Hello:
I have seen this code in ultitouch gesture samples. But I don't kno how can I pass a bitmap parameter to the stateme
nt [Embed(source="imagenes/prueba.jpg")],
please, can you tell me how can I use this code with other bitmaps using parameters in this class?
Many thanks to all of you.
package
import flash.display.Bitmap;
import flash.display.Sprite;
import flash.events.TransformGestureEvent;
import flash.text.TextField;
import flash.text.TextFormat;
import flash.ui.Multitouch;
import flash.ui.MultitouchInputMode;
import flash.events.TouchEvent;
import flash.events.Event;
import flash.display.Stage;
[SWF(width=320, height=480, frameRate=60, backgroundColor=0x000000)]
public class GestureExample extends Sprite
public var ElephantImage:Class;
Not sure what you are asking what do you mean by
pass a bitmap parameter to the statement [Embed(source="imagenes/prueba.jpg")],
and
If you can clarify what you are trying to achieve we should be able to help
ok still not really sure what you're after but you can embed 2 images
[Embed(source="imagenes/image1.jpg")]
public var Image1:Class;
[Embed(source="imagenes/image2.jpg")]
public var Image2:Class;
and then
create the 2 images
var image1:Bitmap = new Image1();
var image2:Bitmap = new Image2();
if you want to do this within a class you cna define a constructor
public class Foo
public var image:Bitmap;
public function Foo(image1:Boolean):void
if (image1)
image = new Image1();
else
image = new Image2();
Thank you very much.
That code is wonderful but is not exactly what I'm trying to do.
If I have for example 100 images I don't want to put all in the class, but pass through a parameter,
When you click on a picture, i want to pass this to the function or Class to show the image clicked.
And I don't know how to do it with [Embed(source="............ How works Embed[ ?
Can I write this within the class file, for example?:
[Embed(source=myImageVar)]
And call it within my fla file something like this?
myImageVar="elephant.jpg";
Foo(myImageVar);
Many thanks
North America
Asia Pacific
