Hi. When using a StreamingAMFChannel the clients http session expires dropping the connection. I use programmatically created multiple mx:Consumer instances. Session expirations occur after 900 seconds from consumer subscription. How can i solve it?
Hi, Rohit,
my services-config.xml
<?xml version="1.0" encoding="UTF-8"?>
<services-config>
<!-- <factories>-->
<!-- <factory id="SpringFactory" class="com.adobe.factories.MyFactory" /> -->
<!-- </factories> -->
<!-- <factories>-->
<!-- <factory id="spring" class="blazeds.spring.factory.SpringFactory"/>-->
<!-- </factories>-->
<services>
<service-include file-path="remoting-config.xml" />
<service-include file-path="proxy-config.xml" />
<service-include file-path="messaging-config.xml" />
<default-channels>
<channel ref="my-amf"/>
<!-- <channel ref="my-streaming-amf"/>-->
</default-channels>
</services>
<security>
<login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/>
<!-- Uncomment the correct app server
<login-command class="flex.messaging.security.TomcatLoginCommand" server="JBoss">
<login-command class="flex.messaging.security.JRunLoginCommand" server="JRun"/>
<login-command class="flex.messaging.security.WeblogicLoginCommand" server="Weblogic"/>
<login-command class="flex.messaging.security.WebSphereLoginCommand" server="WebSphere"/>
<security-constraint id="basic-read-access">
<auth-method>Basic</auth-method>
<roles>
<role>guests</role>
<role>accountants</role>
<role>employees</role>
<role>managers</role>
</roles>
</security-constraint>
</security>
<channels>
<channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
<endpoint url="http://{server.name}:{server.port}/{context.root}/spring/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
</channel-definition>
<channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
<endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
<properties>
<add-no-cache-headers>false</add-no-cache-headers>
</properties>
<channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
<endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
<properties>
<polling-enabled>true</polling-enabled>
<polling-interval-seconds>4</polling-interval-seconds>
</properties>
<channel-definition id="my-streaming-amf" class="mx.messaging.channels.StreamingAMFChannel">
<endpoint url="http://{server.name}:{server.port}/{context.root}/spring/messagebroker/stream ingamf" class="flex.messaging.endpoints.StreamingAMFEndpoint" />
<properties>
<idle-timeout-minutes>0</idle-timeout-minutes>
<max-streaming-clients>10</max-streaming-clients>
<server-to-client-heartbeat-millis>5000</server-to-client-heartbeat-m illis>
<user-agent-settings>
<user-agent match-on="MSIE" kickstart-bytes="2048" max-streaming-connections-per-session="3" />
<user-agent match-on="Firefox" kickstart-bytes="2048" max-streaming-connections-per-session="3" />
</user-agent-settings>
</properties>
<channel-definition id="my-http" class="mx.messaging.channels.HTTPChannel">
<endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/http" class="flex.messaging.endpoints.HTTPEndpoint"/>
<channel-definition id="my-secure-http" class="mx.messaging.channels.SecureHTTPChannel">
<endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/httpsecure" class="flex.messaging.endpoints.SecureHTTPEndpoint"/>
<properties>
</properties>
</channels>
<logging>
<target class="flex.messaging.log.ConsoleTarget" level="Error">
<properties>
<prefix>[BlazeDS] </prefix>
<includeDate>false</includeDate>
<includeTime>false</includeTime>
<includeLevel>false</includeLevel>
<includeCategory>false</includeCategory>
</properties>
<filters>
<pattern>Endpoint.*</pattern>
<pattern>Service.*</pattern>
<pattern>Configuration</pattern>
<pattern>Message.General</pattern>
</filters>
</target>
</logging>
<system>
<redeploy>
<enabled>false</enabled>
<watch-interval>20</watch-interval>
<watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-fi le>
<watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-fi le>
<watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-f ile>
<watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</w atch-file>
<touch-file>{context.root}/WEB-INF/web.xml</touch-file>
</redeploy>
</system>
</services-config>
Client code in .as
var consumer:Consumer;
consumer = new Consumer();
consumer.destination = destination;
consumer.addEventListener(MessageEvent.MESSAGE, onMsg);
consumer.addEventListener(MessageAckEvent.ACKNOWLEDGE, acknowledgeHandler);
consumer.addEventListener(MessageFaultEvent.FAULT, messageFaultHandler);
consumer.channelSet = streamingChannelSet;
mxml
| <mx:ChannelSet id="streamingChannelSet"> | |||
| <mx:StreamingAMFChannel url="{parentApplication.endPointRoot + '/spring/messagebroker/streamingamf'}"/> |
</mx:ChannelSet>
Also i create destinations in java this way:
MessageDestination destination = (MessageDestination)service
.createDestination(destinationName);
destination.setSource(destinationName);
ConfigMap accessConfig = new ConfigMap();
accessConfig.addProperty("use-mappings", "true");
accessConfig.addProperty("method-access-level", "remote");
ConfigMap serviceAdapterConfig = new ConfigMap();
serviceAdapterConfig.addProperty("access", accessConfig);
destination.addChannel("my-streaming-amf");
destination.addChannel("my-polling-amf");
destination.addChannel("my-amf");
destination.getServerSettings().setDurable(true);
destination.setAdapter(
new PublisherServiceAdapter(wellId, paramName)
destination.start();
private class PublisherServiceAdapter extends ServiceAdapter {
private String wellId;
private String paramName;
public PublisherServiceAdapter(String wellId, String paramName) {
super();
this.setId(UUIDUtils.createUUID());
this.wellId = wellId;
this.paramName = paramName;
@Override
public Object invoke(Message message) {
MessageService msgService = (MessageService)getDestination().getService();
msgService.pushMessageToClients(message, true);
msgService.sendPushMessageFromPeer(message, true);
return null;
@Override
public boolean handlesSubscriptions()
return true;
@Override
@SuppressWarnings("unchecked")
public Object manage(CommandMessage commandMessage){
if (commandMessage.getOperation() == CommandMessage.SUBSCRIBE_OPERATION) {
AcknowledgeMessage ackMessage = new AcknowledgeMessage();
Map<String, Object> paramData;// = wellOperdata.get(paramName);
if(wellsOperData.get(wellId) != null &&
(paramData = (Map<String, Object>)wellsOperData.get(wellId).get(paramName)) != null){
Map<String, Object> sendData = new HashMap<String, Object>();
sendData.putAll(paramData);
sendData.put("wellId", wellId);
sendData.put("paramName", paramName);
ackMessage.setBody(sendData);
return ackMessage;
else
return null;
North America
Asia Pacific
