Galip39290
Build 4.6
Dec 2, 2011 9:02 AM
I have just downloaded Flex 4.6 framework, and I cannot build the sdk.
When I run ant main, I've got a lot of errors :
    [compc] ^
    [compc]
    [compc] C:\FlexSDK\4.6.0\frameworks\projects\framework\src\mx\core\ILayoutEl
ement.as(29): col: 41 Error: Interface IEventDispatcher was not found.
    [compc]
    [compc] public interface ILayoutElement extends IEventDispatcher
    [compc]                                         ^
    [compc]
    [compc] C:\FlexSDK\4.6.0\frameworks\projects\framework\src\mx\core\ILayoutDi
rectionElement.as(1): col: 1 Error: The definition of base class Object was not
found.
    [compc]
    [compc] ////////////////////////////////////////////////////////////////////
When I build 4.5.1, I have no error and everythink works fine.
Is there a difference in 4.6, should I define a new environnment variable or add an argument to the ant command ?
Thanks in advance.
Nicolas Beaudrot.
    Feb 3, 2012 8:06 AM   in reply to Galip39290
    I'm also unable to compile the 4.6 sdk. I am able to build all previous versions but 4.6 throws a ton of errors.
    Has anyone been able to successfully build sdk 4.6 on windows?
    To build I did the following:
    cd FLEX_HOME/frameworks/
    ant
    Am I missing something? Like I said, I was able to successfully build all previous versions doing this.
    Apr 29, 2013 5:44 AM   in reply to swartzbaugh3
    The build.xml file probably contains an incorrect version:
    <property name="playerglobal.version" value="11.0"/>
    Your environment variable PLAYERGLOBAL_HOME should point to a directory containing various version numbers. The version number specified above must exist and contain the relevant playerglobal.swc file.
