• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
1
iPhone 4s Video - Serious Sync Issues Eliminate Premiere as a tool
Guest
Dec 08, 2011 Dec 08, 2011
I was excited to see how great the video is from the iPhone 4s.  I have taken one hour 1080P videos of lectures that look great.  However, when pulled into Premiere (CS5), the sound goes out of sync to the point that it is unusable after about seven minutes.  I have checked the original file (.MOV) using QT - it plays perfectly.  Indeed, I can trim and split the file using QT and I know that creating a bunch of small videos to link in Premiere would be a solution of sorts.
What is the deal?  No ability by Adobe to handle MOV files and the screwy indexing they use?  Disappointing.
Or have I missed something?  The sync problem is apparent in the source window - before I add to sequence. Any ideas?  Has anyone tried this with an iPhone 4S video beyond 10 minutes?
Brad
TOPICS
Import
Views
163.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Sep 02, 2015 Sep 02, 2015
1- Download Handbrake.
2- Change from Variable Frame Rate to Constant Frame Rate.
3- Import to PPro.
Cheers.
Votes
Translate
Translate
Community Expert ,
Does your video match your project setting... so there is NO red line over the timeline?
See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-green-render-bars.html
Votes
Translate
Translate
Report
Report
Guest
Yes, indeed the bar is green, I think. (kind of a yellow, green)  And I created the sequence exactly as your post suggested by dragging the file over the "new".  Here is the resulting settings:
Votes
Translate
Translate
Report
Report
LEGEND ,
Looks like those settings did not make it into your post. Could you type them out again?
Thanks and good luck,
Votes
Translate
Translate
Report
Report
Guest
One more thing.  The video is not sync'd even in the source window - without putting it into a sequence.  I thought the source file must then be out of sync, but when I play it using Quicktime, it is perfect.
Votes
Translate
Translate
Report
Report
Guest
Here are the stats for the quicktime file from Media Inspector.  It is interesting that the video length is different than the audio length.
Report for file: IMG_0115.MOV
General / Container Stream #1
          Total Video Streams for this File.................1
          Total Audio Streams for this File.................1
          Video Codecs Used.................................AVC
          Audio Codecs Used.................................AAC LC
          File Format.......................................MPEG-4
          Play Time.........................................49mn 11s
          Total File Size...................................8.21 GiB
          Total Stream BitRate..............................23.9 Mbps
          Encoded with......................................5.0.1
          Encoding Library..................................Apple QuickTime
Video Stream #1
          Codec (Human Name)................................AVC
          Codec (FourCC)....................................avc1
          Codec Profile.....................................Baseline@L4.1
          Frame Width.......................................1 920 pixels
          Frame Height......................................1 080 pixels
          Frame Rate........................................29.970 fps
          Total Frames......................................88453
          Display Aspect Ratio..............................16:9
          Scan Type.........................................Progressive
          Color Space.......................................YUV
          Codec Settings (Summary)..........................1 Ref Frames
          QF (like Gordian Knot)............................0.383
          Codec Settings (CABAC)............................No
          Codec Settings (Reference Frames).................1
          Video Stream Length...............................49mn 11s 385ms
          Video Stream BitRate..............................23.8 Mbps
          Video Stream BitRate Mode.........................VBR
          Bit Depth.........................................8 bits
          Video Stream Size.................................8.18 GiB (100%)
          Video Stream Title................................Core Media Video
          Date of Original Encoding.........................UTC 2011-12-04 13:44:35
          Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
          Transfer Characteristics..........................BT.709-5, BT.1361
          Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio Stream #1
          Codec.............................................AAC
          Codec (FourCC)....................................40
          Audio Stream Length...............................49mn 11s 442ms
          Audio Stream BitRate..............................64.0 Kbps
          Audio Stream BitRate Mode.........................CBR
          Number of Audio Channels..........................1
          Audio Channel's Positions.........................Front: C
          Sampling Rate.....................................44.1 KHz
          Audio Stream Size.................................22.1 MiB (0%)
          Audio Stream Title................................Core Media Audio
Votes
Translate
Translate
Report
Report
Guest
Sorry, I don't think the picture uploaded:  here is another try.
