I'm sure that I just haven't come across the right article yet, but I can't seem to find a decent tutorial addressing sending a PHP variable to Flash. I definitely have looked, but haven't come up with a working solution. In my PHP file, I declare a variable with content from a MySql database. I know for sure that going from the database to PHP works, but I'm not sure how to reach that variable and display it in Flash. Right now, here is my code:
var loader:URLLoader = new URLLoader();
loader.dataFormat = URLLoaderDataFormat.VARIABLES;
loader.addEventListener(Event.COMPLETE, varsLoaded);
loader.load(new URLRequest("reciever.php"));
var varToAppend:String = "";
function varsLoaded(e:Event):void
varToAppend = e.target.data.all_content.toString();
all_txt.text = String(varToAppend);
all_content is my variable I'm trying to reach. But when I run my program, it comes up with this error:
TypeError: Error #1010: A term is undefined and has no properties.
at Base_fla::MainTimeline/varsLoaded()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at flash.net::URLLoader/onComplete()
This is the line it does not like:
When I take out the .toString(); it shows null. Does any one have any suggestions with more productive code?
Thank you, Alex.
Do a trace to see what you get:
function varsLoaded(e:Event):void {
trace(e.target.data);
Kenneth Kawamoto
Thank you for the reply. I am assuming you wanted to do this locally? Well, I did, and it gave me:
%3C%3Fphp%20require%5Fonce%28%27%2E%2E%2FConnections%2FFlashCon%2Ephp%27%29%3B%20%3F%3E%0D%0A%3C%3Fphp%0D%0Aif%20%28%21function%5Fexists%28%22GetSQLValueString%22%29%29%20%7B%0D%0Afunction%20GetSQLValueString%28%24theValue%2C%20%24theType%2C%20%24theDefinedValue%20=%20%22%22%2C%20%24theNotDefinedValue%20%3D%20%22%22%29%20%0D%0A%7B%0D%0A%20%20if%20%28PHP%5FVERSION%20%3C%206%29%20%7B%0D%0A%20%20%20%20%24theValue%20%3D%20get%5Fmagic%5Fquotes%5Fgpc%28%29%20%3F%20stripslashes%28%24theValue%29%20%3A%20%24theValue%3B%0D%0A%20%20%7D%0D%0A%0D%0A%20%20%24theValue%20%3D%20function%5Fexists%28%22mysql%5Freal%5Fescape%5Fstring%22%29%20%3F%20mysql%5Freal%5Fescape%5Fstring%28%24theValue%29%20%3A%20mysql%5Fescape%5Fstring%28%24theValue%29%3B%0D%0A%0D%0A%20%20switch%20%28%24theType%29%20%7B%0D%0A%20%20%20%20case%20%22text%22%3A%0D%0A%20%20%20%20%20%20%24theValue%20%3D%20%28%24theValue%20%21%3D%20%22%22%29%20%3F%20%22%27%22%20%2E%20%24theValue%20%2E%20%22%27%22%20%3A%20%22NULL%22%3B%0D%0A%20%20%20%20%20%20break%3B%20%20%20%20%0D%0A%20%20%20%20case%20%22long%22%3A%0D%0A%20%20%20%20case%20%22int%22%3A%0D%0A%20%20%20%20%20%20%24theValue%20%3D%20%28%24theValue%20%21%3D%20%22%22%29%20%3F%20intval%28%24theValue%29%20%3A%20%22NULL%22%3B%0D%0A%20%20%20%20%20%20break%3B%0D%0A%20%20%20%20case%20%22double%22%3A%0D%0A%20%20%20%20%20%20%24theValue%20%3D%20%28%24theValue%20%21%3D%20%22%22%29%20%3F%20doubleval%28%24theValue%29%20%3A%20%22NULL%22%3B%0D%0A%20%20%20%20%20%20break%3B%0D%0A%20%20%20%20case%20%22date%22%3A%0D%0A%20%20%20%20%20%20%24theValue%20%3D%20%28%24theValue%20%21%3D%20%22%22%29%20%3F%20%22%27%22%20%2E%20%24theValue%20%2E%20%22%27%22%20%3A%20%22NULL%22%3B%0D%0A%20%20%20%20%20%20break%3B%0D%0A%20%20%20%20case%20%22defined%22%3A%0D%0A%20%20%20%20%20%20%24theValue%20%3D%20%28%24theValue%20%21%3D%20%22%22%29%20%3F%20%24theDefinedValue%20%3A%20%24theNotDefinedValue%3B%0D%0A%20%20%20%20%20%20break%3B%0D%0A%20%20%7D%0D%0A%20%20return%20%24theValue%3B%0D%0A%7D%0D%0A%7D%0D%0A%0D%0Amysql%5Fselect%5Fdb%28%24database%5FFlashCon%2C%20%24FlashCon%29%3B%0D%0A%24query%5FFlash%20%3D%20%22SELECT%20%2A%20FROM%20messages%22%3B%0D%0A%24Flash%20%3D%20mysql%5Fquery%28%24query%5FFlash%2C%20%24FlashCon%29%20or%20die%28mysql%5Ferror%28%29%29%3B%0D%0A%0D%0Awhile%28%24row%5FFlash%20%3D%20mysql%5Ffetch%5Farray%28%24Flash%29%29%0D%0A%7B%0D%0A%24all%5FContent%20%3D%20%24row%5FFlash%5B%27fullName%27%5D%20%2E%20%22%2D%2D%2D%2D%2D%22%20%2E%20%24row%5FFlash%5B%27email%27%5D%20%2E%20%22%2D%2D%2D%2D%2D%22%20%2E%20%24row%5FFlash%5B%27message%27%5D%20%2E%20%22%3Cbr%20%2F%3E%22%3B%0D%0A%7D%0D%0A%0D%0A%2F%2Fmysql%5Ffree%5Fresult%28%24Flash%29%3B%0D%0A%3F%3E
Any new instruction, can I decode this?
Thank you, Alex
So I think I might have gotten part of this, here:
var i:int = 0;
while (i < loader.data.all_Content.length)
all_txt.text.concat(loader.data.all_Content + "\n");
Any one know any other way to get info from PHP?
You should output your PHP to an XML file. To import the XML (AS3!) there is an Flash code example from Flash itself however there was a error in that code (may have been corrected in the meantime) there used to be a comment in which the code was corrected.
I explored that 2 years ago and it works. In one of his books David Powers I believe explains the output to XML. If you have got that working you can import the XML in your Flash (AS3) file. There is a book called XML and E4X for Flash and Flex which describes all kinds of ways to get your XML data into Flash.
Ha! In the mean time, while I was waiting for a reply, I did that! I actually got the database into XML and went from there! Great minds think alike( Although its been thought up before)
Thank you, Alex
