ehandel
Illustrator CS4 Type Tool: Selecting won't work by double click or click and drag.
Jan 4, 2012 4:58 PM
Tags: #cs4 #macpro #mac #mac_pro #illustrator_cs4 #type_tool
Illustrator CS4
I'm not exactly sure what happened, but suddenly my Type Tool can not select type by double clicking or click and drag any more.
I'm using Illustrator CS4 (14.0.0) on a MacPro with OSX 10.6.8. Can someone please suggest what might be happening and how to resolve this problem?
Eric
    Jan 4, 2012 5:11 PM   in reply to ehandel
    Check preferences for "Text": "Select text-object by path only" should be off.
    Jan 5, 2012 11:11 AM   in reply to ehandel
    Does your cursor change to an I-Beam after double clicking the type?
    Make sure your selctions are not hidden, hit CMD H.
    Check that your type is not a symbol.
    Jan 5, 2012 11:40 AM   in reply to ehandel
    View>Show Edges
    Command H  or Control H
    Jul 28, 2012 9:21 AM   in reply to Monika Gause
    Thank you.  This has been bugging me for months.
    What I never will understand is why Adobe makes changes like this in the first place.  Too many programmers with not enough to do.
    Jul 28, 2012 2:27 PM   in reply to tangolocoxoxo
    There is a functional reason for this depending on how you work if you read yup about it in the help files i think they explain it well as i recalled it was exxplained well in the manual when they had one.
    It is not a change it has been this way for a long time and the options serve different users in a helpful way. hough it wwould be helpful to have a toggle of some kind.
    Mar 14, 2013 9:24 AM   in reply to ehandel
    Was your issue resolved? I ask beacuse I am experiencign the same problem. "Select text-object by path only" is off.
    Any suggestions would be great!
    Thanks in advance
    Mar 14, 2013 9:27 AM   in reply to WordPain
    As above check the toggle for Show/Hide Edges in the View menu. Cmd(Ctrl)-H
    Mar 18, 2013 9:04 AM   in reply to Larry G. Schneider
    I should have mentioned my edges are showing, so that wouldm't be it. Any other suggestions? I am going to trash my preferences and see if that works.
    Thank you
