We would like to build an AIR app that plays Streaming H.264 Live/VOD videos that would work through AIR on the iOS platform.
I've seem some traffic on the forums that RTMP will work to iOS - but additionally heard that video applications that use RTMP streams will be rejected by the Apple App store.
I have seen that progressive H.264 will work - but that's not streaming or live.
HLS would work if we use the StageWebView object; however, that provides us little control/monitoring over the video inside of it; and it's not "really" integrated as a video player.
For OSMF there seems to be a 3rd-Party plugin which will allow OSMF to read HLS streams - but (from what I've heard) is incomplete because it doesn't play adaptive nor is it completely updated for OSMF 1.6.1.
I would love to be wrong here - but is there currently a way to play a Streamed H.264 Video to iOS that is non-RTMP?
I've seem little information as to if F4M streamed files played via OSMF will work on iOS.
Thanks for the info in advance.
-Will
Please see this http://forums.adobe.com/message/4081450#4081450
In short, you can play H264 video in ios using AIR as:
1. Progressive download
2. HLS format (OSMF 1.6.1 does not seem to be able to handle HLS, but if you use NetStream directly with StageVideo enabled it works)
Yeah - I came across that a while back.
There's no examples on how to get this to work; I've tried a netstream simple solution (null netconnect and treating it like a progressive mp4 / w stage video) and got nothing; I'll keep testing and post example code if I can get it to work.
It makes it a little more burdensome that OSMF doesn't support it; but if I can prove netstream can handle it then a OSMF plugin should be pretty straight forward to create for packaging. The video that as posted on that thread (by rossman) claimed that he was getting multibitrate - but he didn't mention how (HLS or RTMP) or any code that he used.
Since this is the only way that Adobe can deliver Live Video to iOS, and the AIR build to iOS debug cycle; I'd like to see if anyone has a working code sample that they can share.
Thanks.
-Will
I pasted a stripped down version of my test app below, that attempts to playback an m3u8 file. This works for me on an IPad2.
Remember to test on the device itself otherwise wont work.
Dependencies:
1. Air 3.1
2. OSMF 1.6.1
3. Flex SDK 4.6.0
renderMode="direct"
HTH
- Abey
xmlns:mx="library://ns.adobe.com/flex/mx"
backgroundAlpha="0"
backgroundColor="#000000"
addedToStage="onViewActivate(event)"
applicationDPI="160">
<fx:Script>
<![CDATA[
private var nc:NetConnection;
private var ns:NetStream;
private var video:Video;
private var currentVidUrl:String;
protected function onViewActivate(event:Event):void
nc = new NetConnection();
nc.addEventListener(NetStatusEvent.NET_STATUS, onNetStatus, false, 0, true);
nc.addEventListener(SecurityErrorEvent.SECURITY_ERROR, onSecurityErrorHandler, false, 0, true);
currentVidUrl = "http://fmsserver/hls-vod/sample.mp4.m3u8";
nc.connect(null);
private function onNetStatus(evt:NetStatusEvent):void
switch (evt.info.code) {
case "NetConnection.Connect.Success":
ns = new NetStream(nc);
var client:Object = {};
client.onMetaData = onMetaData;
client.onCuePoint = onCuePoint;
client.onBWDone = onBWDone();
ns.client = client;
nc.client = client;
var v:Vector.<StageVideo> = stage.stageVideos;
if (v.length >= 1) {
var stageVideo:StageVideo = v[0];
stageVideo.viewPort = new Rectangle(0, 0, mediaContainer.width, mediaContainer.height);
stageVideo.attachNetStream(ns);
else {
video = new Video();
video.width = mediaContainer.width;
video.height = mediaContainer.height;
mediaContainer.addChildAt(video,0);
video.attachNetStream(ns);
if (currentVidUrl) {
ns.play(currentVidUrl);
break;
case "NetStream.Publish.BadName":
break;
default:
break;
private function onSecurityErrorHandler(event:SecurityErrorEvent):void
protected function onMetaData(item:Object):void
protected function onCuePoint(item:Object):void
protected function onBWDone():void
</fx:Script>
<mx:UIComponent id="mediaContainer"
height="100%"
width="100%"/>
</s:Application>
I know this is a bit old, but I thought I would mention we have an app in the app store that utilizes RTMP live streaming.
I am having a heck of a time trying to make this example work within a Spark View. I believe that my first hurdle is to set renderMode to direct via the NativeWindowInitOptions, but I the stage doesn't contain a NativeWindow property. Also, the UIComponent is never instantiated, it is null. Is it possible to do this within a view? Can anyone point me in the right direction?
Cliff
North America
Asia Pacific
