wyclef
Webserver Connector Utility - CF Dev 9.0.1
Jan 6, 2012 11:51 AM
This thing work? Trying to configure a connection with Apache and keep getting that mod_jrun22.so connector problem that seems like people run into.  Wondering what the latest is with this?
    Jan 6, 2012 12:06 PM   in reply to wyclef
    Yes, the webserver connector utility usually does work and for a great many people, it works without any problem.  Of course none of those people are going around making posts to forums, blogs, or discussion lists.
    When it does not work, it can be a bit of a pain in the butt until it is sorted out.  I have an the past had to custom compile the connector code to get it to work properly on one system I was working with at the time.
    The latest is that if it does not work for you, there is something about your system that is throwing the utility for a loop.  There are ways and means to sort this out but, unfortunately, it will require more work on your part.
    If you would like help from members of this forum, you can provide us with all the relevant information you have about what happens when you use the utility, what you have tried to do to resolve the issue and anything else you think is relevant.
  • Dave Watts
    Mar 11, 2003
    Jan 7, 2012 8:12 PM   in reply to wyclef
    One issue I'm now having which I would LOVE to understand and resolve is that I've installed the CFIDE folder in both either the ColdFusion9 wwwroot directory or MAMPS htdocs directory but it seems as though in order for the administrator area to work properly it wants a duplicate copy of the CFIDE folder in both directories. Does anyone have any ideas about this?
    Also, the default mapping in http://localhost:8888/CFIDE/administrator/index.cfm seems to point to the ColdFusion9 wwwroot folder but it's uneditable. Probably has something to do with my issues?
    When you initially install CF, if you choose to use the built-in JRun web server, your CFIDE folder will be in the CF wwwroot directory. If you later configure CF to use an external web server, and you want to use CFIDE with that web server, that web server will need to be able to resolve the path and will therefore either need its own CFIDE folder or a virtual mapping to the CFIDE folder in the CF wwwroot directory. As a rule, you can't edit the default mapping and the CFIDE mapping from within CF Administrator - if you really need to edit those, you have to edit the underlying configuration file (neo-runtime.xml or neo-mappings.xml, something like that).
    In general, when I configure production web servers, I initially install CF using the built-in JRun web server, then configure CF to use an external web server. However, I don't want to run the CF Administrator through the external web server - instead, I use the built-in JRun web server to manage CF. So, what I do is copy a subset of the CFIDE folder to another directory for the external web server to use, so that I can use CFFORM, etc. But, if I wanted to run the CF Administrator as well, I'd just create a virtual mapping in the web server to resolve to the original CFIDE folder.
    Dave Watts, CTO, Fig Leaf Software
    Dec 27, 2012 11:16 PM   in reply to Dave Watts
    Dave, Can you expand this with more detail about what you do here?
    I have found this CF9 server installation such a pain in the butt with MAMP and in my case with VirtualHostX. I can't find any posting that details the whole setup for this exact situation. The few I have found don't use VHX, don't mention 32 or 64 bit, and mention about the bug in the wsconf about the jrun connector from the jar. I also find that the Webserver Connection Utility button in CF9 Launcher, when clicked asks for a password. It does not accept any password I type. No one has mentioned that either.  I've spent 10-12 hrs on this install and still no go. Painful hair pulling painful.
    Anyway I did install CF9 server 64-bit verion with the built in web server and got CF Administrator up and working but that has the webroot in wwwroot in /Application/Coldfusion 9 folder. When I tried to connect externally I got the same error wyclef originally reported at the start of this thread. I am going to try what wyclef then did and reinstall CF9 server 64-bit again but this time specify the connection to MAMP instead of the build in web server and see if I get the same results he did. But I assume I will run into the CFIDE issue as well, which is where your directions are too high level to help me understand what is your subset and how you manage CF Admin.
    Dec 28, 2012 2:13 PM   in reply to Tea man
    Well I finally found a blog with the exact problem I was having and a solution that worked!
    http://www.12robots.com/index.cfm/2012/9/27/Installing-ColdFusion-9-on -OSX-Snow-Leopard-Lion-and-Mountain-Lion-64bit
    It is an excellent article!
