Crash with ADL using Flash Builder 4.6
Dec 7, 2011 2:28 PM
I have this same issue but I'm using Flash Builder 4.6 with AIR 3.1. I tried overlaying Flex SDK 4.6 with AIR SDK 3.1 that I downloaded and I still get the this error. Do you know any fix you can suggest?
Thanks. Any help is greatly appreciated.
kabalweg
Branched from an earlier discussion.
Replies 1 2 Previous Next
  • Chris Campbell
    May 4, 2010
    Dec 1, 2011 2:22 PM   in reply to kabalweg
    Hi Kabalweg,
    I'll give FB 4.6 a try and see if I can reproduce this.  Could you generate a crash dump for adl.exe and send it to me at ccampbel@adobe.com?
    Chris
  • Chris Campbell
    May 4, 2010
    Dec 1, 2011 4:40 PM   in reply to Chris Campbell
    Just to follow up, I uninstalled 4.5, and installed 4.6 on Windows 7.  I created a new sample project with the 4.6 sdk (which already includes AIR 3.1) and I was able to build, run, and debug the project without crashing.  Do you have anything in your project that I should add into mine to reproduce this?
    Chris
  • Chris Campbell
    May 4, 2010
    Dec 2, 2011 1:49 PM   in reply to kabalweg
    Thanks for the heads up.  I've tried it on a couple of machines so far without any luck.  Would you mind sending me a crash dump (.dmp file) so I can symbolicate and look at the call stack?  You can email me at ccampbel@adobe.com.
    Chris
    Dec 4, 2011 10:31 PM   in reply to kabalweg
    Can you please clear the temp folder and uninstall and install Flash Builder and change the current workspace. Do not overlay AIR 3.1 SDK and check if this is still reproducible?
    Kishan
  • Chris Campbell
    May 4, 2010
    Dec 5, 2011 2:08 PM   in reply to kabalweg
    Could you try opening up a command prompt and seeing if you can use ADL via the command line?
    Using the AIR debug launcher (ADL)
    Chris
  • Chris Campbell
    May 4, 2010
    Dec 6, 2011 1:11 PM   in reply to kabalweg
    So, you crash even if you do a "adl -help" at the command line?  If so, would you mind downloading the AIR sdk and just extract it to a folder (without bothering to do a flex overlay) and try the command line again?  If 3.1 crashes, can you try 2.7?
    Adobe AIR SDK Latest
    Adobe AIR SDK 2.7
    Chris
  • Chris Campbell
    May 4, 2010
    Dec 7, 2011 12:50 PM   in reply to kabalweg
    Thanks for the update.  I'll research more.  Would you mind zipping up your MobileLab project and emailing it to me at ccampbel@adobe.com?
    Chris
  • Chris Campbell
    May 4, 2010
    Dec 7, 2011 2:19 PM   in reply to kabalweg
    Thanks!  I'll take a look.  I heard back from one of our ADL experts and they suggested:
    I would normally try this. First, cd to the app.xml dir. Then run this much simpler command:
    “C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0 (AIR 3.1)\bin\adl.exe”  -profile mobileDevice -screensize 320×460:320×480 MobileLab-app.xml
    If this works, then add more options to the command line to see where it breaks.
    Chris
  • Chris Campbell
    May 4, 2010
    Dec 7, 2011 2:31 PM   in reply to Chris Campbell
    Branched this discussion to a new topic.
  • Chris Campbell
    May 4, 2010
    Dec 7, 2011 2:36 PM   in reply to Chris Campbell
    I was able to run your app using the default 4.6.0 sdk provided by Flash Builder 4.6 using the following ADL command line:
    "C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\bin\adl.exe" -profile mobileDevice -screensize 320X460:320X480 -XscreenDPI 163 -XversionPlatform IOS MobileTest-app.xml
    It also worked fine for me using Flash Builder 4.6 itself, and setting the mobile configuration to an Applie iPhone 4.
    Chris
  • Chris Campbell
    May 4, 2010
    Dec 7, 2011 2:38 PM   in reply to Chris Campbell
    I saw your message in the other thread that the simple command line causes a crash.  Are you sure you're using the default 4.6.0 sdk provided with the Flash Builder 4.6 install?  I noticed in your previous command line that you referenced "4.6.0 (AIR 3.1)" which looks like a custom directory.
  • Chris Campbell
    May 4, 2010
    Dec 8, 2011 1:54 PM   in reply to kabalweg
    Well, I'm stumped.  Unfortunately, the crash log you sent last week didn't contain any AIR related code in the call stack.  You might want to try creating a new, temporary, user account and seeing if the crash occurs there too.  Have you tried this on any other system?
    Chris
    Dec 14, 2011 10:05 AM   in reply to kabalweg
    Same, here. Exactly like kabalweb is describing. Was there ever a solution to this issues?
  • Chris Campbell
    May 4, 2010
    Dec 14, 2011 10:56 AM   in reply to lucasmaj99
    We haven't been able to reproduce the crash.  Lucas, can you generate a crash dump for us and send it to ccampbel@adobe.com?
    Chris
    Dec 14, 2011 11:42 AM   in reply to Chris Campbell
    Dump was sent.
    Dec 14, 2011 11:43 AM   in reply to lucasmaj99
    Adam Lehman already joined in per Holly's blog, but no solution on the horizon yet.
