agile116@hotmail.com
ReferenceError: Error #1065 (upgrade to flex 4.5 runtime exception)
Dec 26, 2011 8:49 PM
Hi All,
I have the following runtime exception after the full build using ant. It seems everything works fine if I use flashbuilder and run it locally. Please help. Thanks.
ReferenceError: Error #1065: Variable _class_embed_css_Assets_swf__292477325_MenuSeparator_1674341715 is not defined.
    at flash.display::MovieClip/nextFrame()
    at mx.core::FlexModuleFactory/deferredNextFrame()
    at mx.core::FlexModuleFactory/update()
    at mx.core::FlexModuleFactory/moduleCompleteHandler()
ReferenceError: Error #1065: Variable _class_embed_css_Assets_swf__292477325_MenuBranchEnabled_1201810055 is not defined.
ReferenceError: Error #1065: Variable _class_embed_css_Assets_swf__292477325_TreeDisclosureOpen_1997560420 is not defined.
ReferenceError: Error #1065: Variable _class_embed_css_Assets_swf__292477325_MenuRadioDisabled_121084241 is not defined.
ReferenceError: Error #1065: Variable _class_embed_css_Assets_swf__292477325_CloseButtonDisabled_1335350451 is not defined.
ReferenceError: Error #1065: Variable _class_embed_css_Assets_swf__292477325_MenuRadioEnabled_1524626796 is not defined.
    Nov 23, 2013 8:17 PM   in reply to agile116@hotmail.com
    Hi, did you ever find a solution?  I have the same issue.
    Nov 25, 2013 11:24 AM   in reply to agile116@hotmail.com
    http://stackoverflow.com/questions/12914660/embedded-resources-with-in cremental-build-provokes-runtime-exception-with-flex-4
    Apparently the fix is to compile a module when using ant using incremental=false.  Looks like that's a known issue.
    Hope someone else can benefit from this!
    Thank you to Alex who provided this answer!
    Here is a sample macrodef for ANT which eliminates this issue:
    <macrodef name="buildModule">
        <attribute name="module-name" default="none" />
        <attribute name="module-package" default="none" />
        <attribute name="out-path" default="." />
        <attribute name="debug" default="true" />
        <sequential>
            <echo message="${absolute_basedir}"/>
            <antcall target="checkReportsDir"/>
            <echo message="building @{module-name} to @{out-path}/@{module-name}.swf" />
            <mxmlc file="${APP_ROOT}/src/@{module-package}/@{module-name}.mxml"
                   output="${DEPLOY_DIR}/@{out-path}/@{module-name}.swf"
                   keep-generated-actionscript="false"
                   incremental="false"
                   debug="@{debug}"
                   optimize="false"
                   size-report="${basedir}/reports/@{module-name}-size_report.xml"
                <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml"/>
                <load-config filename="${basedir}/config/ModuleConfig.xml"/>
            </mxmlc>
        </sequential>
    </macrodef>
