Hi
I have a php/sql database that has thumb nails and videos in swf format and flv. On my html page I have an swf player. I have echoed
the thumbnails and have the url of the videos. How can I get the video url playing on the player after a person clicks the thumbnail with
out xml. Just by passing the url to the player. Kind of how youtube works thanks.
I have hand some sucess with xml passing but this can`t work in this aspect. So I have been investigating jquery and other alternatives.
Hope you can help.
Thanks.
Hi thanks for the reply.
Oh no. I have a folder Thumbnail and folder videos. I then have a phpmyadmin table called videos containing urls of the thumbnail and video.
On the html I echo the thumbnail of a particular video. the html contains a videoplayer with play, pause, stop menu. So I am trying to
use jquery to automaticly pass the url of the video into the videoplayer to play with out having to echo nessary xml maybe through
some actionscript that reads the passed url and plays the video.
I hope this makes sense thanks.
Thanks again for the reply.
so the videos are in two formats .flv and swf. So I can play an embedded swf video from the database but the video will play
with out controls play,pause or stop. It will just be a video embedded on the page. I created a separate player in flash cs5 that
has controls exported it as swf and embedded it on the page and know trying to pass the different video files from the datebase to be playable
with controls.
Thanks.
in your html, add the following to your javascript/jquery:
function thisMovie(movieName) {
if (navigator.appName.indexOf("Microsoft") != -1) {
return window[movieName];
} else {
return document[movieName];
function sendToActionScript(flv) {
thisMovie("put_your_embedded_swfs_name_here_without_the_dot_swf").sendToActionScript(flv);
// when you want to pass the url to flash use:
sendToActionScript("yourflvname.flv");
////////////// and in your embedded swf with the player use:
import flash.External.ExternalInterface;
ExternalInterface.addCallback("sendToActionScript", playFLV);
function playFLV(flv):Void{
yourflv_pb.contentPath=flv;
//do whatever else
Hi
Thanks so much for the assistance I have just got started getting the proposed solution working.
So in the swf players actionscript I have modified the code to:
//Action script
var flvSource:String = "yourflv_pb";
myVid.source=flvSource;
myVid.play();
myVid is the name of the player. I modified the code so that it plays the video is the code above correct?
I am still working on the rendering the whole solution.
thanks again for the help.
Hi Thanks again for help.
I had just started coding the player part.
The name of the flv I would like to play is passed to the player using jquery.
So it would be
The variable contained in the above code.
The actionscript is supposed to read the variable and play it on myVid which is the variable name for the videoplayer object inside the flash.
I just turned the player to run with as1 and 2. So would:
//Action script
myVid.play();
Get the variable in the sendToActionScript("yourflvname.flv");
to play on myVid.play();
I modified the original actionscript code posted to get the passed video playing on the video component with instance name myVid.
Thanks.
Hi
Thanks again for the help. I am almost there. Just made a first try on my server but without any luck.
Below is the html and the actionscript is the same as you posted. When I click play button in the code
the Videos/teleme.flv is supposed to be then passed and played. Nothing happens. I think I messed up the jquery part any help
will be appreciated.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<script type="text/javascript" src="jquery/jquery-1.4.2.min.js"></script>
<script src="Scripts/swfobject_modified.js" type="text/javascript"></script>
$(document).ready(function() {
} else {
thisMovie("JQplay").sendToActionScript(flv);
</script>
<title>Untitled Document</title>
</head>
<body>
<object id="FlashID" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="550" height="400">
<param name="movie" value="JQUERYPLAY/JQplay.swf" />
<param name="quality" value="high" />
<param name="wmode" value="opaque" />
<param name="swfversion" value="6.0.65.0" />
<!-- This param tag prompts users with Flash Player 6.0 r65 and higher to download the latest version of Flash Player. Delete it if you don’t want users to see the prompt. -->
<param name="expressinstall" value="Scripts/expressInstall.swf" />
<!-- Next object tag is for non-IE browsers. So hide it from IE using IECC. -->
<!--[if !IE]>-->
<object type="application/x-shockwave-flash" data="JQUERYPLAY/JQplay.swf" width="550" height="400">
<!--<![endif]-->
<!-- The browser displays the following alternative content for users with Flash Player 6.0 and older. -->
<div>
<h4>Content on this page requires a newer version of Adobe Flash Player.</h4>
<p><a href="http://www.adobe.com/go/getflashplayer"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash player" width="112" height="33" /></a></p>
</div>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
swfobject.registerObject("FlashID");
</script>
<br/>
<input type="button" value="play" onClick="sendToActionScript('Videos/teleme.flv');" />
</body>
</html>
Videos.teleme.flv is inside the JQUERYPLAY Folder when the swf is also contained. JQplay.php is in the main folder of the site.