    Dec 14, 2011 7:39 PM   in reply to lucasmaj99
    A few days upgraded to Flash Builder 4.6 with Lion, but now I am getting a crash. This is caused by running a simple default project (as shown) created by File/New/Flex Project. I properly uninstalled 4.5 prior to installing 4.6. I have also updated to latest versions of AIR and all Lion updates. I have a MacBook 2.3 gHz Intel Core i7.
    <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                         xmlns:mx="library://ns.adobe.com/flex/mx">
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
    </s:WindowedApplication>
    Here is the Lion crash report:
    Process:         adl [258]
    Path:            /Applications/Adobe Flash Builder 4.6/*/adl
    Identifier:      adl
    Version:         ??? (???)
    Code Type:       X86 (Native)
    Parent Process:  Adobe Flash Builder 4.6 [188]
    Date/Time:       2011-12-14 21:33:53.102 -0600
    OS Version:      Mac OS X 10.7.2 (11C74)
    Report Version:  9
    Interval Since Last Report:          2131 sec
    Crashes Since Last Report:           10
    Per-App Crashes Since Last Report:   10
    Anonymous UUID:                      F166F2BF-69B6-4755-8575-4ED8168C66B9
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000c0000020
    VM Regions Near 0xc0000020:
        Stack                  00000000bf800000-00000000c0000000 [ 8192K] rw-/rwx SM=COW
        CG shared images       00000000c0003000-00000000c000b000 [   32K] r--/r-- SM=SHM
    Application Specific Information:
    objc_msgSend() selector name: backingScaleFactor
    objc[258]: garbage collection is OFF
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   libobjc.A.dylib                         0x929c5e87 objc_msgSend_fpret + 23
    1   com.apple.AppKit                        0x90a4527a -[NSWindow _setFrame:updateBorderViewSize:] + 1223
    2   com.apple.AppKit                        0x90a44915 -[NSWindow _oldPlaceWindow:] + 630
    3   com.apple.AppKit                        0x909ee514 -[NSWindow _setFrameCommon:display:stashSize:] + 1657
    4   com.apple.AppKit                        0x909ede96 -[NSWindow setFrame:display:] + 71
    5   com.adobe.AIR                           0x01574a68 0x1000000 + 5720680
    6   com.adobe.AIR                           0x016c594c 0x1000000 + 7100748
    7   com.adobe.AIR                           0x0168661b 0x1000000 + 6841883
    8   com.adobe.AIR                           0x01841106 0x1000000 + 8655110
    9   com.adobe.AIR                           0x01842c59 0x1000000 + 8662105
    10  com.adobe.AIR                           0x01846d57 0x1000000 + 8678743
    11  com.adobe.AIR                           0x01872ead 0x1000000 + 8859309
    12  com.adobe.AIR                           0x018df0bc 0x1000000 + 9302204
    13  com.adobe.AIR                           0x015636c8 0x1000000 + 5650120
    14  com.adobe.AIR                           0x01564d05 0x1000000 + 5655813
    15  com.adobe.AIR                           0x01861b09 0x1000000 + 8788745
    16  com.adobe.AIR                           0x0194576c FREGetObjectAsInt32 + 176322
    17  com.apple.CoreFoundation                0x930ba091 -[NSObject performSelector:withObject:] + 65
    18  com.apple.Foundation                    0x94b78f64 __NSThreadPerformPerform + 503
    19  com.apple.CoreFoundation                0x9303184f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
    20  com.apple.CoreFoundation                0x93031206 __CFRunLoopDoSources0 + 246
    21  com.apple.CoreFoundation                0x9305b0d8 __CFRunLoopRun + 1112
    22  com.apple.CoreFoundation                0x9305a8ec CFRunLoopRunSpecific + 332
    23  com.apple.CoreFoundation                0x9305a798 CFRunLoopRunInMode + 120
    24  com.apple.HIToolbox                     0x9008ea7f RunCurrentEventLoopInMode + 318
    25  com.apple.HIToolbox                     0x90095d9b ReceiveNextEventCommon + 381
    26  com.apple.HIToolbox                     0x90095c0a BlockUntilNextEventMatchingListInMode + 88
    27  com.apple.AppKit                        0x908ea040 _DPSNextEvent + 678
    28  com.apple.AppKit                        0x908e98ab -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 113
    29  com.apple.AppKit                        0x908e5c22 -[NSApplication run] + 911
    30  com.adobe.AIR                           0x0100886a 0x1000000 + 34922
    31  com.adobe.AIR                           0x010089cb 0x1000000 + 35275
    32  com.apple.CoreFoundation                0x930ba091 -[NSObject performSelector:withObject:] + 65
    33  adl                                     0x00002fa3 RuntimeMain(char const*, int) + 333
    34  adl                                     0x000028ba start + 54
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib                  0x9bc4a90a kevent + 10
    1   libdispatch.dylib                       0x97071c58 _dispatch_mgr_invoke + 969
    2   libdispatch.dylib                       0x970706a7 _dispatch_mgr_thread + 53
    Thread 2:
    0   libsystem_kernel.dylib                  0x9bc4a02e __workq_kernreturn + 10
    1   libsystem_c.dylib                       0x9b50accf _pthread_wqthread + 773
    2   libsystem_c.dylib                       0x9b50c6fe start_wqthread + 30
    Thread 3:
    Thread 4:
    0   libsystem_kernel.dylib                  0x9bc4983e __psynch_cvwait + 10
    1   libsystem_c.dylib                       0x9b50ce21 _pthread_cond_wait + 827
    2   libsystem_c.dylib                       0x9b4bd42c pthread_cond_wait$UNIX2003 + 71
    3   com.adobe.AIR                           0x016ecc99 0x1000000 + 7261337
    4   com.adobe.AIR                           0x0152b120 0x1000000 + 5419296
