Latest Version of Air won't install on my MAC! Help!
Dec 10, 2011 12:28 PM
I have a Mac book pro running version 10.7.2.  I recently purchased Adobe CS5.5 Master Collection and proceeded to uninstal my previous version so that I could install the new one.
After downloading the 'demo' version and then trying to install it, I received an error message asking me to install the latest version of Air.  I downloaded the latest version of Air and everytime I try to run it...I get an error saying that Adobe Air needs the latest version of Adobe Air in order to proceed with installation.
What the??? This is insane!! I tried all the various troubleshooting suggestions including inserting code in Terminal but nothing works!!
Please...I'm a professional and need my CS5.5 running urgently!!
Thanks...
Charles
  • Chris Campbell
    May 4, 2010
    Dec 12, 2011 5:09 PM   in reply to Charles Dumont
    That is odd, but I'm glad you got it fixed.  Feel free to post back anytime if you run into problems in the future.
    Chris
    Dec 12, 2011 5:22 PM   in reply to Charles Dumont
    I tried this but it didn't work.  I'm getting
    This application requires a version of Adobe AIR which cannot be found.
    Please download the latest version of the runtime from
    http://www.adobe.com/go/getair,
    or contact the application author for an updated version.
    I uninstalled my downloaded version of master suit after the trail was over.  I'm looking to use other programs that use this and I've tried everything that people have offered as advice.  STILL the same error message.
    Help!  I need need need to order photos using another program that uses this and I can't do it!
  • Chris Campbell
    May 4, 2010
    Dec 12, 2011 5:29 PM   in reply to savrine1
    I'm sorry you're running into installation issues with AIR.  Microsoft has released a new utility that can help resolve installation problems.  Would you mind giving this a try and let us know how it works for you?  When running the Fix it, go through the uninstall process and try to remove Adobe AIR from your system.  Once finished, download the latest version of AIR and install again.
    Microsoft Install and Uninstall Fix It
    If you still encounter problems, we'll need to review the AIR installer log to better diagnose the issue.  Please post back with the log contents.  You can find instructions for finding these logs here:
    AIR Installer Log Instructions
    Chris
    Dec 12, 2011 5:32 PM   in reply to Chris Campbell
    Sorry, I have a mac.  I don't think that will work for me.
  • Chris Campbell
    May 4, 2010
    Dec 12, 2011 5:38 PM   in reply to savrine1
    Oops, sorry about that.  Let's try this.  Go to /Library/Frameworks/ and delete the Adobe AIR.framework folder.  Once that's gone, try reinstalling the runtime from the .dmg and then give the .air file another go.
    Chris
    Dec 13, 2011 12:28 PM   in reply to Chris Campbell
    I did this. Still problems. I can download it just not install it because it says it need a newer version of AIR to run. I'm trying to install the newer version of AIR.
    Help,
    Rebecca
  • Chris Campbell
    May 4, 2010
    Dec 13, 2011 2:59 PM   in reply to savrine1
    The AIR runtime installer is complaining that it needs a newer version to run?  Can you post your AIR installer log so I can take a look at what it's hanging up on?  Here are the instructions:
    Installer log output: Mac
    Chris
    Dec 13, 2011 9:44 PM   in reply to Charles Dumont
    Ok I had the EXACT same problem you did!  I was using Safari and it was telling me it couldn't install the Adobe Download Assistant because it needed Adobe Air, but when I tried to download Air, it gave me that message too.  But I just downloaded Firefox and it worked just fine downloading Photoshop from there.  I'm not sure what the deal is, but at least it's working now.
    Dec 14, 2011 8:45 AM   in reply to Charles Dumont
    I am having the same issue installing air.  I am running Mac OS 10.7.2 on a Macbook trying to install Air ver 3.1.0.4880.  Following is the syslog and crash report outputs.  Any help is appreciated.
    Dec 14 10:29:41 MacBook-Pro Adobe AIR Installer[4603]: Runtime Installer begin with version 3.1.0.4880 on Mac OS 10.7.2 x86
    Dec 14 10:29:41 MacBook-Pro Adobe AIR Installer[4603]: Commandline is: -psn_0_1122578
    Dec 14 10:29:41 MacBook-Pro Adobe AIR Installer[4603]: No installed runtime detected
    Dec 14 10:29:43 MacBook-Pro com.apple.launchd.peruser.501[120] ([0x0-0x112112].com.adobe.air.Installer[4603]): Job appears to have crashed: Segmentation fault: 11
    Dec 14 10:29:43 MacBook-Pro ReportCrash[4607]: Saved crash report for Adobe AIR Installer[4603] version 3.1 (3.1.0.4880) to /Users/BobOwens/Library/Logs/DiagnosticReports/Adobe AIR Installer_2011-12-14-102943_Bob-Owenss-MacBook-Pro.crash
    Here is the crash report:
    Process:         Adobe AIR Installer [4603]
    Path:            /Volumes/VOLUME/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
    Identifier:      com.adobe.air.Installer
    Version:         3.1 (3.1.0.4880)
    Code Type:       X86 (Native)
    Parent Process:  launchd [120]
    Date/Time:       2011-12-14 10:29:42.413 -0600
    OS Version:      Mac OS X 10.7.2 (11C74)
    Report Version:  9
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000a0000020
    VM Regions Near 0xa0000020:
        __LINKEDIT             000000008feb5000-000000008fec8000 [   76K] r--/rwx SM=COW  /usr/lib/dyld
    --> Submap                 0000000090000000-00000000ac000000          r--/rwx machine-wide submap
        mapped file            0000000090000000-0000000090005000 [   20K] r-x/r-x SM=COW  Object_id=dac2260
    Application Specific Information:
