Hello all,
I've javascripting InDesign for about a year. My job is almost completely automated now.
However, something is eluding me. When I export a document to a PDF, I have a script that adds the export to a queue (aka a background task). It exports to 3 different places (two back-up folders and the desktop). However, one server is slower than the others and when I use myDocument.close() at the end of the script, InDesign gives me a message that says it can't close the document because it is being used by a background task. Here's the code:
myDocument.asynchronousExportFile (
ExportFormat.pdfType,
File (desktopFolder.fsName+"/"+pdfFile),
false
myDocument.close();
Ideally, what I'd like to do is add some sort of event listener to wait for the background tasks to complete before closing the document. But, not affect the ability to move on to other tasks while the export is happening. How do I do that??
-Mike
Hi Mike.
Here is an example of capture export event:
#targetengine session
(function() {
app.addEventListener("afterExport", function(evnt) {
var task, listener;
task = app.idleTasks.add({ name: "exportPDF", sleep: 1000});
listener = task.addEventListener(IdleEvent.ON_IDLE,
function(ev) {
listener.remove();
task.remove();
if (/Adobe\sPDF/.test(evnt.format)){
app.activeDocument.close (SaveOptions.YES);
}).name = "exportPDF";
alert("custom exporter installed.");
If you want stop listener, run below:
#targetengine "session"
myListener = app.eventListeners.itemByName("exportPDF");
if (myListener.isValid) {
myListener.remove();
alert ("custom exporter removed." )
...or you can disable background export. You can read as reference below:
http://forums.adobe.com/message/3689090#3689090
Ten.
@Ten: the "old" exportFile method is still available.
So, if you want to export to PDF without a background task you could do it like this:
myDocument.exportFile (
false
myDocument.close();
But I think Mike did deliberately choose the "asynchronously" variety…
Uwe
Heres my code:
function Listen () {
app.addEventListener("afterExport", function(evt) {
var task = app.idleTasks.add ({name:"exportPDF", sleep: 1000});
var listener = task.addEventListener (IdleEvent.ON_IDLE, function(e) {
listener.remove();
task.remove();
if (/Adobe\sPDF/.test(evt.format)) {myDoc.close(SaveOptions.YES)};
alert ("Custom exporter installed.");
Listen();
myDoc.asynchronousExportFile(
File (dirFolder.fsName + "/" + pdfFile),
false
I was concerned that the "afterExport" class is not in the object model for InDesign CS5. I think that may be why the document is not closing after the export completes. Other than that, there are no errors...
Hi Mike.
Your code works fine in my environment. But I think better to kill Listener each time automatically.
listener.remove();
task.remove();
myDoc.close(SaveOptions.YES);
app.eventListeners.itemByName("exportPDF").remove(); //kill listener.
//alert ("custom exporter removed.")
//alert ("Custom exporter installed.");
//my test parameters.
pdfFile = "/test10.pdf";
Listen();
File (pdfFile),
false
Event classes dropped from Object Model Viewer. But we can correct props ourself like below :
var str ="";
for (var a in Event) {
str += a + "\n";
alert(str);
But I think best way of reading Object Model, download and read Jongware's CHM file. Check below link.
http://forums.adobe.com/thread/668578
@Uwe : Thank you for your information.
Ten
This is really helpful.. I've been using it for awhile now. But, I'd like to make it better.
How would I go about creating a queue? Right now, when I try to export multiple documents at once, the script will only close the last document exported, and not the others. So, if I run the script each time on 3 documents, only the last one will close.
Ideally, I'd like to add these documents to a queue that will close them each as they finish. How would you go about doing that?
Cheers,
Mike
Hi Mike,
We can do that, simply counting finished time. But regular variables lost value when functions finished.
So I try to use closure and it works, see below:
function Listen (num) {
var flg = (function (){ //closure
var _f = 1;
return function(){return _f++;}
listener.remove();
task.remove();
if (/Adobe\sPDF/.test(evt.format)&&flg()>num) {
//test
var svLen = 3; //document length
Listen(svLen-1);
for (i=0;i<svLen;i++)
myDoc.asynchronousExportFile(ExportFormat.pdfType,File ("/test" + i + ".pdf"),false);
Ten
North America
Asia Pacific