    5   com.adobe.AIR                           0x016ecd69 0x1000000 + 7261545
    6   com.adobe.AIR                           0x016ecde3 0x1000000 + 7261667
    7   com.adobe.AIR                           0x016ece7e 0x1000000 + 7261822
    8   libsystem_c.dylib                       0x9b508ed9 _pthread_start + 335
    9   libsystem_c.dylib                       0x9b50c6de thread_start + 34
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    1   libsystem_c.dylib                       0x9b50ce78 _pthread_cond_wait + 914
    2   libsystem_c.dylib                       0x9b50cf7b pthread_cond_timedwait_relative_np + 47
    3   com.adobe.AIR                           0x016ecb79 0x1000000 + 7261049
    4   com.adobe.AIR                           0x0157e071 0x1000000 + 5759089
    5   com.adobe.AIR                           0x0157e08e 0x1000000 + 5759118
    6   com.adobe.AIR                           0x016ecd69 0x1000000 + 7261545
    7   com.adobe.AIR                           0x016ecde3 0x1000000 + 7261667
    8   com.adobe.AIR                           0x016ece7e 0x1000000 + 7261822
    9   libsystem_c.dylib                       0x9b508ed9 _pthread_start + 335
    10  libsystem_c.dylib                       0x9b50c6de thread_start + 34
    Thread 9:
    2   libsystem_c.dylib                       0x9b4bd3e0 pthread_cond_timedwait$UNIX2003 + 70
    3   com.adobe.AIR                           0x016eccc5 0x1000000 + 7261381
    4   com.adobe.AIR                           0x0172c48a 0x1000000 + 7521418
    Thread 10:
    Thread 11:
    3   com.adobe.AIR                           0x01567248 0x1000000 + 5665352
    4   com.adobe.AIR                           0x01564eb6 0x1000000 + 5656246
    5   com.adobe.AIR                           0x015657ee 0x1000000 + 5658606
    6   com.adobe.AIR                           0x0156581b 0x1000000 + 5658651
    7   com.adobe.AIR                           0x016ecd69 0x1000000 + 7261545
    8   com.adobe.AIR                           0x016ecde3 0x1000000 + 7261667
    9   com.adobe.AIR                           0x016ece7e 0x1000000 + 7261822
    10  libsystem_c.dylib                       0x9b508ed9 _pthread_start + 335
    11  libsystem_c.dylib                       0x9b50c6de thread_start + 34
    Thread 0 crashed with X86 Thread State (32-bit):
      eax: 0x00155920  ebx: 0x00545a50  ecx: 0x9130490c  edx: 0xc0000000
      edi: 0x001552b0  esi: 0x90a44dc1  ebp: 0xbfffda88  esp: 0xbfffda18
       ss: 0x00000023  efl: 0x00010202  eip: 0x929c5e87   cs: 0x0000001b
       ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
      cr2: 0xc0000020
    Logical CPU: 2
    Binary Images:
        0x1000 -     0x6ff7 +adl (??? - ???) <4A9D2BEF-8A3D-77D9-29A5-DB5B7B4C50DC> /Applications/Adobe Flash Builder 4.6/*/adl
      0x200000 -   0x2adff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
      0x7e0000 -   0x7eafff  com.apple.IOFWDVComponents (2.0.7 - 2.0.7) <811CF4D6-15B2-3EDA-B026-5E4B28C0F742> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/ IOFWDVComponents
      0x7f5000 -   0x7f9ffb  com.apple.audio.AudioIPCPlugIn (1.2.1 - 1.2.1) <B8333059-00BE-33A6-AEC0-0C8F285E6E07> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0x1000000 -  0x21effc7 +com.adobe.AIR (??? - 3.1.0.4880) <98C235AB-2609-7063-F7C1-025C658A3AA0> /Applications/Adobe Flash Builder 4.6/*/Adobe AIR.framework/Versions/1.0/Adobe AIR
    0x2555000 -  0x258eff3  com.apple.QuickTimeFireWireDV.component (7.7.1 - 2306) <5347333C-9175-39FF-AFEC-BF24BB6701D7> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacO S/QuickTimeFireWireDV
    0x2599000 -  0x25c1fff  com.apple.QuickTimeIIDCDigitizer (7.7.1 - 2306) <6F887F4E-2D83-3415-9342-7EA8600E1349> /System/Library/QuickTime/QuickTimeIIDCDigitizer.component/Contents/M acOS/QuickTimeIIDCDigitizer
    0x25c9000 -  0x25cfffb  com.apple.audio.AppleHDAHALPlugIn (2.1.3 - 2.1.3f7) <C2DD672D-46CE-34BB-8456-129C65DDE583> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x2700000 -  0x274eff7  com.apple.QuickTimeUSBVDCDigitizer (2.7.1 - 2.7.1) <1D79F9C3-E0F4-33AE-A390-38DD884DEA28> /System/Library/QuickTime/QuickTimeUSBVDCDigitizer.component/Contents /MacOS/QuickTimeUSBVDCDigitizer
    0x2758000 -  0x2785ff8  GLRendererFloat (??? - ???) <1264885F-1492-3591-BFB1-B671A7B08A29> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
    0x3b00000 -  0x3c6dffc  GLEngine (??? - ???) <C49CCDEA-F23E-30CD-9BCD-FC09C9D07CF4> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
    0x3e46000 -  0x3f3dffb  libGLProgrammability.dylib (??? - ???) <8E592FEB-B6A8-3BFF-828B-B37B05D4D574> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
    0x6500000 -  0x67a0fe7  com.apple.ATIRadeonX3000GLDriver (7.14.5 - 7.1.4) <BA35443F-847C-344D-80C1-B9EC528B89C9> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/Mac OS/ATIRadeonX3000GLDriver
    0xa800000 -  0xab96fff  com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.14.5 - 7.1.4) <3085DB78-3E8E-3570-B235-3ED8F1E712B3> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Co ntents/MacOS/AppleIntelHD3000GraphicsGLDriver
    0x8feab000 - 0x8fedd9c7  dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
    0x90005000 - 0x9000cffd  com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x90013000 - 0x9003bff0  com.apple.CoreServicesInternal (113.8 - 113.8) <9930695C-1C48-329F-93FD-5AEEE2EF942C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
    0x9003c000 - 0x9008bffb  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <71C9D388-E607-3DB4-9FD3-FC918EB4A835> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