    objc_msgSend() selector name: backingScaleFactor
    objc[4603]: garbage collection is OFF
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   libobjc.A.dylib                         0x9448ae87 objc_msgSend_fpret + 23
    1   com.apple.AppKit                        0x98a7127a -[NSWindow _setFrame:updateBorderViewSize:] + 1223
    2   com.apple.AppKit                        0x98a70915 -[NSWindow _oldPlaceWindow:] + 630
    3   com.apple.AppKit                        0x98a1a514 -[NSWindow _setFrameCommon:display:stashSize:] + 1657
    4   com.apple.AppKit                        0x98a19e96 -[NSWindow setFrame:display:] + 71
    5   com.adobe.AIR                           0x03353948 0x2f55000 + 4188488
    6   com.adobe.AIR                           0x034a474c 0x2f55000 + 5568332
    7   com.adobe.AIR                           0x0346541b 0x2f55000 + 5309467
    8   com.adobe.AIR                           0x03620266 0x2f55000 + 7123558
    9   com.adobe.AIR                           0x03621db9 0x2f55000 + 7130553
    10  com.adobe.AIR                           0x03625eb7 0x2f55000 + 7147191
    11  com.adobe.AIR                           0x0365200d 0x2f55000 + 7327757
    12  com.adobe.AIR                           0x036be21c 0x2f55000 + 7770652
    13  com.adobe.AIR                           0x033425a8 0x2f55000 + 4117928
    14  com.adobe.AIR                           0x03343be5 0x2f55000 + 4123621
    15  com.adobe.AIR                           0x03640c69 0x2f55000 + 7257193
    16  com.adobe.AIR                           0x037248cc FREGetObjectAsInt32 + 176322
    17  com.apple.CoreFoundation                0x99ee7091 -[NSObject performSelector:withObject:] + 65
    18  com.apple.Foundation                    0x9bdc6f64 __NSThreadPerformPerform + 503
    19  com.apple.CoreFoundation                0x99e5e84f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
    20  com.apple.CoreFoundation                0x99e5e206 __CFRunLoopDoSources0 + 246
    21  com.apple.CoreFoundation                0x99e880d8 __CFRunLoopRun + 1112
    22  com.apple.CoreFoundation                0x99e878ec CFRunLoopRunSpecific + 332
    23  com.apple.CoreFoundation                0x99e87798 CFRunLoopRunInMode + 120
    24  com.apple.HIToolbox                     0x94f1ba7f RunCurrentEventLoopInMode + 318
    25  com.apple.HIToolbox                     0x94f22d9b ReceiveNextEventCommon + 381
    26  com.apple.HIToolbox                     0x94f22c0a BlockUntilNextEventMatchingListInMode + 88
    27  com.apple.AppKit                        0x98916040 _DPSNextEvent + 678
    28  com.apple.AppKit                        0x989158ab -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 113
    29  com.apple.AppKit                        0x98911c22 -[NSApplication run] + 911
    30  com.adobe.AIR                           0x02f5d8ea 0x2f55000 + 35050
    31  com.adobe.AIR                           0x02f5db10 0x2f55000 + 35600
    32  com.apple.CoreFoundation                0x99ee7091 -[NSObject performSelector:withObject:] + 65
    33  com.adobe.air.Installer                 0x00002eb7 RuntimeAppMain(char const*, int) + 371
    34  com.adobe.air.Installer                 0x00002ff4 main + 60
    35  com.adobe.air.Installer                 0x000024d2 start + 54
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib                  0x9318990a kevent + 10
    1   libdispatch.dylib                       0x9c968c58 _dispatch_mgr_invoke + 969
    2   libdispatch.dylib                       0x9c9676a7 _dispatch_mgr_thread + 53
    Thread 2:
    0   libsystem_kernel.dylib                  0x9318902e __workq_kernreturn + 10
    1   libsystem_c.dylib                       0x9bb4eccf _pthread_wqthread + 773
    2   libsystem_c.dylib                       0x9bb506fe start_wqthread + 30
    Thread 3:
    Thread 4:
    0   libsystem_kernel.dylib                  0x9318883e __psynch_cvwait + 10
    1   libsystem_c.dylib                       0x9bb50e21 _pthread_cond_wait + 827
    2   libsystem_c.dylib                       0x9bb0142c pthread_cond_wait$UNIX2003 + 71
    3   com.adobe.AIR                           0x034cba99 0x2f55000 + 5728921
    4   com.adobe.AIR                           0x0330a000 0x2f55000 + 3887104
    5   com.adobe.AIR                           0x034cbb69 0x2f55000 + 5729129
    6   com.adobe.AIR                           0x034cbbe3 0x2f55000 + 5729251
    7   com.adobe.AIR                           0x034cbc7e 0x2f55000 + 5729406
    8   libsystem_c.dylib                       0x9bb4ced9 _pthread_start + 335
    9   libsystem_c.dylib                       0x9bb506de thread_start + 34
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:
    2   libsystem_c.dylib                       0x9bb013e0 pthread_cond_timedwait$UNIX2003 + 70
    3   com.adobe.AIR                           0x034cbac5 0x2f55000 + 5728965
    4   com.adobe.AIR                           0x0350b28a 0x2f55000 + 5989002
    Thread 9:
    Thread 10:
    3   com.adobe.AIR                           0x03346128 0x2f55000 + 4133160
    4   com.adobe.AIR                           0x03343d96 0x2f55000 + 4124054
    5   com.adobe.AIR                           0x033446ce 0x2f55000 + 4126414
    6   com.adobe.AIR                           0x033446fb 0x2f55000 + 4126459
    7   com.adobe.AIR                           0x034cbb69 0x2f55000 + 5729129
    8   com.adobe.AIR                           0x034cbbe3 0x2f55000 + 5729251
    9   com.adobe.AIR                           0x034cbc7e 0x2f55000 + 5729406
    10  libsystem_c.dylib                       0x9bb4ced9 _pthread_start + 335
    11  libsystem_c.dylib                       0x9bb506de thread_start + 34
