Reducing Animated GIF Significantly
Jan 1, 2012 1:41 PM
I have a 3.4 meg animated gif.  I was only able to reduce it to 1.8 megs.  Any solution, without reducing colors to shrink the animated gif to under 300K preferable ?
  • Noel Carboni
    Dec 23, 2006
    Jan 1, 2012 1:46 PM   in reply to StrongBeaver
    Most folks use a video format for a significantly large/long animation.
    How big is the image (horizontal pixels x vertical pixels)?
    How many frames?
    Is it made up of a lot of color complexity?
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 1, 2012 7:52 PM   in reply to StrongBeaver
    That's moderately small, but with a large frame count.  I'm guessing there must be a fair bit of change between frames in order to get it up to the size you've reported.  GIF compression works best when exactly identical RGB values are maintained across large spaces in the image, and from frame to frame.
    Beyond possibly reducing the width and height if possible, I can only suggest fooling with the color table size and other parameters available to you in the Save for Web & Devices dialog and looking critically at the results.
    -Noel
    Jan 2, 2012 12:45 AM   in reply to StrongBeaver
    What content requires 186 frames? What are you trying to show?
    A 200kb GIF at that size is usually ~12 frames, certainly not over 100.
  • JJMack
    Jan 9, 2006
    Jan 2, 2012 4:55 AM   in reply to StrongBeaver
    It is very hard to predict the size an animated gf will be. To many variables image complexity and complexity of the animation here is a 390x200 pixel size one that has 150 frames and has a file size of 157KB.  About the size you want yours to be.