    0x9008c000 - 0x903ccffb  com.apple.HIToolbox (1.8 - ???) <DFED9BD0-E142-397B-BE16-16EBCF3CE1EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x903f6000 - 0x9040bfff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x9040f000 - 0x90418ffb  com.apple.DisplayServicesFW (2.5.2 - 317) <DF4FCE9C-A4EE-3590-B079-495AC83836EA> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
    0x90419000 - 0x9041cff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
    0x90422000 - 0x906a7fe3  com.apple.QuickTime (7.7.1 - 2306) <F8C64DC4-3FE4-3A06-B10B-59E7F3BA6FDD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x906df000 - 0x906efff7  libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
    0x90760000 - 0x907c2ffb  com.apple.datadetectorscore (3.0 - 179.4) <12EF80E0-35CC-30A7-942F-2F9E87C4C98C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
    0x907c3000 - 0x9081fff3  com.apple.Symbolication (1.2 - 83.1) <E651A2F1-CC13-3DDD-9B0A-09180014966B> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
    0x90820000 - 0x9088ffff  com.apple.Heimdal (2.1 - 2.0) <DE626683-DF32-341B-8997-AE63309590C7> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
    0x90896000 - 0x908dfff7  libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x908e0000 - 0x9136effe  com.apple.AppKit (6.7.2 - 1138.23) <ADFA8D70-601E-3B5C-96FD-F45F52055CC8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x9137a000 - 0x9137dffd  libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
    0x915a8000 - 0x922f8fff  com.apple.QuickTimeComponents.component (7.7.1 - 2306) <B397F658-057A-3D84-ABC7-84AA6256DB88> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
    0x922f9000 - 0x9230eff7  com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x9230f000 - 0x92420ff7  libJP2.dylib (??? - ???) <35D120D4-3304-3A02-9259-EB933E74E63A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x92421000 - 0x9244eff7  com.apple.securityinterface (5.0 - 55004) <93C0285A-A266-3F21-82C9-434CBD3FA712> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
    0x9244f000 - 0x92809ffb  com.apple.SceneKit (2.1 - 125.1) <7BFC0028-18AC-3B49-8DDC-CB7A7359D4F7> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/Scene Kit
    0x9280a000 - 0x929beff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
    0x929bf000 - 0x92a95a5b  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <A0EDB351-4B9D-3AA2-9D1A-0C22204FCCD3> /usr/lib/libobjc.A.dylib
    0x92a96000 - 0x92ae6fff  libFontRegistry.dylib (??? - ???) <81E03B82-1F31-3702-97DC-BE20298E326F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x92b1c000 - 0x92b35fff  libPng.dylib (??? - ???) <A83B66DC-302C-3A4C-8107-0E5560708024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x92eac000 - 0x92f27ffb  com.apple.ApplicationServices.ATS (317.5.0 - ???) <D5AC5C21-CE1E-333D-94F7-F0F534FD4DC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x92f88000 - 0x92fb6ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x92fb7000 - 0x9301cff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x93020000 - 0x931f6fe3  com.apple.CoreFoundation (6.7.1 - 635.15) <AC9F6462-6315-3D89-8075-D048DB4DBF7E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x931f7000 - 0x93216fff  com.apple.RemoteViewServices (1.2 - 39) <C7B638D2-2F8B-3A45-916A-73103FADC822> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
    0x93217000 - 0x93519fff  com.apple.CoreServices.CarbonCore (960.18 - 960.18) <8094724D-591D-3CC2-81DE-4E3029624E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x9351a000 - 0x93543ffe  com.apple.opencl (1.50.63 - 1.50.63) <C4EC60D6-9A7C-3CE9-AA80-2F81D9BB4465> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x939ed000 - 0x93a2eff7  com.apple.CoreMedia (1.0 - 705.42) <B45070F1-4097-3BAD-AA7C-0F7AFD6EAC27> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x93a3a000 - 0x940e3eeb  com.apple.CoreGraphics (1.600.0 - ???) <322FC806-0B9F-3A58-8C88-D477E32A50F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x940e4000 - 0x94135ff3  com.apple.CoreMediaIO (210.0 - 3180) <79AA7CA8-FC39-375D-9485-855D302DF7AA> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMedia IO
    0x94136000 - 0x941caff7  com.apple.LaunchServices (480.21 - 480.21) <E3621817-B627-3EEC-A7F9-0D45583B7FE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x941cb000 - 0x941cffff  com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x9426c000 - 0x9426effb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x9427a000 - 0x94297fff  libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <95AE43ED-6C52-3B39-89B6-54C81C62F1FF> /usr/lib/libresolv.9.dylib
    0x94298000 - 0x94298fff  com.apple.quartzframework (1.5 - 1.5) <EF66BF08-620E-3D11-87D4-35D0B0CD1F6D> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x94299000 - 0x94359fff  com.apple.CoreServices.OSServices (478.29 - 478.29) <EAAAAC1B-2599-3875-9068-DF7E6B5760A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x94380000 - 0x943a2ff1  com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
    0x943a3000 - 0x943a3fff  com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x943a4000 - 0x943acff3  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
    0x943ad000 - 0x94417ff3  com.apple.CoreSymbolication (2.1 - 66) <B11C9057-1611-36A5-81F6-2C97A7047321> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
    0x94440000 - 0x94440fff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
    0x94556000 - 0x9456aff7  com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x9456b000 - 0x945bcff9  com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x94609000 - 0x94a7eff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