    Thread 0 crashed with X86 Thread State (32-bit):
      eax: 0x00397c50  ebx: 0x0019f180  ecx: 0x9933090c  edx: 0xa0000000
      edi: 0x00390f50  esi: 0x98a70dc1  ebp: 0xbfffdb98  esp: 0xbfffdb28
       ss: 0x00000023  efl: 0x00010206  eip: 0x9448ae87   cs: 0x0000001b
       ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
      cr2: 0xa0000020
    Logical CPU: 2
    Binary Images:
        0x1000 -     0x6ff7 +com.adobe.air.Installer (3.1 - 3.1.0.4880) <B215D2E3-E498-D23B-CD5E-C6FAD3B39C7E> /Volumes/VOLUME/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
      0x700000 -   0x7adff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
    0x2d23000 -  0x2d5cff3  com.apple.QuickTimeFireWireDV.component (7.7.1 - 2306) <5347333C-9175-39FF-AFEC-BF24BB6701D7> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacO S/QuickTimeFireWireDV
    0x2d67000 -  0x2d71fff  com.apple.IOFWDVComponents (2.0.7 - 2.0.7) <811CF4D6-15B2-3EDA-B026-5E4B28C0F742> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/ IOFWDVComponents
    0x2d7c000 -  0x2d80ffb  com.apple.audio.AudioIPCPlugIn (1.2.1 - 1.2.1) <B8333059-00BE-33A6-AEC0-0C8F285E6E07> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    0x2f55000 -  0x406bfc7 +com.adobe.AIR (??? - 3.1.0.4880) <AB2E4804-CA8F-B8C0-AE11-B52400555F22> /Volumes/VOLUME/Adobe AIR Installer.app/Contents/Frameworks/Adobe AIR.framework/Versions/1.0/Adobe AIR
    0x5364000 -  0x538cfff  com.apple.QuickTimeIIDCDigitizer (7.7.1 - 2306) <6F887F4E-2D83-3415-9342-7EA8600E1349> /System/Library/QuickTime/QuickTimeIIDCDigitizer.component/Contents/M acOS/QuickTimeIIDCDigitizer
    0x5394000 -  0x53e2ff7  com.apple.QuickTimeUSBVDCDigitizer (2.7.1 - 2.7.1) <1D79F9C3-E0F4-33AE-A390-38DD884DEA28> /System/Library/QuickTime/QuickTimeUSBVDCDigitizer.component/Contents /MacOS/QuickTimeUSBVDCDigitizer
    0x53ec000 -  0x53f2ffb  com.apple.audio.AppleHDAHALPlugIn (2.1.3 - 2.1.3f7) <C2DD672D-46CE-34BB-8456-129C65DDE583> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    0x5515000 -  0x5682ffc  GLEngine (??? - ???) <C49CCDEA-F23E-30CD-9BCD-FC09C9D07CF4> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
    0x56b6000 -  0x57adffb  libGLProgrammability.dylib (??? - ???) <8E592FEB-B6A8-3BFF-828B-B37B05D4D574> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
    0x8f7c000 -  0x921cfe7  com.apple.ATIRadeonX3000GLDriver (7.14.5 - 7.1.4) <BA35443F-847C-344D-80C1-B9EC528B89C9> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/Mac OS/ATIRadeonX3000GLDriver
    0x924d000 -  0x95e3fff  com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.14.5 - 7.1.4) <3085DB78-3E8E-3570-B235-3ED8F1E712B3> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Co ntents/MacOS/AppleIntelHD3000GraphicsGLDriver
    0x97a1000 -  0x97ceff8  GLRendererFloat (??? - ???) <1264885F-1492-3591-BFB1-B671A7B08A29> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
    0x8fe57000 - 0x8fe899c7  dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
    0x90005000 - 0x90015ff7  libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
    0x90018000 - 0x90037fff  com.apple.RemoteViewServices (1.2 - 39) <C7B638D2-2F8B-3A45-916A-73103FADC822> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
    0x90038000 - 0x90043ff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <11726E50-E6FC-3AB0-8750-DDDCCF2B8534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x90044000 - 0x900aeff3  com.apple.CoreSymbolication (2.1 - 67) <38FD2396-C987-3E7F-93EF-7D8ECAF542AF> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
    0x900b0000 - 0x900b4ff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
    0x900b5000 - 0x900b9fff  libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x900ba000 - 0x9010afff  libFontRegistry.dylib (??? - ???) <81E03B82-1F31-3702-97DC-BE20298E326F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x901a5000 - 0x901c1ff5  com.apple.GenerationalStorage (1.0 - 125) <F1D67293-9192-367D-AE74-2732B23E7E77> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
    0x901c2000 - 0x90202ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
    0x90203000 - 0x90f53fff  com.apple.QuickTimeComponents.component (7.7.1 - 2306) <B397F658-057A-3D84-ABC7-84AA6256DB88> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacO S/QuickTimeComponents
    0x90f8b000 - 0x90fb3ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
    0x90fb4000 - 0x90ffbfff  com.apple.SystemConfiguration (1.11.1 - 1.11) <CA6CE2B6-DC18-31FF-9668-70BB2FD8D7BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
    0x90ffc000 - 0x9106bfff  com.apple.Heimdal (2.1 - 2.0) <DE626683-DF32-341B-8997-AE63309590C7> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
    0x9106c000 - 0x9131eff7  com.apple.security (7.0 - 55010) <BE0350C5-5221-3BFF-B674-646AB1BA0F2E> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x9136b000 - 0x9136bfff  com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x9136c000 - 0x9136cff0  com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
    0x91391000 - 0x91397ffb  com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
    0x91398000 - 0x913a6fff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
    0x91465000 - 0x91479ff7  com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x9147a000 - 0x91504ffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
    0x91505000 - 0x91553ff3  com.apple.ImageCaptureCore (3.0.1 - 3.0.1) <DB40F137-4519-339B-81DC-7375B2FE8FD2> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
    0x91554000 - 0x915c9fff  com.apple.Metadata (10.7.0 - 627.20) <1E7C8194-8CE4-3103-A3D1-8913238AF923> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
    0x915ca000 - 0x915cfffd  libGFXShared.dylib (??? - ???) <820D744C-C641-3918-A72A-AC2E5276BCB6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
