I am using PP version 3.2 CS3. I imported clips that were shot on an XDcam EX-1. They show in my bins as MP4. For some reason, some of the clips do not have audio and some do. I played them in the source monitor and timeline - no audio. The mixer is showing no levels as well. I took the same clips and watched them in the XDcam browser and the audio is there. So there is no doubt audio. I am baffled as to why a few clips have this issue. Any suggestions? Thanks
First - To work with AC3 sound files in Premiere CS3, copy the ad2ac3dec.dll file from the Encore CS3 directory into the Premiere directory
Second - Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
What is a CODEC... a Primer http://forums.adobe.com/thread/546811
What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
For Mac http://mediainfo.massanti.com/
Ok, downloaded the correct version of MediaInfo. Here is the analysis:
General
Complete name : E:\Biomet 3i\Interviews 1-10-12\Cam 1 Card 1\BPAV\CLPR\FAUS0402_01\FAUS0402_01.MP4
Format : MPEG-4
Format_Commercial_IfAny : XDCAM EX 35
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 772 MiB
Duration : 2mn 58s
Overall bit rate mode : Variable
Overall bit rate : 36.3 Mbps
Encoded date : UTC 2012-01-10 23:45:09
Tagged date : UTC 2012-01-10 23:45:09
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Codec ID : 61
Duration : 2mn 58s
Bit rate mode : Variable
Bit rate : 35.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 1.267
Stream size : 739 MiB (96%)
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Codec ID : twos
Duration : 2mn 58s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 32.7 MiB (4%)
Language : English
John:
When I import any folder it gives me a File Import Failure dialog box, but after I hit OK, the files are in the bin.
Not sure if this has anything to do with the issue. Whenever I import an entire folder or single clip, there is no conforming progress bar. There is no conforming at all.
Steve
North America
Asia Pacific