    0x94a7f000 - 0x94b23fff  com.apple.QD (3.12 - ???) <68CBE425-43BA-3E6D-8668-A4A67396E20D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x94b24000 - 0x94e2eff3  com.apple.Foundation (6.7.1 - 833.20) <B5092554-485A-3A7D-904B-B04B1EE5C50C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x94e31000 - 0x94e4bfff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x95005000 - 0x9502dff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
    0x9508c000 - 0x9516fff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
    0x95170000 - 0x951acfff  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <AA56493C-D7C6-3D4F-8DC8-855405AFF57B> /usr/lib/libcups.2.dylib
    0x951ad000 - 0x951c0ffb  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <3D94520B-C976-370F-AF56-278002BCF11D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
    0x951c1000 - 0x951ccfff  libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
    0x951cd000 - 0x9532ffff  com.apple.QTKit (7.7.1 - 2306) <5A7E5ED0-C4DC-3CEC-ABE0-24899134ACE1> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x95330000 - 0x95331ff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
    0x95f87000 - 0x95f8affc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
    0x95f8b000 - 0x95fc1ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x95fc2000 - 0x960b2ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
    0x96487000 - 0x96487fff  com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x96488000 - 0x96489ff5  libremovefile.dylib (21.0.0 - compatibility 1.0.0) <9A1E12B7-F822-3544-8E1D-A6DC81E1F2E6> /usr/lib/system/libremovefile.dylib
    0x96507000 - 0x96557ff9  com.apple.QuickLookFramework (3.1 - 500.1) <28CB604E-2426-3491-BF16-2CDFD4C392B0> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x96558000 - 0x96565fff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x9657a000 - 0x965c8ff3  com.apple.ImageCaptureCore (3.0.1 - 3.0.1) <DB40F137-4519-339B-81DC-7375B2FE8FD2> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
    0x965c9000 - 0x965e6ff3  com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x96dbe000 - 0x96dc7fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
    0x96dd4000 - 0x96dd5ff7  libsystem_sandbox.dylib (??? - ???) <BC0A04E9-4F28-3BC8-AA7B-63C3451E9212> /usr/lib/system/libsystem_sandbox.dylib
    0x96dd6000 - 0x96ddaffd  IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x96f0a000 - 0x96f62fff  com.apple.HIServices (1.10 - ???) <76B50B43-6CFD-3067-A085-11420FD4FAA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x96f63000 - 0x96fa1fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0AE59D4F-FFA7-3539-8B86-AD8993894AA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x96fa2000 - 0x9702cffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x9706f000 - 0x9707dfff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
    0x970af000 - 0x9714aff3  com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x9714b000 - 0x97181fff  com.apple.DebugSymbols (2.1 - 85) <0F996A4A-16A7-3C90-8037-0E2958D1FB16> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
    0x97182000 - 0x9718afff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x97254000 - 0x9732bffb  com.apple.avfoundation (2.0 - 180.30) <6788562E-A9A8-3898-A0F4-66D9BBAE3430> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFounda tion
    0x9732c000 - 0x9733afff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
    0x97389000 - 0x973f0fff  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
    0x973f1000 - 0x973f2fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
    0x973f3000 - 0x97a6efe5  com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
    0x97a6f000 - 0x97a73ff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
    0x97a74000 - 0x97b94fec  com.apple.vImage (5.1 - 5.1) <008B989F-F080-398E-ACB1-FBF5BA107D6D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x97b95000 - 0x97cf6ffb  com.apple.QuartzCore (1.7 - 270.0) <0916DA83-6400-3FEA-BC53-5F4BA4D126EC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x97db5000 - 0x97e9dfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
    0x97fb6000 - 0x980e2ff9  com.apple.CFNetwork (520.2.5 - 520.2.5) <02193949-50A8-3CBC-9920-5FCDB8EBE17A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x980e3000 - 0x980e4fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
    0x980e5000 - 0x98114ff7  libsystem_info.dylib (??? - ???) <B86A363D-6EA2-3A69-A6CB-18B7F98FC61A> /usr/lib/system/libsystem_info.dylib
    0x98115000 - 0x98267fff  com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <7646E131-08EE-3D72-ADA2-4A61C562B36E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x98268000 - 0x98377ffb  com.apple.DesktopServices (1.6.1 - 1.6.1) <9F02752A-617B-3AC7-BCA1-F040C105EDDE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x98388000 - 0x983c6fff  com.apple.NavigationServices (3.6 - 192) <CB7AE807-9292-3EBA-A5F5-D7DCEE28A5B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x98408000 - 0x9842dff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x98474000 - 0x98479ffd  libGFXShared.dylib (??? - ???) <820D744C-C641-3918-A72A-AC2E5276BCB6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
    0x9847a000 - 0x984a4ff0  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib
    0x984cf000 - 0x988d1ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x98916000 - 0x98bc8ff7  com.apple.security (7.0 - 55010) <BE0350C5-5221-3BFF-B674-646AB1BA0F2E> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x98bfd000 - 0x98c00fff  com.apple.AppleSystemInfo (1.0 - 1) <D2F60873-ECB1-30A8-A02E-E772F969116E> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/ A/AppleSystemInfo
    0x98c16000 - 0x98c32ff5  com.apple.GenerationalStorage (1.0 - 125) <F1D67293-9192-367D-AE74-2732B23E7E77> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