    0x91be5000 - 0x91bf0ffe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
    0x91bf1000 - 0x91bf9fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
    0x91bfa000 - 0x91ffcff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    0x91ffd000 - 0x921b1ff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
    0x921b2000 - 0x921ccfff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x921f3000 - 0x92280fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
    0x92281000 - 0x92315ff7  com.apple.LaunchServices (480.21 - 480.21) <E3621817-B627-3EEC-A7F9-0D45583B7FE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
    0x92316000 - 0x923edffb  com.apple.avfoundation (2.0 - 180.30) <6788562E-A9A8-3898-A0F4-66D9BBAE3430> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFounda tion
    0x923ee000 - 0x9240bfff  libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <95AE43ED-6C52-3B39-89B6-54C81C62F1FF> /usr/lib/libresolv.9.dylib
    0x9240c000 - 0x92414ff3  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
    0x92426000 - 0x9243bfff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x9243c000 - 0x92445ffb  com.apple.DisplayServicesFW (2.5.2 - 317) <DF4FCE9C-A4EE-3590-B079-495AC83836EA> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
    0x92bf0000 - 0x92bf1ff5  libremovefile.dylib (21.0.0 - compatibility 1.0.0) <9A1E12B7-F822-3544-8E1D-A6DC81E1F2E6> /usr/lib/system/libremovefile.dylib
    0x92c18000 - 0x92c9ffff  com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
    0x92d2a000 - 0x92d66fff  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <AA56493C-D7C6-3D4F-8DC8-855405AFF57B> /usr/lib/libcups.2.dylib
    0x92d67000 - 0x9315afeb  com.apple.VideoToolbox (1.0 - 705.42) <3F12F8A3-ED41-3EAD-A887-B7805353122C> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
    0x9315b000 - 0x9315bfff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
    0x9315c000 - 0x9316fffb  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <3D94520B-C976-370F-AF56-278002BCF11D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
    0x93170000 - 0x9318eff7  libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
    0x9318f000 - 0x93414fe3  com.apple.QuickTime (7.7.1 - 2306) <F8C64DC4-3FE4-3A06-B10B-59E7F3BA6FDD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x93415000 - 0x9346effb  com.apple.coreui (1.2.1 - 164.1) <890E0BE9-3360-3B56-BE46-5A2421875A40> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x9348c000 - 0x9348eff9  com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
    0x9351d000 - 0x93649ff9  com.apple.CFNetwork (520.2.5 - 520.2.5) <02193949-50A8-3CBC-9920-5FCDB8EBE17A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
    0x9364a000 - 0x9368bff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <975E4F25-7943-3785-849C-244FF4E77602> /usr/lib/libcurl.4.dylib
    0x9369b000 - 0x938e4ff7  com.apple.JavaScriptCore (7534.52 - 7534.52.7) <19E4C699-A9BA-3FCB-90CC-02C8F0607165> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
    0x938e5000 - 0x93a46ffb  com.apple.QuartzCore (1.7 - 270.0) <0916DA83-6400-3FEA-BC53-5F4BA4D126EC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x93a5f000 - 0x93a8afff  com.apple.GSS (2.1 - 2.0) <05A0171B-76EA-3E4C-8A36-65D1A978AF4B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x93a96000 - 0x93ae5ffb  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <71C9D388-E607-3DB4-9FD3-FC918EB4A835> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
    0x93ae6000 - 0x93aedff5  libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
    0x93aee000 - 0x93b10ffe  com.apple.framework.familycontrols (3.0 - 300) <F87D87EF-553A-3165-9C9A-6E117C537FE9> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
    0x93b56000 - 0x93b5aff7  com.apple.OpenDirectory (10.7 - 146) <3D3D30CE-6D82-3681-AA98-4E3AEFFA4229> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
    0x93bd4000 - 0x94049ff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
    0x9404a000 - 0x9412dff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
    0x9413a000 - 0x9429cfff  com.apple.QTKit (7.7.1 - 2306) <5A7E5ED0-C4DC-3CEC-ABE0-24899134ACE1> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x94433000 - 0x94483ff9  com.apple.QuickLookFramework (3.1 - 500.1) <28CB604E-2426-3491-BF16-2CDFD4C392B0> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
    0x94484000 - 0x9455aa5b  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <A0EDB351-4B9D-3AA2-9D1A-0C22204FCCD3> /usr/lib/libobjc.A.dylib
    0x9455b000 - 0x94580ff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x94581000 - 0x945e8fff  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
    0x945e9000 - 0x94613ff0  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib
    0x94614000 - 0x94617fff  com.apple.AppleSystemInfo (1.0 - 1) <D2F60873-ECB1-30A8-A02E-E772F969116E> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/ A/AppleSystemInfo
    0x94618000 - 0x94c93fe5  com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
    0x94c94000 - 0x94cf5ffb  com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <089D78E0-46A6-38DB-9545-7F35CC815939> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x94d18000 - 0x94d7dff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
    0x94d97000 - 0x94de7ff4  libTIFF.dylib (??? - ???) <E86EA22A-82C0-3E77-9EAF-739F385790D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x94e58000 - 0x94f18ff3  com.apple.ColorSync (4.7.0 - 4.7.0) <A39EA668-D042-377F-BC81-26748CD57ADC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    0x94f19000 - 0x95259ffb  com.apple.HIToolbox (1.8 - ???) <DFED9BD0-E142-397B-BE16-16EBCF3CE1EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
