kategorgeous
Need some Help with CFUPDATE into MySQL
Dec 8, 2011 2:29 PM
Hi
I am trying to update a MySQL database with a Coldfusion Form which has brought in the information from another form.  The Form action for the update form is as follows:
<form action="update_sup.cfm?GID=#qsupname.SupplierCode#" method="post">
This bit seems to work in so far as it generates a URL that includes the Supplier Code:
www.website.com/update_sup.cfm?GID=193BA3BE-C09F-087E-DACCEE9702D6C5C1
But the SQL query doesn't actually update:
SQL Queries
  CFUPDATE (Datasource=kw5336, Time=0ms, Records=0) in /website/update_sup.cfm @ 22:27:00.000
update Suppliers set SupplierName=?,SalesRepName=?,SalesRepPhone=?,Address1=?,Address2=?,Notes=? where SupplierCode=?
The Form Fields in the Debug show the changes:
Form Fields:
FIELDNAMES=SUPCODE,SUPNAME,SUPADDR1,SUPADDR2,SUPCITY,SUPPCODE,SUPPTERM S,SUPREPNAME,SUPREPPHONE,SUPREPEMAIL,SUPNOTES
SUPADDR1=Unit 55 Portland Drive
SUPADDR2=Kiln Farm
SUPCITY=Milton Keynes
SUPCODE=193BA3BE-C09F-087E-DACCEE9702D6C5C1
SUPNAME=SupplierF
SUPNOTES=
SUPPCODE=MK17 2RB
SUPPTERMS=30
SUPREPEMAIL=p.argent@supplierf.co.uk
SUPREPNAME=Paul Argenta
SUPREPPHONE=01555 123456
What have I missed??
    Dec 8, 2011 3:10 PM   in reply to kategorgeous
    Look at the parameters passed to your database.  It's possible that you are only using the part of the GID up to the first hyphen.  If so, you can urlencode the variable or send it as a hidden form field instead.  I'd do the latter myself because I don't like having both url and form variables to deal with.
    Dec 8, 2011 3:30 PM   in reply to Dan Bracuk
    SUPCODE, ..., SUPPCODE
    There are also two fields with very similar names. Is it possible the query is mixing them up?
  • Dave Watts
    Mar 11, 2003
    Dec 8, 2011 3:41 PM   in reply to kategorgeous
    Are you sure it's not updating? I don't see any evidence of that from the example you posted. I don't think it shows a value for records updated in the debug output when you run an update.
    Dave Watts, CTO, Fig Leaf Software
    Dec 8, 2011 4:15 PM   in reply to Dave Watts
    I believe CF9 does display the number of records updated.  At least with a "regular" update.  But I agree that is not a very robust test.
