I've installed the v1.2 all in one .zip and configured it as per http://opensource.adobe.com/wiki/display/flexpmd/FlexPMD+Eclipse+plugin after installing the plugin itself some time ago (back in v1.1 days). No updates are show right now as pending and the update site is enabled.
Although the CPD detector runs OK, when I right click a source folder and choose 'Run FlexPMD', the Flex PMD view remains empty. The PMD builder is enabled for the project too, no joy.
The eror log doesn't have anthing relevent, just :
eclipse.buildId=M20110210-1200
java.version=1.6.0_26
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Wed Jan 04 14:20:20 GMT 2012
Unable to create menu item "com.adobe.ac.pmd.eclipse.toolbar.runCommand", command "com.adobe.ac.pmd.eclipse.flexpmd.runCommand.category" not defined
Any hints ?
Upgrading to Builder 4.6 didn't help.
Check if your project name contains space character. If there is any space in name FlexPMD fails to generate anything. Just figured this out while having exactly the same problem. Hope it helps.
Including including the -Djava.io.tmpdir= param in java command line didn't help in my case
Try changing the "Java command line" in the FlexPMD preferences to change the location of the temp folder to somewhere FlashBuilder has permissions... This can be done by including the -Djava.io.tmpdir="
C:\Documents and Settings\{user}\Application Data\Temp" or a similar directory.