    0x9525a000 - 0x95264ff2  com.apple.audio.SoundManager (3.9.4 - 3.9.4) <D23C4761-6492-3974-B4D2-495082B8B7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Car bonSound.framework/Versions/A/CarbonSound
    0x95265000 - 0x9561fffb  com.apple.SceneKit (2.1 - 125.1) <7BFC0028-18AC-3B49-8DDC-CB7A7359D4F7> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/Scene Kit
    0x95651000 - 0x95656ff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
    0x956f6000 - 0x957eeff7  libFontParser.dylib (??? - ???) <83E7E71E-D217-3DEE-B288-F5BAE7E118C5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x95847000 - 0x958a4ffb  com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTM LRendering.framework/Versions/A/HTMLRendering
    0x958a5000 - 0x958d3fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <07D9A827-9567-34C2-9022-AF4BF975C9A7> /usr/lib/libSystem.B.dylib
    0x958d4000 - 0x958dcff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
    0x958dd000 - 0x958dfff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
    0x95961000 - 0x9599dffd  libGLImage.dylib (??? - ???) <8251242B-E04E-3467-BD0F-834578B18AC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
    0x9599e000 - 0x959dcfff  com.apple.NavigationServices (3.6 - 192) <CB7AE807-9292-3EBA-A5F5-D7DCEE28A5B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Nav igationServices.framework/Versions/A/NavigationServices
    0x95a0b000 - 0x95adafff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <8B8A3DD3-BB3D-33FC-A714-81E1B883B155> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
    0x95adb000 - 0x95adeffd  libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
    0x95bd7000 - 0x960b3ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
    0x960d9000 - 0x96199fff  com.apple.CoreServices.OSServices (478.29 - 478.29) <EAAAAC1B-2599-3875-9068-DF7E6B5760A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
    0x9619a000 - 0x961c8ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x96475000 - 0x964abff4  com.apple.LDAPFramework (3.0 - 120.1) <EA92FCA5-7A7E-328F-8C7F-4250FCC45879> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x964d5000 - 0x964fbffb  com.apple.quartzfilters (1.7.0 - 1.7.0) <9C8F1F3D-D570-3F5C-9B31-5B5B82161CDE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
    0x964fc000 - 0x96ba5eeb  com.apple.CoreGraphics (1.600.0 - ???) <322FC806-0B9F-3A58-8C88-D477E32A50F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x96ba6000 - 0x96c08ffb  com.apple.datadetectorscore (3.0 - 179.4) <12EF80E0-35CC-30A7-942F-2F9E87C4C98C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
    0x96c09000 - 0x96c0afff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
    0x96ce9000 - 0x96cffffe  libxpc.dylib (77.17.0 - compatibility 1.0.0) <E01E0074-0830-3F20-8703-EA7722BFD358> /usr/lib/system/libxpc.dylib
    0x96d00000 - 0x96e0fff7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <90D36793-04A5-3BFF-BE83-EEEDCBEDC756> /usr/lib/libsqlite3.dylib
    0x974ab000 - 0x9750bff3  com.apple.Symbolication (1.2 - 87) <2F9206D6-BE64-3C21-B593-43B8C60A7A9E> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
    0x9750c000 - 0x9760bffb  com.apple.DiskImagesFramework (10.7.2 - 331) <58D09F91-CC36-3CAD-9306-25BC8A5FD63E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/Dis kImages
    0x9760c000 - 0x97642ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
    0x97643000 - 0x9769bfff  com.apple.HIServices (1.10 - ???) <76B50B43-6CFD-3067-A085-11420FD4FAA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
    0x9769c000 - 0x978c5ffb  com.apple.QuartzComposer (5.0 - 236) <7BD138F0-C748-3013-98C0-4D5F5E10B9AB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
    0x978c6000 - 0x978cdff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
    0x978ce000 - 0x97a20fff  com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <7646E131-08EE-3D72-ADA2-4A61C562B36E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
    0x97a21000 - 0x97a22fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
    0x97a23000 - 0x97c42ff7  com.apple.imageKit (2.1.1 - 1.0) <9AF0A882-BEAD-3AEC-8A72-497A7C3C2358> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
    0x97c6b000 - 0x97ccffff  com.apple.framework.IOKit (2.0 - ???) <D14460ED-2B6C-375D-B3A4-B8C82E922666> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x97cd0000 - 0x97d04ff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
    0x97d05000 - 0x97d13fff  com.apple.opengl (1.7.5 - 1.7.5) <81166D23-DE8E-3938-AAD3-29B1FA5E446E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x97d14000 - 0x97d2bff8  com.apple.CoreMediaAuthoring (2.0 - 889) <49B55753-BD7E-3889-BA60-15294DA49CB7> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versio ns/A/CoreMediaAuthoring
    0x97d2c000 - 0x97d34ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
    0x97d37000 - 0x97d37ffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
    0x97f68000 - 0x97f85ff3  com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
    0x980e1000 - 0x980e8fff  com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x980e9000 - 0x980f2fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
    0x980f3000 - 0x98103fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x98104000 - 0x98142fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0AE59D4F-FFA7-3539-8B86-AD8993894AA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x98143000 - 0x98145ffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x98146000 - 0x983b9fff  com.apple.CoreImage (7.82 - 1.0.1) <6C99F458-E83A-3538-9B71-2C8BD0C9DCD5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
