Using formCalc or JavaScript
Dec 19, 2011 4:56 AM
Good Day All;
I am now getting into forms that require some calculations. In doing some reading I have seen where both JavaScript and FormCalc are being used. Can anyone tell me which is the better to use?
For the form I am currently designing I have tried formCalc but I have hit a wee bump. I have ued the following “if(cost_p_h ne 0) thenSum(60/file_p_h) endif” and received the following error
Script failed (language is formcalc; context is xfa[0].form[0].form1[0].#subform[0].#subform[1].Table1[0].Row1[0].dur [0])
script=if(cost_p_h ne 0) thenSum(60/file_p_h) endif
   Error: syntax error near token 'thenSum' on line 1, column 25.
I am currently running Acrobat Pro 8 and the version of LiveCycle Designer is 8.05
Thanks All.
Chomp
    Dec 19, 2011 5:40 AM   in reply to The Chomp
    Hello Chomp,
    In your script you should give a space between then and Sum as follows:
    if(cost_p_h ne 0) then Sum(60/file_p_h) endif”
    Hope,this will help you.
    Debadas.
    Dec 19, 2011 6:32 AM   in reply to The Chomp
    Hello Chomp,
    You can not divide by zero, so you need to add code to only allow the division when you have a non-zero divisor.
    So for  this script Sum(60/file_p_h), you have check wheather file_p_h is non-zero.
    if(file_p_h ne 0) then Sum(60/file_p_h) endif
    Debadas.
    Dec 20, 2011 7:48 PM   in reply to The Chomp
    It is becuase if files in blank it counts that as not equal to 0 so does the calculation. try:
    if (files > 0) then
         Sum(60/files)
    else $ = ""
    endif
