• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
1
Push notifications... at last!
Explorer ,
Dec 21, 2011 Dec 21, 2011
For several weeks I have been working an ANE for iOS Push Notifications (APNS). I now have a beta with the following specs.
Methods:
registerForAPN( badges : Boolean = true, sounds : Boolean = true, alerts : Boolean = true, newsStandContent : Boolean = false ) : void;
unregisterForAPN() : void;
askForAPNtypes() : void;
setLocalBadge( badgeNumber : Number) : void;
Last method doesn't really have to do with APN, but was build in because you probably will need it.
All methods are void. For consistency all data is sent back through events.
Events:
REGISTERING - Just for debugging. Means registerForRemoteNotificationTypes was called.
REGISTERED - Means registration was successful. Returns deviceToken on event.deviceToken
FAILED - Means registration failed. Returns error string on event.info
UNREGISTERING - Just for debugging. Means unregisterForRemoteNotifications was called.
NOTIFICATION - Returns the payload of an APN as a string on event.info (not yet thoroughly tested, since I don't need it in my own implementation)
TYPES - Returns the currently registered APN-types as booleans on event.types.badges, event.types.sounds, event.types.alerts, event.types.newsStandContent.
Send me a PM with your e-mail address if you are interested in this ANE. Source code will not be released, just a ready-to-use ANE.
TOPICS
Development
Views
10.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner ,
Congratulations Anders!
If anyone is interested in my solution for APNs you can PM me too and you can give it a try here
http://flashsimulations.com/2011/12/16/apple-push-notification-service-native-extension-for-adobe-ai...
Votes
Translate
Translate
Report
Report
New Here ,
Jan 01, 2012 Jan 01, 2012
hi anders and piotr did your soultion works with flash builder windows version or it must be used in mac ???
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 02, 2012 Jan 02, 2012
Seems like you need to use Mac when building the IPA.
You still need Mac when submitting to iTunes though. (I run Mac with WMware in Windows)
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 10, 2012 Jan 10, 2012
My Adobe AIR app with push notifications has just been released on App Store:
http://itunes.apple.com/us/app/wordpox-premium/id481002756
Users are happy, and everything seems to work just great
Votes
Translate
Translate
Report
Report
New Here ,
Hi Anders!
can i ask you how to solve an issue on development of my APNS native extension?
In my native library, I'm working with [UIApplication sharedApplication] setDelegate:"my object" to delegate UIApplication dispatching events to "my object": but when i try to dispatch event with FREDispatchStatusEventAsync in method application:didRegisterForRemoteNotificationsWithDeviceToken the application crashes!
Can you help me please? if you want i can post my code!
Votes
Translate
Translate
Report
Report
New Here ,
Jan 11, 2012 Jan 11, 2012
I am also interested in using APNs with Flash Builder 4.6. I have been searching the web and have not found an answer, documentation or any tutorials on using APNs. I am using Flash Builder 4.6 and Windows 7.
If any one has any info please post links or some code.
Mike
Votes
Translate
Translate
Report
Report
New Here ,
hi mj93,
to compile your app you need mac os, with XCode environment.. in windows you can't.
I'm working on APNS extension, with some issue,  and when finished will post the code ..
seems that this thing of APNs is a taboo!
bye
Votes
Translate
Translate
Report
Report
Jan 12, 2012 Jan 12, 2012
Hey people
I try use this example. But for me make a error.
VerifyError: Error #1014: Class
pl.randori.air.nativeextensions.ios::APNSExtension could not be found.
at runtime::ContentPlayer/loadInitialContent()
at runtime::ContentPlayer/playRawContent()
at runtime::ContentPlayer/playContent()
at runtime::AppRunner/run()
at ADLAppEntry/run()
at global/runtime::ADLEntry()
I use flash CS5.5 and mac lion
I get the ANE rename for SWC include in the library.
Have some solution?
tanks
Bruno Brustoloni e Oliveira
Votes
Translate
Translate
Report
Report
Engaged ,
Congrats on getting it working.
Just wondering if you can answer a small question for me, related to one of the comments above.
I can't seem to get the delegate class to work consistently, once I set it, the rest of the extension interface back to the flash application seems to break.
So for example if as soon as I call
[[UIApplication sharedApplication] setDelegate:myDelegate];
Then any call to things like: FREDispatchStatusEventAsync fail and cause the app to crash.
Is this something to do with destroying some ANE default delegate class?
air native extensions // https://airnativeextensions.com
Votes
Translate
Translate
Report
Report
Jan 18, 2012 Jan 18, 2012
Hi anders-tbl,
Great that you got the Push notifications working... but I have some questions on it, it will be helpful if you can put up light that how you breakthrough them...