    0x983ba000 - 0x983bafff  com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x983bb000 - 0x983bcff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
    0x983bd000 - 0x98454ff3  com.apple.securityfoundation (5.0 - 55005) <F5A98CC2-11C6-34F3-8F72-75B642627630> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
    0x9848a000 - 0x9849bfff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
    0x9849c000 - 0x984c4ff0  com.apple.CoreServicesInternal (113.8 - 113.8) <9930695C-1C48-329F-93FD-5AEEE2EF942C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
    0x984c5000 - 0x98807fff  com.apple.MediaToolbox (1.0 - 705.42) <5AEFD5BE-6FA3-38F8-966A-B0AB56C472B8> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
    0x98808000 - 0x98809fff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
    0x98816000 - 0x98906ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
    0x9890c000 - 0x9939affe  com.apple.AppKit (6.7.2 - 1138.23) <ADFA8D70-601E-3B5C-96FD-F45F52055CC8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x9939b000 - 0x993defff  com.apple.MediaKit (11.0 - 585) <BD6A0B33-7048-3E71-864F-DFB5BC0FC640> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/Media Kit
    0x993df000 - 0x993dffff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
    0x996ef000 - 0x99708fff  libPng.dylib (??? - ???) <A83B66DC-302C-3A4C-8107-0E5560708024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x9987e000 - 0x9998fff7  libJP2.dylib (??? - ???) <35D120D4-3304-3A02-9259-EB933E74E63A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x99990000 - 0x99994ffd  IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x99995000 - 0x99996ff7  libsystem_sandbox.dylib (??? - ???) <BC0A04E9-4F28-3BC8-AA7B-63C3451E9212> /usr/lib/system/libsystem_sandbox.dylib
    0x99c47000 - 0x99c47fff  com.apple.quartzframework (1.5 - 1.5) <EF66BF08-620E-3D11-87D4-35D0B0CD1F6D> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x99c5e000 - 0x99cafff3  com.apple.CoreMediaIO (210.0 - 3180) <79AA7CA8-FC39-375D-9485-855D302DF7AA> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMedia IO
    0x99cce000 - 0x99cd7ff3  com.apple.CommonAuth (2.1 - 2.0) <D49B41B1-A5DD-366A-8C30-49E9B875AA13> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
    0x99cdc000 - 0x99d12fff  com.apple.DebugSymbols (2.1 - 85) <FAD78A3A-48DF-3D27-9726-1D31D3B889DA> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
    0x99d13000 - 0x99d42ff7  libsystem_info.dylib (??? - ???) <B86A363D-6EA2-3A69-A6CB-18B7F98FC61A> /usr/lib/system/libsystem_info.dylib
    0x99d43000 - 0x99d44ffd  libCVMSPluginSupport.dylib (??? - ???) <96F2F2F4-E7A9-36C8-B1CF-D58AA3DB2B44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
    0x99e4d000 - 0x9a023fe3  com.apple.CoreFoundation (6.7.1 - 635.15) <AC9F6462-6315-3D89-8075-D048DB4DBF7E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
    0x9a024000 - 0x9a09cff2  com.apple.CorePDF (3.0 - 3.0) <A0EC8F60-A622-347E-979A-F71939C45E5F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
    0x9a0f8000 - 0x9a0f9ffd  com.apple.MonitorPanelFramework (1.4.0 - 1.4.0) <45AC1CB9-2A81-3FEA-9BA4-E9BBA2582A28> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/M onitorPanel
    0x9a10b000 - 0x9a1ecfff  com.apple.DiscRecording (6.0 - 6000.4.1) <DA12E1A4-063B-3319-996B-AFF9B361561C> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRec ording
    0x9a6da000 - 0x9a6ddff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
    0x9a6de000 - 0x9a70bff7  com.apple.securityinterface (5.0 - 55004) <93C0285A-A266-3F21-82C9-434CBD3FA712> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
    0x9a70c000 - 0x9a71cfff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
    0x9a71d000 - 0x9aa1ffff  com.apple.CoreServices.CarbonCore (960.18 - 960.18) <8094724D-591D-3CC2-81DE-4E3029624E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
    0x9aa20000 - 0x9aa43fff  com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x9aa44000 - 0x9ab1aff6  com.apple.QuickLookUIFramework (3.1 - 500.1) <4E259D94-6081-32D7-AD60-565E57B11EBA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
    0x9ab1b000 - 0x9ab1effc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
    0x9ab25000 - 0x9ab26ff7  libquarantine.dylib (36.0.0 - compatibility 1.0.0) <70782AEC-8933-3EB4-91CA-E44C0E768C90> /usr/lib/system/libquarantine.dylib
    0x9ab46000 - 0x9ab51fff  libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
    0x9ab52000 - 0x9abcdffb  com.apple.ApplicationServices.ATS (317.5.0 - ???) <D5AC5C21-CE1E-333D-94F7-F0F534FD4DC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
    0x9acba000 - 0x9acc5ffc  com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
    0x9acd5000 - 0x9acd6fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
    0x9ace0000 - 0x9ad23ffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
    0x9ad24000 - 0x9ad24fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
    0x9ad25000 - 0x9adc9fff  com.apple.QD (3.12 - ???) <68CBE425-43BA-3E6D-8668-A4A67396E20D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
    0x9adca000 - 0x9adcdffb  com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
    0x9adce000 - 0x9addbfff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
    0x9ae32000 - 0x9ae38ffd  com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
    0x9ae39000 - 0x9aeb5ffd  com.apple.PDFKit (2.6.1 - 2.6.1) <7BC3186B-80B7-3E68-AFDD-2734164BCCFB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
    0x9af02000 - 0x9af2bffe  com.apple.opencl (1.50.63 - 1.50.63) <C4EC60D6-9A7C-3CE9-AA80-2F81D9BB4465> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x9af2c000 - 0x9af30fff  com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
