• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
procedure for importing pdf
Explorer ,
Dec 21, 2011 Dec 21, 2011
I am on RH8. I'm getting a message saying corrupted file when I try to import PDF. I found Peter's info re: this problem on his site as follows:
22
07 Jan 2010Peter Grainge
Importing a PDF results in a invalid file format or corrupted file message.
Bizarrely you may get this message if you import a PDF created in a recent version of Acrobat including the one that ships with RoboHelp 8.
To test this is the cause, import an old PDF or one created by another PDF writer.
The workaround is to set Acrobat to save with Acrobat 5 compatibility.
Update 27 Jan 2011. This problem has been fixed in RoboHelp 9.
I need more info and a procedure for doing what is suggested here.
Views
895
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Dec 22, 2011 Dec 22, 2011
your second approach worked. I don't believe this error was fixed even in RH 8.02.
Votes
Translate
Translate
Community Expert ,
Well, there's 2 approaches here - the first is to hope that it got fixed in RH8 for you. Make sure that you're all up to date with your RH8 patches (use the Help > Updates mechanism or go directly to the http://www.adobe.com/downloads/updates/ page.
The second approach (if the first doesn't pan out and you don't want to move to RH9) is to recreate the PDF again and set the "open-with" version to Acrobat 5.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jeff, is Open-with a TCS/RH PDF layout setting? Or do you mean the compatibility setting when converting a Word doc to PDF?
Votes
Translate
Translate
Report
Report
Community Expert ,
The latter - it's an Acrobat security setting
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Thanks. Just wasn't sure if there was a separate option in RH8.
Votes
Translate
Translate
Report
Report
Explorer ,
Votes
Translate
Translate
Report
Report
Community Expert ,
I kind of suspected that - if they had, Peter would have mentioned it on his site.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