    0x98c33000 - 0x98c33fff  com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x98c34000 - 0x98c3dff3  com.apple.CommonAuth (2.1 - 2.0) <D49B41B1-A5DD-366A-8C30-49E9B875AA13> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
    0x98c3e000 - 0x98cd5ff3  com.apple.securityfoundation (5.0 - 55005) <F5A98CC2-11C6-34F3-8F72-75B642627630> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
    0x98cd6000 - 0x98dceff7  libFontParser.dylib (??? - ???) <83E7E71E-D217-3DEE-B288-F5BAE7E118C5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x98dcf000 - 0x98dcffff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x98df6000 - 0x991e9feb  com.apple.VideoToolbox (1.0 - 705.42) <3F12F8A3-ED41-3EAD-A887-B7805353122C> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
    0x991ea000 - 0x9952cfff  com.apple.MediaToolbox (1.0 - 705.42) <5AEFD5BE-6FA3-38F8-966A-B0AB56C472B8> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
    0x9952d000 - 0x99534fff  com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x99540000 - 0x99542ff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
    0x998ec000 - 0x99979fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x9997a000 - 0x999f6ffd  com.apple.PDFKit (2.6.1 - 2.6.1) <7BC3186B-80B7-3E68-AFDD-2734164BCCFB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
    0x99b2b000 - 0x99bebff3  com.apple.ColorSync (4.7.0 - 4.7.0) <A39EA668-D042-377F-BC81-26748CD57ADC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x99c3a000 - 0x99c48fff  com.apple.opengl (1.7.5 - 1.7.5) <81166D23-DE8E-3938-AAD3-29B1FA5E446E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x99c49000 - 0x99cabff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
    0x99cac000 - 0x99cd7fff  com.apple.GSS (2.1 - 2.0) <05A0171B-76EA-3E4C-8A36-65D1A978AF4B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x99d36000 - 0x99fa9fff  com.apple.CoreImage (7.82 - 1.0.1) <6C99F458-E83A-3538-9B71-2C8BD0C9DCD5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
    0x99faa000 - 0x9a080ff6  com.apple.QuickLookUIFramework (3.1 - 500.1) <4E259D94-6081-32D7-AD60-565E57B11EBA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
    0x9a081000 - 0x9a087ffd  com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x9a088000 - 0x9a09effe  libxpc.dylib (77.17.0 - compatibility 1.0.0) <E01E0074-0830-3F20-8703-EA7722BFD358> /usr/lib/system/libxpc.dylib
    0x9a09f000 - 0x9a0a0fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
    0x9a0a1000 - 0x9a0a7ffb  com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x9a0b1000 - 0x9a0d4fff  com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x9a0d5000 - 0x9a0dcff5  libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
    0x9a0dd000 - 0x9a13affb  com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x9a1a8000 - 0x9a1b9fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
    0x9a1ba000 - 0x9a1e0ffb  com.apple.quartzfilters (1.7.0 - 1.7.0) <9C8F1F3D-D570-3F5C-9B31-5B5B82161CDE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
    0x9a1e7000 - 0x9a227ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
    0x9a328000 - 0x9a330ff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
    0x9a331000 - 0x9a339ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
    0x9a33a000 - 0x9a559ff7  com.apple.imageKit (2.1.1 - 1.0) <9AF0A882-BEAD-3AEC-8A72-497A7C3C2358> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
    0x9a652000 - 0x9a669ff8  com.apple.CoreMediaAuthoring (2.0 - 889) <49B55753-BD7E-3889-BA60-15294DA49CB7> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versio ns/A/CoreMediaAuthoring
    0x9a66a000 - 0x9a675ffc  com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
    0x9b0a8000 - 0x9b0a8fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x9b0a9000 - 0x9b0aaffd  com.apple.MonitorPanelFramework (1.4.0 - 1.4.0) <45AC1CB9-2A81-3FEA-9BA4-E9BBA2582A28> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
    0x9b0ab000 - 0x9b0acfff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
    0x9b0ad000 - 0x9b0adffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
    0x9b0ae000 - 0x9b1bdff7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <90D36793-04A5-3BFF-BE83-EEEDCBEDC756> /usr/lib/libsqlite3.dylib
    0x9b1be000 - 0x9b407ff7  com.apple.JavaScriptCore (7534.52 - 7534.52.7) <19E4C699-A9BA-3FCB-90CC-02C8F0607165> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
    0x9b408000 - 0x9b495ff7  com.apple.CoreText (220.11.0 - ???) <4F98D709-75AC-35F0-AD88-8F2C4BD744C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x9b4aa000 - 0x9b4abffd  libCVMSPluginSupport.dylib (??? - ???) <96F2F2F4-E7A9-36C8-B1CF-D58AA3DB2B44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
    0x9b4ac000 - 0x9b577fff  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
    0x9b578000 - 0x9b5d1ffb  com.apple.coreui (1.2.1 - 164.1) <890E0BE9-3360-3B56-BE46-5A2421875A40> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x9b5d4000 - 0x9b65bfff  com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x9b6c5000 - 0x9b6e7ffe  com.apple.framework.familycontrols (3.0 - 300) <F87D87EF-553A-3165-9C9A-6E117C537FE9> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
    0x9b6e8000 - 0x9b72ffff  com.apple.SystemConfiguration (1.11.1 - 1.11) <CA6CE2B6-DC18-31FF-9668-70BB2FD8D7BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x9b730000 - 0x9b734ffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
    0x9b9a8000 - 0x9b9afff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
    0x9baf7000 - 0x9baf8ff7  libquarantine.dylib (36.0.0 - compatibility 1.0.0) <70782AEC-8933-3EB4-91CA-E44C0E768C90> /usr/lib/system/libquarantine.dylib