    0x9af31000 - 0x9b040ffb  com.apple.DesktopServices (1.6.1 - 1.6.1) <9F02752A-617B-3AC7-BCA1-F040C105EDDE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
    0x9b041000 - 0x9b045ffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
    0x9b046000 - 0x9b097ff9  com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
    0x9baf0000 - 0x9bbbbfff  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
    0x9bbf3000 - 0x9bcdbfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
    0x9bd02000 - 0x9bd02ff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
    0x9bd03000 - 0x9bd65ff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
    0x9bd72000 - 0x9c07cff3  com.apple.Foundation (6.7.1 - 833.20) <B5092554-485A-3A7D-904B-B04B1EE5C50C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x9c07f000 - 0x9c10cff7  com.apple.CoreText (220.11.0 - ???) <4F98D709-75AC-35F0-AD88-8F2C4BD744C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
    0x9c148000 - 0x9c191ff7  libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
    0x9c192000 - 0x9c1d3ff7  com.apple.CoreMedia (1.0 - 705.42) <B45070F1-4097-3BAD-AA7C-0F7AFD6EAC27> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x9c1d4000 - 0x9c26fff3  com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
    0x9c270000 - 0x9c285ff7  com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
    0x9c286000 - 0x9c28dffd  com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x9c28e000 - 0x9c299ffb  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
    0x9c29a000 - 0x9c29afff  com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x9c2a1000 - 0x9c3c1fec  com.apple.vImage (5.1 - 5.1) <008B989F-F080-398E-ACB1-FBF5BA107D6D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
    0x9c511000 - 0x9c511fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x9c935000 - 0x9c957ff1  com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
    0x9c962000 - 0x9c965ff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
    0x9c966000 - 0x9c974fff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
    0x9c975000 - 0x9cb5eff7  com.apple.CoreData (104 - 358.12) <F8AD7990-2C30-31A4-8E78-FA8DD5CF03CC> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 2
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 4539
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=206.1M resident=138.5M(67%) swapped_out_or_unallocated=67.7M(33%)
    Writable regions: Total=145.1M written=7136K(5%) resident=9784K(7%) swapped_out=0K(0%) unallocated=135.6M(93%)
    REGION TYPE                      VIRTUAL
    ATS (font support)                 31.9M
    ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
    CG shared images                    168K
    CoreGraphics                          8K
    CoreServices                       1820K
    IOKit                               168K
    MALLOC                             78.3M
    MALLOC guard page                    32K
    Memory tag=240                     6148K
    Memory tag=242                       12K
    Memory tag=249                      156K
    Stack                              69.1M
    VM_ALLOCATE                        16.1M
    __CI_BITMAP                          80K
    __DATA                             12.1M
    __DATA/__OBJC                       288K
    __IMAGE                            1256K
    __IMPORT                              4K
    __LINKEDIT                         45.1M
    __OBJC                             2268K
    __OBJC/__DATA                        12K
    __PAGEZERO                            4K
    __TEXT                            161.0M
    __UNICODE                           544K
    mapped file                        87.5M
    shared memory                       312K
    shared pmap                        7108K
    TOTAL                             521.0M
    TOTAL, minus reserved VM space    521.0M
  • Chris Campbell
    May 4, 2010
    Dec 14, 2011 12:40 PM   in reply to bobo.rf.wi
    bobo,
    I apologize for the crash you're running into, could you try either of the two workarounds listed below?   Please let me know how it works out.
    • Open System Preferences, select Energy Saver and disable Automatic graphics switching (or use a third party GPU switcher, such as gfxCardStatus and enable the Nvidia GPU)
    • Before launching your AIR based application, launch either Google Chrome or Mozilla Firefox.
    Chris
    Dec 14, 2011 1:55 PM   in reply to Chris Campbell
    Chris - I disabled the Auto graphics switching and everything installed correctly.  Thanks a lot for your help.
    Dec 14, 2011 2:04 PM   in reply to Chris Campbell
    Fixed!  Thanks so much!  This was driving me CRAZY!
    Rebecca
    Dec 14, 2011 9:28 PM   in reply to Chris Campbell
    Thanks! I had the same issue as bobo (AIR 3.1, Mac OS X 10.7.2) and disabling automatic graphics switch did the trick.
    Dec 16, 2011 8:01 AM   in reply to Charles Dumont
    Now that is screwed up.  Simply having FireFox opened resolves the issue?
    Thanks.  This has been driving me batty ever since my PandoraOna app stopped working this morning.
    Dec 17, 2011 6:27 AM   in reply to Chris Campbell
    Had the same problem in installing AIR 3.1 on Mac OSX 10.7.2.
    The solution was to disable Automatic graphics switching.
    Question: Does AIR require auto graphics switching in order to run or may I re-enable it after successfully installing AIR?
    I run on a macbook pro and battery life is important to me, so I'm not looking forward to air not working properly w/o it. This also signficantly diminishes the desirability of AIR based applications.
    Mike
    Dec 18, 2011 6:23 AM   in reply to Chris Campbell
    chris.campbell,
    This is can affect any adobe app. and the bug fix should be prioritized appropriately.