One strange thing.  This shows 30F/S.  When I evaluate iPhone file with Media Inspector it shows 29.97.  This mismatch has caused me to see sync drift in the past.  But no matter what I do I can't get it synced - even when i manually correct the frame rate.
There must be others that have tried iPhone 4S videos beyond 10 minutes!
Votes
Translate
Translate
Report
Report
LEGEND ,
Quick question: do you, by chance, have a Matrox card installed on your computer?
Votes
Translate
Translate
Report
Report
Guest
No Matrox Card.  Running on a 2010 MacBook Pro with the Lion (10.7.2).
One other piece of info.  I shrunk the file from the original 8G using QT.  The smaller file was sync'd.  I put that into Premiere - no joy.  I uploaded the smaller file to Vimeo and they were able to process it with no loss of sync - they obviously don't use premiere!
Thanks for your help!
Brad
Votes
Translate
Translate
Report
Report
Explorer ,
Dec 09, 2011 Dec 09, 2011
I've had sync issues with the iPhone 4, that looks at lot like yours. When I looked at my footage with Interpret Footage, it showed "Use Frame Rate from File: 31.5789", and Mediainfo showed a varying frame rate. Setting the frame rate (in Interpret Footage) to 29.97 fixed the problem completely. It's worth a try
Votes
Translate
Translate
Report
Report
Guest
Dec 10, 2011 Dec 10, 2011
Tried interpret footage at 29.97 and no effect on the sync.  Again, QT plays this perfectly.  Premiere is out of sync by over one second at the end of 45 minutes.  Output from QT is also out of sync.  When I say OOS - it is in the imported file in the source window - and then of course in the sequence too.  I am beginning to think that this particular file is just whacked - but interesting that QT can handle it correctly.  Curious.  Will take another video on Sunday.
Brad
Votes
Translate
Translate
Report
Report
Community Expert ,
>Output from QT is also out of sync -snip- interesting that QT can handle it correctly
Ah... which is it... QT does it correctly, or not?
Votes
Translate
Translate
Report
Report
Guest
Sorry for the confusing comment.  QT always handles this correctly.  My thought was to output a file from QT (assuming that the original iPhone file had something weird in it) and then try it in Premiere.  However, the QT output, while it still played correctly in QT, was out of sync when viewed in the source window or sequence of Premiere.
I guess the only question left is:  Can a long video taken with the iPhone 4S play correctly and be edited in Premiere without sync problems?  If so, I have a unique, single file problem.  I will take another long file on Sunday and try it again.
Brad
Votes
Translate
Translate
Report
Report
LEGEND ,
Brad,
Am I correct that the iPhone footage has a variable FPS, or am I confusing another poster's issue?
If it does, converting it to a static FPS should take care of things.
If I am confused, please disregard the above comments.
Votes
Translate
Translate
Report
Report
Engaged ,
Bill Hunt wrote:
Brad,
bill... not sure about the 4, but the 4s is not technically a variable framerate.... but it is. say i shoot 10 videos.... some may be 24fps, others 30, and others 15. the specs on the phone say UP TO 30, and with my experience it has been 24fps 7 out of 10 times (not exactly.... but just saying it seems like). 2 of 10 times 30, and every blue moon a 15. i have not recorded a long butt video myself.... all the ones i've done were a few minutes long and by doing the "drag to new project," never had an OOS problem.... i may experiment with this though.....
Votes
Translate
Translate
Report
Report
Engaged ,
demon_hunter83 wrote:
Bill Hunt wrote:
Brad,
nevermind.... i'll be darned! it is variable frame rate! lol heres what media info says....