thanks.
Hi
I recent but all the file in the same folder but with out any luck. I have gone over an over again on the code but can`t find any thing wrong.
I think part of the problem mite be the jquery. Could browser type affect the functionality.
If possible is they a way to try the same code on your machine and see how it goes it would be really helpful.
Thanks.
All the code is the same as we discussed on earlier posts.
Appreciate the help.
Hi
Thanks so much again for the help. Really appreciate. Maybe I can upload the html page as it looks for a quick look. Maybe you mite notice
something.
So here goes as said earlier all file are in same folder including video:
video name: teleme.flv
player name: JQplay.swf with actionscript from earlier post.
// JQplay.htm
<head>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.6.1/jquery.min.js"></script>
<script src="swfobject_modified.js" type="text/javascript"></script>
} else {
</script>
<title>Qplayer</title>
</head>
<body>
<param name="movie" value="JQplay.swf" />
<param name="expressinstall" value="expressInstall.swf" />
<!--[if !IE]>-->
<object type="application/x-shockwave-flash" data="JQplay.swf" width="550" height="400">
<!--<![endif]-->
<div>
<p><a href="http://www.adobe.com/go/getflashplayer"><img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.g if" alt="Get Adobe Flash player" width="112" height="33" /></a></p>
</div>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
</script>
<br/>
<input type="button" value="play" onClick="sendToActionScript('teleme.flv');" />
</body>
</html>
The actionscript loading flv into swf player:
//Action script MyVid is the player component instance
myVid.contentPath=flv;
myVid.play();
Please reply if you find any thing out of place.
i don't see where you're using jquery and there's faulty swfobject code. try:
<head>
} else {
</script>
</head>
<body>
<!--[if !IE]>-->
<!--<![endif]-->
<div>
</div>
<!--[if !IE]>-->
</object>
<!--<![endif]-->
</object>
<br/>
</body>
</html>
Hi
Thanks so much for the help. I am not sure what faulty swfobject code is but I just tried the code without no luck.
http://www.expishare.com/interactive/JQplay.html
or
http://www.expishare.com/interactive/JQplay.php
to check out. you can use view source to see code the teleme.flv is in same folder.
I am constantly trying out many things and hope to get lucky. Fingers crossed.
What debug method could I try like in actionscript to check if the variable arrived. Maybe a if statement or error check to verify that flash is recieving
the video?
Hi
That really mite be the problem because the externalinterface class is in the actionscript. I tried modifying the publish settings which
say its flash player 12. I even tried to modify to flash player 8.
Is they a way I can modify the actionscript to work with current version or manual modify the version in the code>
Thanks.
Hi
Thanks so much. Since you made the post I have been looking at some getURL() examples of doing the same as externalinterface but there is no
exact one that is suitable for working it in this circumstance.
So how can:
myVid.play();
using getUrl() playing video instantly.
Thanks so much.
Oh Okay.
So what option do I have? How can I manually publish high than flashplayer version 6 . Is there a way to manually change the version
after flash is published? Its weird I used the publish settings to publish flashplayer 12 but in the html it show some thing like
version 6. I am using dreamweaver after publishing.
Thanks.
Hi
Finally got it to fp8.
Check: http://www.expishare.com/interactive/JQplay.htm
if you click play below the player the vid should play. But no luck.
teleme.flv is in the same folder and actionscript same. Constantly trying other things.