    I was using Adobe Muse (public 5) for a client project. I tried using Muse offline and this seems to have caused AIR (installed Nov 6) to corrupt. I could not get Muse or AIR to install until I disabled Automatic graphics switching.
    Anyway, disabled Automatic graphics switching is a usable work around.
    Thanks.
    Jan 3, 2012 11:15 AM   in reply to nattie412
    I cannot believe in this!!!
    I spent last F O U R hours trying install adobe air after problems with an app. N O   S U C C E S S!!!
    I used Chrome. Than, after uncountable searches i found this discussion and decided to give this solution a try (but without hopes!). So i openes Firefox and magically this works! I can install AIR!!!
    Thanks a lot! Very thanks! I love you!!!
  • Chris Campbell
    May 4, 2010
    Jan 4, 2012 4:20 PM   in reply to AerendirITA
    I'm sorry you guys are effected by this bug.  I know it's a huge pain, and finding the solution is harder than it should be.  We're working to get the workaround more visibility and we're also working closely with Apple to resolve it as quickly as possible.
    Chris
    Jan 5, 2012 3:29 AM   in reply to Charles Dumont
    @Chris Campbell
    Thanks for your reply. I like (and i belive that it likes all others too) to receive a reply from Adobe
    I noticed that TweetDeck works well, while I have problems with Balsamiq Mockup and Creately.
    The thing is very strange: i have to open first TweetDeck, so i have to wait for some minutes and than i can open other AIR apps.
    If i open first Balsamiq or Creately i receive errors.
    If i open first TweetDeck and than Balsamiq or Creately WITHOUT wait some minutes, i receive errors.
    I discovered this writing this message.
    Infact i remember that yesterday i opened first TweetDeck and than other apps and all works well.
    Today i do the same procedure but the errors appeared.
    So i came to this forum, logged me in and started to write. When i opened again the apps to see the errors to post them here, the apps worked, so i think that i have to wait some minutes... and i don't understand why, obviously! o.O
    Anyway, if i'll receive errors again i'll post them here... Thanks for your support!
    Jan 6, 2012 12:12 PM   in reply to Martinator
    Wow,  that is pretty screwed up that after an hour of trying to resolve this issue I was able to work through it by simply having FireFox open.  That is a funky issue.  What up Adobe?
    Jan 6, 2012 4:55 PM   in reply to AerendirITA
    I have the same problem with my macbook pro. I read on a blog somewhere that if you turn off the automatic graphic switching in your system preferences/ energy saver section it will fix the problem. So I tried it and now it works fine
    Jan 28, 2012 2:58 PM   in reply to Chris Campbell
    I had, and fixed, the same problem on my MacBook with running AIR. Just wanted to know, can I now re-select the Automatic graphics switching in system preferences? Or will that cause a problem again?
    Many thanks.
    Brenda
    Jan 31, 2012 1:29 PM   in reply to AerendirITA
    I can't believe this is happening! I've been trying to get Balsamiq to install and run on my Mac OSX 10.6.8 for 3 hours!
    I get the same error messages as reported above. "Application requires a version of Adobe AIR which cannot be found..."
    I uninstalled Flash/Air/etc downloaded them and installed them again using both Firefox and Safari.
    I even downloaded and launched Tweekdeck in case that might work, Launched Firefox,
    and now registered with Adobe to be able to ask for your HELP!
    Mac OSX 10.6.8 does not have "automatic graphic switching" in Energy Saver pannel
    just automatically reducing brightness & dimming display, I tried switching them off.
    I don't know what else to try?  Any advice would be GRATELY appreciated!?
    Pretty Desperate!
    ilona
    Jan 31, 2012 2:06 PM   in reply to ilonaposner
    To help troubleshoot, which Mac model do you have? (Maybe your Mac doesn't have the ability to turn off automatic graphics switching).
    Jan 31, 2012 2:51 PM   in reply to Brenton.Elmore
    MacBook Pro 2.53 Ghz Intel Core 2Duo
    running Mac OSX 10.6.8
    FLASH Version 11.1.102.55
    Adobe AIR Installer  Version 3.1(3.1.0.4880)
  • Chris Campbell
    May 4, 2010
    Jan 31, 2012 6:25 PM   in reply to ilonaposner
    Are you receiving that error when you try and install Balsamiq or when you try and run it?
    Jan 31, 2012 8:18 PM   in reply to Chris Campbell
    When I try to RUN Balsamiq I get the following error:
    "Adobe AIR:
    This application requires a version of Adebe Air which cannot be found.
    Please download the latest version of the runtilme from http://www.adobe.com/go/getair,
    or contact the application author for an updated version. [OK]"
    I can run TweetDeck.app just fine?
    Any suggestions? Thank you!
    Jan 31, 2012 8:40 PM   in reply to ilonaposner
    JUST GOT IT WORKING!  Hurray!
    Tried another Uninstall of both AIR & Balsamiq. Then Emptied Trash Can. Then installed AIR again then Balsamiq and it just worked this time?
    Not sure which of the previous attempts helped this and If I still need to keep my Energy Saver settings off since
    Mac OSX 10.6.8 does not have "automatic graphic switching" in Energy Saver pannel, do I need to turn off
    just "automatically reducing brightness" & "dimming display" are they related to the Graphics Switching?
    THANK YOU for your help everyone!
    Apr 24, 2012 11:16 AM   in reply to Charles Dumont
    I'm having this issue, but I'm using Windows. Is there  a Windows equivalent to "turning off automatic graphics switching"? I'm attempting to install muse.
  • Chris Campbell
    May 4, 2010
    May 10, 2012 4:10 PM   in reply to jenrizzo
    jenrizzo - are you still crashing when running Muse?