    0x9baf9000 - 0x9bb03ff2  com.apple.audio.SoundManager (3.9.4 - 3.9.4) <D23C4761-6492-3974-B4D2-495082B8B7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x9bb59000 - 0x9bb95ffd  libGLImage.dylib (??? - ???) <8251242B-E04E-3467-BD0F-834578B18AC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x9bc31000 - 0x9bc4fff7  libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
    0x9bc58000 - 0x9bc9bffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
    0x9bc9c000 - 0x9bc9eff9  com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x9bc9f000 - 0x9bcaaff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <11726E50-E6FC-3AB0-8750-DDDCCF2B8534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x9bcab000 - 0x9bd0cffb  com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <089D78E0-46A6-38DB-9545-7F35CC815939> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x9bd21000 - 0x9bd21fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x9bd22000 - 0x9bd97fff  com.apple.Metadata (10.7.0 - 627.20) <1E7C8194-8CE4-3103-A3D1-8913238AF923> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x9bde5000 - 0x9bde9fff  libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x9bdea000 - 0x9c2c6ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x9c2c7000 - 0x9c2d7fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x9c329000 - 0x9c38dfff  com.apple.framework.IOKit (2.0 - ???) <D14460ED-2B6C-375D-B3A4-B8C82E922666> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x9c38e000 - 0x9c38eff0  com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x9c3c9000 - 0x9c441ff2  com.apple.CorePDF (3.0 - 3.0) <A0EC8F60-A622-347E-979A-F71939C45E5F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
    0x9c444000 - 0x9c62dff7  com.apple.CoreData (104 - 358.12) <F8AD7990-2C30-31A4-8E78-FA8DD5CF03CC> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x9c63c000 - 0x9c865ffb  com.apple.QuartzComposer (5.0 - 236) <7BD138F0-C748-3013-98C0-4D5F5E10B9AB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
    0x9c866000 - 0x9c894fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <07D9A827-9567-34C2-9022-AF4BF975C9A7> /usr/lib/libSystem.B.dylib
    0x9c8ad000 - 0x9c97cfff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <8B8A3DD3-BB3D-33FC-A714-81E1B883B155> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x9c97d000 - 0x9c97dff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x9c9a8000 - 0x9c9adff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
    0x9caee000 - 0x9cb3eff4  libTIFF.dylib (??? - ???) <E86EA22A-82C0-3E77-9EAF-739F385790D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x9cb3f000 - 0x9cb4affb  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x9cb4b000 - 0x9cb4fff7  com.apple.OpenDirectory (10.7 - 146) <3D3D30CE-6D82-3681-AA98-4E3AEFFA4229> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
    0x9cb53000 - 0x9cb56ffb  com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x9cb57000 - 0x9cb5aff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 2
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 451
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=203.9M resident=110.1M(54%) swapped_out_or_unallocated=93.8M(46%)
    Writable regions: Total=140.2M written=8800K(6%) resident=10.7M(8%) swapped_out=0K(0%) unallocated=129.5M(92%)
    REGION TYPE                      VIRTUAL
    ATS (font support)                 31.8M
    ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
    CG shared images                    168K
    CoreGraphics                          8K
    CoreServices                       1676K
    IOKit                               168K
    MALLOC                             71.1M
    MALLOC guard page                    32K
    Memory tag=240                     6528K
    Memory tag=242                       12K
    Memory tag=243                        4K
    Memory tag=249                      156K
    Stack                              69.6M
    VM_ALLOCATE                        16.1M
    __CI_BITMAP                          80K
    __DATA                             11.9M
    __DATA/__OBJC                       200K
    __IMAGE                            1256K
    __IMPORT                              4K
    __LINKEDIT                         45.0M
    __OBJC                             2344K
    __OBJC/__DATA                         4K
    __PAGEZERO                            4K
    __TEXT                            158.9M
    __UNICODE                           544K
    mapped file                        90.4M
    shared memory                       308K
    shared pmap                        7292K
    TOTAL                             515.1M
    TOTAL, minus reserved VM space    515.1M
    Model: MacBookPro8,2, BootROM MBP81.0047.B24, 4 processors, Intel Core i7, 2.3 GHz, 4 GB, SMC 1.69f3
    Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
    Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
    Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
    Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.100.98.75.18)
    Bluetooth: Version 4.0.1f4, 2 service, 18 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: Hitachi HTS725050A9A362, 500.11 GB
    Serial ATA Device: HL-DT-ST DVDRW  GS31N
    USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 3
    USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 5
    USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 8
    USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
    USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
    USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
  • Chris Campbell
    May 4, 2010
    Dec 15, 2011 11:18 AM   in reply to lucasmaj99
    I think I asked this earlier but I didn't see a response.  Is anyone crashing ADL against the AIR 2.7 SDK?