General
Complete name                   : G:\crap\IMG_0216.MOV
Format                           : MPEG-4
Format profile                   : QuickTime
Codec ID                         : qt
File size                        : 197 MiB
Duration                         : 1mn 8s
Overall bit rate                 : 24.2 Mbps
Recorded date                    : 2011-10-29T21:51:53-0400
Encoded date                     : UTC 2011-10-30 01:51:53
Tagged date                      : UTC 2011-10-30 01:52:05
Writing application              : 5.0
Writing library                  : Apple QuickTime
Model                            : iPhone 4S
Make                             : Apple
com.apple.quicktime.make         : Apple
com.apple.quicktime.creationdate : 2011-10-29T21:51:53-0400
com.apple.quicktime.software     : 5.0
com.apple.quicktime.model        : iPhone 4S
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : Baseline@L4.1
Format settings, CABAC           : No
Format settings, ReFrames        : 1 frame
Format settings, GOP             : M=1, N=30
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1mn 8s
Bit rate                         : 24.1 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate mode                  : Variable
Frame rate                       : 29.970 fps
Minimum frame rate               : 28.571 fps
Maximum frame rate               : 31.579 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.388
Stream size                      : 196 MiB (100%)
Title                            : Core Media Video
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Material_Duration                : 68235
Material_StreamSize              : 205789884
Material_FrameCount              : 2045
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format profile                   : LC
Codec ID                         : 40
Duration                         : 1mn 8s
Bit rate mode                    : Constant
Bit rate                         : 64.0 Kbps
Channel(s)                       : 1 channel
Channel positions                : Front: C
Sampling rate                    : 44.1 KHz
Compression mode                 : Lossy
Stream size                      : 523 KiB (0%)
Title                            : Core Media Audio
Material_Duration                : 68243
Material_StreamSize              : 535291
eta: but notice the bit-rate. sheesh!
Votes
Translate
Translate
Report
Report
LEGEND ,
I do not know the specs. on the iPhone 4S, so cannot comment directly, but think that the OP had also posted to the PrE Forum, by mistake, and in that thread, had mentioned that the footage had a variable FPS. I'll see if I can find that post, so we can see what the OP (or maybe it was another 4S user?) discovered.
Votes
Translate
Translate
Report
Report
Engaged ,
i corrected myself due to ignorance. refer to earlier post. my bad
Votes
Translate
Translate
Report
Report
Advocate ,
I know Adobe was working on making the D7000 .mov files play smoothly in Premire and the temporary fix was to rename to .mpg thus not using the Quicktime engine.
Try that to see if it makes a difference.
GLenn
Votes
Translate
Translate
Report
Report
Contributor ,
Most phones use a MPEG codec so changing the file extension to .mpg might work. I have to do that with my Canon FS 200 but my phone's (HTC Thunderbolt) video files work fine. Go figure.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 26, 2012 Jul 26, 2012
Changing the extension to .mpg works for me as a workaround.  I'm not sure who I'm more upset with, Apple or Premiere.  Apple has a history of making things more difficult than they have to be, and Premiere has a reputation to uphold...
Votes
Translate
Translate
Report
Report
Aug 22, 2013 Aug 22, 2013
I tried changing the extension, and I'm still having sync issues. I'm resorting to using video converter software. The weird thing is, Adobe Premiere Elements works like a charm with iPhone footage. How can it's Pro big brother not handle it?
Votes
Translate
Translate
Report
Report
Aug 23, 2013 Aug 23, 2013
Hey Michael,
Did you try handbrake yet?  I did this fix a while back:
http://www.youtube.com/watch?v=vUo2j_ibpNM
Cheers!
John Noah P
Votes
Translate
Translate
Report
Report
Jul 13, 2014 Jul 13, 2014
Simply changing the extension to .mpg worked for me, using both iPhone 4 and 4s footage that had out of sync issues. Be sure to properly change the extension rather than just adding ".mpg" on the end of the file name (on a PC with Windows 7 while viewing the folder in explorer you need to choose Tools - Folder options - View and then uncheck hide extensions).
Votes
Translate
Translate
Report
Report
New Here ,
Oct 27, 2015 Oct 27, 2015
that totally worked for me!!! what a ridiculous solution ... thank you!!!
Votes
Translate
Translate
Report
Report
