Audition CS5.5 won't play
Dec 23, 2011 7:34 AM
Tags: #adobe #mac #audio #premiere #5.5 #audition #audition_cs5.5 #playback_issues
MacBook Pro 17"
2.2GHz Intel Core i7
8Gb RAM
Audition was working nicely.  Now over the past 2 weeks, it won't play anything.  I've tried MP3 files, WAVs, audio exported from Premiere....nothing is working.
Help!!!
    Dec 23, 2011 7:37 AM   in reply to GotDesign01
    Do you get an error message? Can you see the cursor and level meters moving, but hear no sound? What is your audio setup?
  • SteveG(AudioMasters)
    Oct 26, 2006
    Dec 23, 2011 8:25 AM   in reply to GotDesign01
    GotDesign01 wrote:
    The CTI won't move.  It's not playing, there is no sound to hear.  Nothing is happening.  No error messages, nothing.  I open a file, it renders the waveform... and just sits there.  I pressed the play button...nothing.  Spacebar... nothing.
    If the transport won't start, it means that Audition is disconnected from your sound device. That's about the only thing that will cause this to happen. In other words, no active sound device is allocated to it; without this, nothing.
    Oct 26, 2006
    Dec 23, 2011 9:22 AM   in reply to GotDesign01
    As far as Audition is concerned, look in Preferences at the Audio Hardware setup - whatever shows in there is what you've got.
    If nothing shows there, then I have no idea of what you do, because you're running a Mac. By and large we only speak PC here, although it's just possible that somebody might pick it up...
    Oct 26, 2006
    Dec 23, 2011 11:40 AM   in reply to GotDesign01
    GotDesign01 wrote:
    How can I get this message bumped/copied ove to the "Audition for Mac" forum?
    Hehe! Best one I've heard all day!
    Dec 23, 2011 4:02 PM   in reply to SteveG(AudioMasters)
    Audition seems to be too highly developed.
    I could not record anything unless the Speaker and Microphone were set to the same Hz rate.
    Thst so silly.
    even a 32kbps low quality sound plays well on my speakers so, why connectiong input and output sound quality/Hz?
    Dec 24, 2011 2:19 AM   in reply to GotDesign01
    Why is it silly that the record and playback sample rate have to match?  If you think about it, when you're recording, the sound you're listening to is looped through your sound interface.  If the rates don't match, it'll stop working because from your description, you're probably using something like a simple Realtek which can only do one thing at a time.
    Really, the inbuilt sound cards on most computers are NOT designed for any serious recording--they're far more suitable just for watching Youtube or making Skype calls.  However, you CAN use it if your really must--but it'll get confused trying to handle two sample rates at once.
    It's not anything silly in Audition--it's a limitation of your sound card and operating system.
    Dec 24, 2011 3:04 AM   in reply to Eireannsg1
    There are many users on this forum who might be inclined to disagree with you!
    BTW, I'm not one of them; for me it does exactly what I need it to do.
    Oct 26, 2006
    Dec 24, 2011 6:01 AM   in reply to Eireannsg1
    This thread is full of little gems!
    Dec 24, 2011 6:27 AM   in reply to emmrecs
    For me for example it doesnt do one thing...record system sound.
    W7 allows to record system sound, XP doesnt. Sadly that option doesnt exist...unless someone disagrees amd tells me how to record system sound with Audition...
    Right now only my Camtasia records that.
    Dec 24, 2011 6:57 AM   in reply to Eireannsg1
    Audition has nothing to do with all those routing things--that's handled by the control panel for your sound card.  On my old XP laptop the internal sound card gave me an option called "What U Hear" and that gave me system sounds.  As I recall (I'm not on that machine right now) the default setting did NOT show all the possible sources--you had to tick boxes beside the ones you wanted to see.
    Actually, you're one of the few lucky ones to be able to record system sounds in Windows 7.  The OS provides for this but the vast majority of computer manufacturers are disabling this function under pressure from the recording industry.  Have a look at how often the question is asked in this forum....
    Dec 24, 2011 8:27 AM   in reply to GotDesign01
    Go into your Core Audio settings.  You need to match the record and playback bits to the same sample rate.  On a Mac, that is the place to start.  If you are exporting from Premiere into Audition you will need to set your playback engine to match whatever your Premiere session was set.
    Dec 24, 2011 4:00 PM   in reply to Bob Howes
    "Actually, you're one of the few lucky ones to be able to record system sounds in Windows 7."
    Its not only me.
    We tried to record system sound in Indonesia and it didnt work....
    I said change from XP to W7...
    The guy changed and it worked.
    Thats why I think the windows7 provides for that while earlier versions dont.
    Dec 24, 2011 4:03 PM   in reply to Eireannsg1
    Oh, for older systems you can just plug audio-out into mic-in and you can record system sound.
    Oct 26, 2006
    Dec 25, 2011 2:28 AM   in reply to Eireannsg1
    Its not only me.
    I think that this is completely wrong, and back to front - Bob is quite correct. It works easily with XP on most systems, and is a right PITA with W7.
    Jan 20, 2012 11:12 AM   in reply to GotDesign01
    I had the same problem, the solution turned out to be banal. I went to the Preferences of Audition to verify if I had the Audio Hardware settings set up right (I use loudspeakers or headphones, and every time I change the output, I need to change it in the Preferences). That setting was set right, to the headphones, though. So, just to see what will happen, I changed it to Built-in Output and a dialog box appeared: Device changes can modify....etc. Previously I clicked "No" and I still had the problem. So this time I clicked "Yes" and the problem was solved. (Of course to be able to hear, I changed back to headphones)