1. Does your implementation is able to give "aps" data to the app when app was not running in background and push notification comes to iPhone? if you can give a hint it will be helpful..
2. How did you overcome these "undefined selector" issues for " _stageLoaded" and " notifyASyncMessages"...
I too implemented the push notifications but for question 1 I get the aps data when app is running in background as "didFinishLaunchingWithOptions" never fires in native extension. and for question 2 it seems that these are internal engine methods which for now I have just over ridden with blank implentation to avoid crashes...
Nice if you can help..
Best Wishes,
Sanniv.
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 19, 2012 Jan 19, 2012
Hello sanniv_ios!
1. Yes, APNs are working even if the app isn't running.
2. I did not run into that problem when I created my ANE. I did run into several other problems though, which made me spend a silly amount of time developing it.
If you want to see it in action you can try the free version of my app:
http://itunes.apple.com/us/app/wordpox-free/id482879840?mt=8
Send a PM to me with your e-mail address if you would like my ANE-solution.
Votes
Translate
Translate
Report
Report
Engaged ,
We've ended up using an implementation that uses runtime method injection. Any other ios traditional method of using the setDelegate on the sharedApplication will result in the errors you're seeing sanniv_ios.
Basically you need to look into the class_addMethod functions.
If you do it any other way you'll break some of the flash application functionality.
Votes
Translate
Translate
Report
Report
Engaged ,
Jan 24, 2012 Jan 24, 2012
Actually sanniv_ios, I see you're problem.
The method injection works for any of the methods that are called while the app is running but the didFinishLaunchingWithOptions function seems to get called before the extension has been initialised.
Did you end up figuring out a way of getting the launch options without using this function? I can't find any other way of getting a notification passed in a application startup ...
Votes
Translate
Translate
Report
Report
New Here ,
Jan 25, 2012 Jan 25, 2012
Hello Anders,
I would like to have your comercial version of this ANE. Please, check MESSAGES.
Thanks a lot and congratulations.
Fernando
Votes
Translate
Translate
Report
Report
Explorer ,
May 25, 2012 May 25, 2012
hello and congratulation for you solution!
i'm intersted in the ane and/or a sample for flash as3 (commercial).
please contact me: painschen@web.de
Votes
Translate
Translate
Report
Report
Engaged ,
May 30, 2012 May 30, 2012
I'm interested in how to use this in Flash Professional too!
Votes
Translate
Translate
Report
Report
Explorer ,
I have discontinued the distribution of my extension for push notifications until further notice. One developer says the extension makes his app crash. I cannot confirm this, and at the moment I don't have the time to investigate it further.
Votes
Translate
Translate
Report
Report
New Here ,
May 31, 2012 May 31, 2012
Dear Anders,
Anyway thanks alot for your reply.
Regards,
Danh Le - Flash Developer
Tel: +84 907 506 614
http://danz-media.com/
Votes
Translate
Translate
Report
Report
Engaged ,
If you're still looking for a working APNS ANE we've released a package of ANE's that contains a fully working solution. We use it in all of our projects and it's being used in the development of several other developers applications. It's a cross platform solution as well, making use of C2DM on Android.
You can check it out here:
http://labs.distriqt.com/native-extensions/
Cheers,
Michael
Votes
Translate
Translate
Report
Report
New Here ,
Jun 04, 2012 Jun 04, 2012
HI I'm interesting in your apn air exteinsion.
Would you please send your ane let me to try?
Thanks a  lot.
My email is UNjerromy@gmail.com
Votes
Translate
Translate
Report
Report
New Here ,
Aug 07, 2012 Aug 07, 2012
Hello,
I am interested for the APN air extension.Would you please send me your ane ? Thanks a lot.
My emails is nishith_89@yahoo.com
Votes
Translate
Translate
Report
Report
New Here ,
Salve,
sono in ferie, rientro in azienda giorno 27/08/2012.
Prego di inoltrare le richieste al seguente indirizzo di posta: staff@eniac.it
oppure relativamente ad attività web: claudio.palazzolo@eniac.it, damiano.degan@eniac.it.
Distinti Saluti.
Spina Domenico.
Votes
Translate
Translate
Report
Report
Guest
Aug 14, 2012 Aug 14, 2012
Hi Anders,
I would like to use your ANE in my project. Could you please send a copy to my email fayaz.rvce@gmail.com
Votes
Translate
Translate
Report
Report
New Here ,
Salve,
Distinti Saluti.
Spina Domenico.
Votes
Translate
Translate
Report
Report