Any idea will be appreciated.
Thanks.
Hi again
I just needed your assistance on a solution that works for text but needs modifiication to enable video.The solution uses Flashvars:
2 php variables are passed to swf and displayed on textfield.
<?php
$id = "monito";
$code = "teleme.flv";
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>AS3</title>
<script language="javascript">AC_FL_RunContent = 0;</script>
<script src="AC_RunActiveContent.js" language="javascript"></script>
</head>
<body bgcolor="#333333">
<!--url's used in the movie-->
<!--text used in the movie-->
<!-- saved from url=(0013)about:internet -->
if (AC_FL_RunContent == 0) {
alert("This page requires AC_RunActiveContent.js.");
} else {
AC_FL_RunContent(
'codebase', 'http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#ve rsion=9,0,0,0',
'width', '500',
'height', '500',
'src', 'AS3_php_Var_into_flash',
'FlashVars', 'itemID=<?php print "$id"; ?>&itemCode=<?php print "$code"; ?>',
'quality', 'high',
'pluginspage', 'http://www.macromedia.com/go/getflashplayer',
'align', 'middle',
'play', 'true',
'loop', 'true',
'scale', 'showall',
'wmode', 'window',
'devicefont', 'false',
'id', 'AS3_php_Var_into_flash',
'bgcolor', '#ffffff',
'name', 'AS3_php_2_Var_into_flash',
'menu', 'true',
'allowFullScreen', 'false',
'allowScriptAccess','sameDomain',
'movie', 'AS3_php_2_Var_into_flash',
'salign', ''
); //end AC code
</script>
<noscript>
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#ve rsion=9,0,0,0" width="500" height="500" id="AS3_php_Var_into_flash" align="middle">
<param name="allowScriptAccess" value="sameDomain" />
<param name="allowFullScreen" value="false" />
<param name="movie" value="AS3_php_2_Var_into_flash.swf" />
<param name="bgcolor" value="#ffffff" />
<param name="FlashVars" value="itemID=<?php print "$id"; ?>&itemCode=<?php print "$code"; ?>">
<embed src="AS3_php_2_Var_into_flash.swf" FlashVars="itemID=<?php print "$id"; ?>&itemCode=<?php print "$code"; ?>" quality="high" bgcolor="#ffffff" width="400" height="150" name="AS3_php_2_Var_into_flash" align="middle" allowScriptAccess="sameDomain" allowFullScreen="false" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" />
</object>
</noscript>
</body>
</html>
Can you help me with actionscript 3 or 2 to grab the 2 variables and play them in a video playback component instance name Myvid
The current actionscript reads the variables and displays them on textfield: this code:
// Claim the offset Number that spaces the text
// fields so they are not right on top of each other
var offSet:Number = 32;
// Claim keyStr variable as a string
var keyStr:String;
// Claim valueStr variable as a string
var valueStr:String;
// Create the paramObj Object and set it to load parameters
// from the root level being sent in by FlashVars externally
var paramObj:Object = LoaderInfo(this.root.loaderInfo).parameters;
// Set Text Format Object, its attributes and values
var format:TextFormat = new TextFormat();
format.font = "Verdana";
format.size = 24;
// Create the loop that iterates over all of the variables you send in using FlashVars
for (keyStr in paramObj) {
valueStr = String(paramObj[keyStr]); // This line gets the values of each variable sent in
var myText:TextField = new TextField(); // Create a text field to read and access each var
myText.defaultTextFormat = format; // Set the formatting into the text field properties
myText.text = keyStr + " value is: " + valueStr; // Use the vars here, I place into text field waiting
myText.y = offSet; // Before we place each text field on stage we offSet it
myText.width = 450; // Set the width of the text field
this.addChild(myText); // Now this line actually places the text field on stage
offSet += offSet; // Offset offSet(lol) so the next text field is 32 pixels lower
I am trying to change that so the variable is used to play the pass video url into the videoplay name Myvid.
Thanks.
I am still working and modifying past code mite have a break through soon.
North America
Asia Pacific
