Mapping Java errors to ActionScript errors
Jan 12, 2012 3:29 PM
I see from the Reference Implementation and the Java API that it's possible to set Error Data on the license request using either the values defined in the com.adobe.flashaccess.sdk.protocol.AdobeErrorData class, or custom values using CustomErrorData.
I want to create a test license server that can send specific error codes to the player, so that I can better test my player's responses to FAXS error codes.
To properly do this, I need to understand how the errors described in the Java API map to the different ActionScript runtime error codes. Is there a document somewhere that relates the two? I would rather not issue each ErrorData object individually from my license server to see what Flash Player & the FAXS runtime do with it.
-Mike
    Jan 18, 2012 11:40 AM   in reply to Mike Tolan
    Error codeAdobeErrorData fieldClient Error Mapping
    105REQ_UNSUPPORTED_VERSION3350
    110REQ_AUTH_TOKEN_INVALID_EXPIRED3301
    111REQ_MACHINE_TOKEN_INVALID_EXPIRED3324
    112REQ_DRM_CREDENTIAL_NEEDS_UPGRADE3335
    113REQ_RUNTIME_CREDENTIAL_NEEDS_UPGRADE3337
    114REQ_DRM_VERSION_NOT_SUPPORTED3334
    115REQ_RUNTIME_VERSION_NOT_SUPPORTED3336
    116REQ_UNSUPPORTED_VERSION_NEED_UPGRADE3335
    202AUTH_FAILED3301
    302LACQ_CONTENT_METADATA_INVALID3314
    303LACQ_CONTENT_POLICY_EXPIRED3303
    304LACQ_CONTENT_POLICY_REVOKED3303
    305LACQ_USER_NOT_AUTHORIZED3304
    306LACQ_AUTHENTICATION_REQUIRED3330
    307LACQ_TAMPERING_DETECTED3326
    311LACQ_DOMAIN_REGISTRATION_REQUIRED3360
    312LACQ_CONTENT_POLICY_NOT_YET_VALID3331
    313LACQ_DEVICE_CAPABILITIES_INSUFFICIENT3347
    501DOM_REG_DENIED3355
    502DOM_LIMIT_REACHED3355
    503DOM_AUTHENTICATION_REQUIRED3330
    Note:
    - Any error codes defined in AdobeErrorData which are not listed in the mapping above will result in 3328 on the client. The client suberror code will carry the error code sent by the server.
    - If the server defines custom error codes using CustomErrorData, this will result in 3329 on the client. The client suberror code will carry the error code sent by the server.
    Reference error code links:
    http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/run timeErrors.html
    http://help.adobe.com/en_US/flashaccess/3.0/javadocs/com/adobe/flashac cess/sdk/protocol/AdobeErrorData.html
