sn5n
Sony NEX-5N AVCHD 2.0 1080p50 and Premiere Pro/After Effects CS5.5
Jan 3, 2012 1:09 AM
Tags: #avchd #2.0 #after_effects_cs5.5 #1080p50
I have a new Sony NEX-5N and have shot some test 1080p50 video using it.
On my quest for some new editing/production software to close the loop I have just downloaded and installed a Trial Version of CS5.5 Production Premium.
I am able to load my video files into Premiere Pro.
However, when I attempt to open the Video File in After Effects, I recieve the following Error message:
After Effects error: '00023.MTS' cannot be imported - this '.mts' file is damaged or unsupported.
Perhaps this is a limitation of the Trial Version or perhaps a limitation of After Effects CS5.5.  Is anyone able to advise?
As extra information I include below the TEXT output from MediaInfo for the file I am able to load into Premiere Pro CS5.5 but not After Effects.
Thanks.
General
Complete name                    : F:\AVI\Video\SourceMedia\00023.MTS
Format                           : BDAV
Format/Info                      : Blu-ray Video
File size                        : 61.8 MiB
Duration                         : 19s 616ms
Overall bit rate mode            : Variable
Overall bit rate                 : 26.4 Mbps
Maximum Overall bit rate         : 28.0 Mbps
Video
Menu ID                          : 1 (0x1)
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.2
Format settings, CABAC           : Yes
Format settings, ReFrames        : 2 frames
Format settings, GOP             : M=1, N=12
Codec ID                         : 27
Duration                         : 19s 680ms
Bit rate mode                    : Variable
Bit rate                         : 25.1 Mbps
Maximum bit rate                 : 26.0 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 50.000 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.242
Stream size                      : 58.8 MiB (95%)
Audio
Menu ID                          : 1 (0x1)
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : 129
Bit rate mode                    : Constant
Bit rate                         : 256 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Compression mode                 : Lossy
Stream size                      : 615 KiB (1%)
Text
Menu ID                          : 1 (0x1)
Format                           : PGS
Codec ID                         : 144
Duration                         : 19s 135ms
