Adobe Reader X 10.1.1 is not working correctly on my computer which is running Windows XP Professional Service Pack 3. I have several symptoms.
1. If I am able to open a pdf file on my hard drive I get this error message:
“Verify operation failed.”
I hit OK and can read the document fine.
2. Many pdf files on my hard drive will not open. I get the error message:
“There was an error opening this document. There was a problem reading this document (57).”
I doubt the document is corrupt because I can email them to my coworkers and they can open it.
3. I can open any document inside of Internet Explorer 8. I get the error message:
“There is a problem with Adobe Acrobat/Reader. If it is running, please exit and try again (0:104)”
It wasn’t running and trying again won’t help. Usually I download the file and try to open it and if I can't I email to a co-worker and continue on. But now I need to fill out a form online that uses a pdf but I can't download it. What can I do now?
I have uninstalled and reinstalled twice with no success. I suspect the root problem is the “Verify operation failed.”
Any ideas.
1. I repaired the application using Control Panel, no change.
I logged in as a different user and the “Verify Operation Failed.” Message did not appear.
But I could not open the problem pdf files.
2. The pdf files that won't open are labeled as SECURED when I open them in Foxit.
Thanks for taking the time to assist me with this.
Could you please try updating to the latest release of Adobe Reader i.e. 10.1.2 and see if the issue still exists.
You can do the same by clicking on Help > Check For Updates from within Adobe Reader.
Meanwhile could you please let me know if you are experiencing this with all the PDFs that you access on your system or only with a specific set of files.
Ankit
I updated to Adobe Reader X 10.1.2. Nothing is different.
1. Every time I open the Adboe Reader I get the error message:
2. (SECURED) pdf files on my hard drive will not open. I get the error message:
3. I can't open any pdf documents inside of Internet Explorer 8. I always get the error message:
Could you please try deleting all files and folders from within the Adobe Reader installation folder (byt default its C:\Program Files\Adobe\Reader 10.0) and then try repairing the application.
It seems as if you have an external plug-in installed on your system which may be causing the problem.
I tried deleted all files from the folder C:\ Reader 10.0 and then repairing the application.
There was no change.
I tried:
- Uninstalling Adobe and IE8.
- Deleted all Adobe files from my hard drive.
- Remove all reference to adobe from my registry.
- Ran a Registry Cleaning software.
- Reinstalled IE8 and Adobe Reader.
I don't think this is an Adobe Reader problem.
I think this is a Windows problem.
I'm having the exact same issue. I have tried everything I can think of. I'm not sure if its a compatability issue with IE 9, adobe reader 10.0 or Windows 7. I even spoke with my instructor and she failed to have any other ideas to solve this issue. If your able to discover one, would you mind sharing. I have a ton of homework and I'm unable to view the material.
Could you please temporarily disable the antivirus on your system and see if the same issue persists.
Also, it would be great if you could try and see if the problem re-occurs with the Protected Mode as Off on Reader. Although its not advised to have the mode turned off, it would me an idea as to the cause behind the issue.
You can disable the Protected Mode by going to Edit > Preferences > General and unchecking the "Enable Protected Mode" checkbox in Reader. Make sure that you close all instances of Adobe Reader post changing the setting.
Try and launch the same PDFs and see if the problem is still present.
Please make sure to turn on the Protected Mode thereafter to ensure that your system is not compromised by any malicious PDFs.
Ankit
I found a work around. It requires Foxit Reader, which is free.
Option 1: If you can't open a (.pdf) file in Internet Explorer because it insists on using Adobe Reader which fails on your computer for whatever reason, sometimes you can right click on the link itself and select “Save Target As” which will save the (.pdf) to your hard drive and then you can open it with Foxit Reader. If the file that it tries to save is something other than a (.pdf) such as an (.htm) then try option 2 below.
Option 2: If the “Save Target As” option isn't available, or it tries to save a file type (.htm), then click on the link anyway and let Adobe Reader try and open it. If it fails, the URL to the (.pdf) file should be in the Internet Explorer/Adobe Reader address bar. Copy the URL, open Foxit reader, go to File - Open, then paste the URL of the (.pdf) into the File Name textbox on the Open File pop-up screen and hit "Open".
I've tried changing the default (.pdf) reader to Foxit but sometimes the link to the (.pdf) still insists on using Adobe. Even if I try to use FireFox and Foxit together, there are some (.pdf) links that won't use anything but Adobe.
Sorry Adobe but I don't think it's your software, I think something is wrong with Windows on this computer.
Verify Operation Failed while trying to open the PDF file in Acrobat or Adobe Reader : Launch Acrobat or Adobe Reader, click on Edit > Preferences, In General check on Use Only Certified plug-ins and click on ok. After that navigate to C:\Users\User Account \AppData\Roaming\Adobe\Acrobat\10.0\preference, delete all files from preference folder. Then try to launch Acrobat and open the PDF file. This will resolve the issue.
North America
Asia Pacific