    Chris
  • Chris Campbell
    May 4, 2010
    Dec 15, 2011 11:21 AM   in reply to Chris Campbell
    Zaelou,
    I suspect you might be running into a known issue with late model Apple computers running 10.7.2. Can you try a couple of workarounds to see if this solves your crash?
    • Open System Preferences, select Energy Saver and disable Automatic graphics switching (or use a third party GPU switcher, such as gfxCardStatus and enable the Nvidia GPU)
    • Before launching your AIR based application, launch either Google Chrome or Mozilla Firefox.
    We apologize for the inconvenience and hope to have this resolved soon.
    Chris
    Dec 15, 2011 11:50 AM   in reply to Chris Campbell
    Any work arounds for Win7?
    Dec 15, 2011 12:33 PM   in reply to Chris Campbell
    Chris,
    Yes. I have confirmed that disabling Automatic Graphics Switching does eliminate the crash on Lion 10.7.2.
    BTW, the crash occurs both in the FB4.6 IDE, and also with an installed .air app.
    Thank you,
    Zaeiou
    Dec 15, 2011 12:58 PM   in reply to kabalweg
    Yes, same here. Logged in as brand new "test" user and no crash. So ... what would be a perm solution?
  • Chris Campbell
    May 4, 2010
    Dec 16, 2011 3:00 PM   in reply to lucasmaj99
    Ok, thanks for the feedback that the new user account is working properly.  It sounds like something exists on your regular accounts that is causing a conflict.
    Could you try temporarily removing the following folder and seeing if that makes a difference?
    C:\Users\UserName\AppData\Roaming\Adobe\AIR\CRLCache
    Chris
    Dec 19, 2011 4:42 AM   in reply to Chris Campbell
    Thanks Chris, that solved it for me!
    Any idea when this will be fixed?
    Dany
    Dec 19, 2011 5:47 AM   in reply to Chris Campbell
    Sorry, behavior did not change. Still crashing.
    Dec 20, 2011 12:33 PM   in reply to kabalweg
    Re:Crash with ADL using latest SDK - 4.6 with AIR Version - 3.1
    I am using Flash Builder - 4.0 with upgraded version of 4.6 SDK from 4.1/4.5.1.
    When I am trying to debugging my code Adobe AIR Debug Launcher has stopped working with following ERROR Details:
    If I Use Adobe 4.6 SDK ADL is getting crashed following is the Error Message.
    Any solution for this issue would be appriciated .
    Problem signature:
      Problem Event Name:                        APPCRASH
      Application Name:                             adl.exe
      Application Version:                           3.1.0.4880
      Application Timestamp:                    4eb7612e
      Fault Module Name:                          Adobe AIR.dll
      Fault Module Version:                        3.1.0.4880
      Fault Module Timestamp:                 4eb75fb9
      Exception Code:                                  c0000005
      Exception Offset:                                00183969
      OS Version:                                          6.1.7600.2.0.0.274.10
      Locale ID:                                             1033
      Additional Information 1:                  0a9e
      Additional Information 2:                  0a9e372d3b4ad19135b953a78882e789
      Additional Information 3:                  0a9e
      Additional Information 4:                  0a9e372d3b4ad19135b953a78882e789
    Read our privacy statement online:
      http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
      C:\Windows\system32\en-US\erofflps.txt
    Naresh Reddy.
    Jan 7, 2012 1:53 PM   in reply to Naresh_Reddy
    same issue happens for me on windows Vista. Clearing the AIR cache as suggested did not work. Any new ideas?
  • Chris Campbell
    May 4, 2010
    Jan 9, 2012 1:24 PM   in reply to bmilesp
    Officeissue and bmilesp,
    Does this crash still occur if you create a new, temporary, user account and try building from there?  I've been unable to reproduce the issue and am hoping we can figure out what's different between the accounts.
    Chris
    Jan 9, 2012 2:13 PM   in reply to Chris Campbell
    Hey Chris
        I downloaded 4.6 SDK from Adobe site using my Original Account.Do you want me to create temporary account to get this 4.6 SDK ?
    I didn't try that way, anyhow i'll create one temporary account to get 4.6 SDK and i'll proceed from there onwards.I'll let you know the result.
    Naresh Reddy.
  • Chris Campbell
    May 4, 2010
    Jan 9, 2012 2:35 PM   in reply to Naresh_Reddy
    Hi Naresh,
    I'm sorry I wasn't clear in my previous post.  I should have said a new, temporary, windows account.  Other devs in this thread have stated that doing this allowed ADL to run without crashing.  Just wanted to figure out if it helps you too.
    Chris
1 2 Previous Next
Actions
