Bogoljubow
mp4 export: much brighter than in PremierePro
Dec 13, 2011 4:54 PM
Tags: #export_settings
Hi
after export from Premiere Pro CS5 the material looks much brighter than it looks inside Premiere.
In Premiere: PAL; dv footage (in *.AVI container); interlaced. CC etc.; all fx rendered (green line in TL)
Export: h.264 / mpeg4; multi-pass; best render settings; deinterlaced
I tried different encoding settings and players.
I'm new to PP so I'm thankful for basic hints, like quality settings, render settings in PP regarding the output/export.
tia
I just found this article
http://forums.adobe.com/message/3695506#3695506
The pictures are looking like the problem i tried to describe. But... if i play the program in VLC - same problem.
(Now I skipped through the faq/help articles and some video tutorials, but this didn't solve the problem.)
    Dec 13, 2011 8:15 PM   in reply to Bogoljubow
    How does it look on a properly calibrated TV (not a computer monitor)?
    Dec 17, 2011 8:09 PM   in reply to Bogoljubow
    The problem is, you really need that calibrated external TV for proper color correction.  It's the only way to know you're seeing the image correctly.  Otherwise, the playback program, the video driver and even the operating system can interfere with the signal, and you just don't know what you're seeing.
