robinsf44
Coldfusion 9 Developer with Apache 2.2.21 Installation Error
Jan 13, 2012 5:34 PM
Tags: #apache #coldfusion #installation_failure #wamp
I'm trying to install ColdFusion 9 Developer addition over WAMP which runs Apache 2.2.21.  During the installation process, everything goes well until I get to the "Add Web Server Configuration" window which asks for the configuration directory (C:\wamp\bin\apache\Apache2.2.21\conf) and the directory and file name of the server binary (C:\wamp\bin\apache\Apache2.2.21\bin\httpd.exe).  After I've entered this info and hit OK, I get the following error message:
Adobe Coldfusion 9 does not support this version of Apache.  The earliest supported Apache versions are 1.2.12 or later for Apache 1.x and 2.0.43 or later for Apache 2.x.
At this point, I'm prevented from continuing with the installation process.  According to this error message and white papers on the Adobe site, my version of Apache is supported.  Any suggestions for what I need to do to get CF9 installed.
thanks in advance,
    Jan 14, 2012 1:37 AM   in reply to robinsf44
    Sounds like a bug in the installer (to state the obvious, sorry).
    Does Adobe still offer free support for installation issues?  Macromedia used to, from memory?
    I am loath to suggest it, because all I hear from people trying to get official CF support from Adobe is horror stories of endless redirection/misdirection, but you could see if they still do offer free installation support and give them a call...
    But if the install doesn't recognise your Apache version, I'm not sure what else to suggest.
    Perhaps just go through the installation using the inbuilt JRun web server, and configure Apache after completion with wsconfig.  If it's a bug with the installer, the same bug might not be present in wsconfig.
    That said, if it's just a dev machine, the inbuilt JRun web server might be sufficient anyhow?  It depends what you're doing with your web sites, I guess.
    Adam
    Feb 14, 2012 2:33 AM   in reply to robinsf44
    Could we see the content of the file httpd.conf? It was well known in the past that ColdFusion mistakenly configured mod_jrun20 as JRun module, instead of mod_jrun22.
    Mar 21, 2012 1:37 PM   in reply to robinsf44
    I'm having this exact machine on 2 out 3 machines. The one it's working on is Win7 the others are WinXP but I can't imagine that has anything to do with it.
    Apache was installed in XAMPP, latest version. We're all using the exact same installer for both XAMPP and CF server.
    Do you have any update on this?
    Mar 21, 2012 2:19 PM   in reply to DanomiteDev
    Just an FYI - I ditched XAMPP and for the machines it wasn't working on, I installed Apache directly from here and it worked just fine.
    http://mirrors.axint.net/apache//httpd/binaries/win32/httpd-2.2.22-win 32-x86-no_ssl.msi
