AcrobatBlog
PDF Maker/Outlook 2007 crashing issue
Jan 3, 2012 11:14 AM
When using Adobe PDF maker in outlook 2007 it often crashes. Is there a maximum PDF portfolio size that you can archive emails into? It seems once my file hits a certain size I need to begin a new file for the process to run? How can I fix this?
    Jan 5, 2012 5:48 AM   in reply to AcrobatBlog
    There are some known issues with Acrobat X and Outlook. These issues are as follows (taken from the Known issues documentation):
    If Outlook is online with Exchange (cached Exchange Mode OFF), then PDFMaker can only convert 249 mails through selection. All the mails after that are skipped with Status "Unable to open secured message."
    • You can open messages in Outlook in the same session where PDFMaker conversion through selection had failed.
    • Folder conversion works fine. PDFMaker successfully converts 10000 mails in an online folder on exchange server.
    • Tested for Outlook 2007, Outlook 2003, and Outlook XP. Same behavior irrespective of outlook version.
      PDFMaker should be able to convert up to 1000 mails through selection with Cached Exchange Mode OFF. [1662502]
Bookmarked By (1)
