Could not load the Bigger Tiles Modules
Jan 14, 2012 5:12 PM
I use Photoshop CS5 on iMac 3.06GHz IC2D with Lion 10.7.2. When I start Photoshop a Popup says : Could not load the Bigger Tiles Modules because it does not work with this version of Photoshop. Pity, but how to disable this Popup at every start ?
    Jan 14, 2012 5:42 PM   in reply to cldjr
    Delete the plugin.  You copied a plugin from an older version of Photoshop, and it does not work with Photoshop CS5, nor is it needed.
    Nov 4, 2012 10:13 PM   in reply to cldjr
    If you're getting a message about that plugin not loading.. then yes, that plugin exists and you have Photoshop trying to load it.
  • Noel Carboni
    Dec 23, 2006
    Nov 5, 2012 1:57 AM   in reply to cldjr
    The key, to which Chris alluded, is that you copied plug-ins from an earlier version of Photoshop - or you set the Extra plug-ins folder location preference to point to such plug-ins, probably to try to shortcut the process of getting the same set of 3rd party plug-ins installed that you had installed before.
    You can't do it that way, because you also likely carried along the plug-ins that were provided by Adobe with Photoshop.
    You have to undo that - ALL of that - and return your plug-ins back to just the set provided with the current version of Photoshop.  Then you have to install just your 3rd party plug-ins.
    I'm curious - what gave you the idea that you could just try to port your plug-ins from the older Photoshop wholesale like that?
    -Noel
    Nov 6, 2012 12:18 AM   in reply to cldjr
    At some point, you did copy plugins from an older version, or mistakenly pointed the optional plugins folder preference at an older version -- otherwise you wouldn't have that obsolete plugin or the error about it not loading.
    Sep 18, 2013 7:34 AM   in reply to Chris Cox
    I get this same warning with Photoshop CC.  Every time, and it was a fresh install on a new machine.  I have neither ported or installed any third party plug-ins.  Any other ideas?
    Sep 18, 2013 7:02 PM   in reply to Amit5000
    Bigger Tiles has not been necessary for quite some time, and could actually cause problems in recent versions of Photoshop.  You should not have copied it from a previous version.  Go delete the plugins you copied from a previous version of Photoshop.
    Sep 19, 2013 7:12 AM   in reply to Chris Cox
    Thanks for your help, but once again - I did not copy anything from any previous versions.  This is a fresh install from CC on a brand new machine.  This plug-in/module is definitely part of the CC install. That being said, I found it in the 64bit Photoshop Plug-In folder, removed it, and the issue has been fixed.
    In this thread you keep insisting that people copied it from an older version, and while that may often be the case, it is 100% NOT the case for some of us.  It seems to have been installed automatically with the CC download.  Ultimately the fix is the same, and simple to boot.
  • Pierre Courtejoie
    Jan 11, 2006
    Sep 19, 2013 7:17 AM   in reply to Amit5000
    Hello, Amit If it was the case, the million of Photoshop CC users (assuming all CC subscribers installed it) would have the issue. It should not be there on a normal installation...
    Can we see the contents of help>system information... to see what else is installed incorrectly.
    Sep 19, 2013 7:26 AM   in reply to Pierre Courtejoie
    Sure... I hope this helps and this is what you mean.  It is the case that I installed it fresh on a new machine, but maybe I checked a wrong box along the way.  I certainly have no reason to deny installing it any other way.  Regardless, it was only a slight annoyance and such an easy fix.
    Adobe Photoshop Version: 14.1.1 (14.1.1 20130910.r.414 2013/09/10:23:00:00) x64
    Operating System: Windows 7 64-bit
    Version: 6.1 Service Pack 1
    System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
    Physical processor count: 6
    Logical processor count: 12
    Processor speed: 4374 MHz
    Built-in memory: 32710 MB
    Free memory: 28757 MB
    Memory available to Photoshop: 29685 MB
    Memory used by Photoshop: 60 %
    Image tile size: 1024K
    Image cache levels: 4
    Display: 1
    Display Bounds: top=0, left=0, bottom=1200, right=1920
    Display: 2
    Display Bounds: top=0, left=1920, bottom=1200, right=3840
    OpenGL Drawing: Enabled.
    OpenGL Allow Old GPUs: Not Detected.
    OpenGL Drawing Mode: Advanced
    OpenGL Allow Normal Mode: True.
    OpenGL Allow Advanced Mode: True.
    NumGPUs=1
    gpu[0].OGLVersion="3.0"
    gpu[0].MemoryMB=3072
    gpu[0].RectTextureSize=16384
    gpu[0].Renderer="Quadro K4000/PCIe/SSE2"
    gpu[0].RendererID=4602
    gpu[0].Vendor="NVIDIA Corporation"
    gpu[0].VendorID=4318
    gpu[0].HasNPOTSupport=1
    gpu[0].DriverVersion="9.18.13.2049"
    gpu[0].Driver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2 um,nvwgf2um"
    gpu[0].DriverDate="20130621000000.000000-000"
    gpu[0].CompileProgramGLSL=1
    gpu[0].TestFrameBuffer=1
    gpu[0].OCLSupported=1
    gpu[0].OCLVersion="1.1"
    gpu[0].CUDASupported=1
    gpu[0].CUDAVersion="4.2.1"
    gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 NVIDIA via Cg compiler"
    gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTR UCTIONS_ARB]=[65536]
    gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
    gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
    gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
    gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
    gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
    gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
    gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
    gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
    gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
    gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
    gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
    gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
    gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
    gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
    gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
    gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
    Serial number: 90970468542907043447
    Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\
    Temporary file path: C:\Users\Amighty\AppData\Local\Temp\
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      C:\, 223.2G, 140.5G free
    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\Plug-Ins\
    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
    Installed components:
       ACE.dll   ACE 2013/07/14-12:09:50   79.543790   79.543790
       adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
       AdobeLinguistic.dll   Adobe Linguisitc Library   7.0.0
       AdobeOwl.dll   Adobe Owl 2013/03/03-12:10:08   5.0.13   79.533484
       AdobePDFL.dll   PDFL 2013/03/13-12:09:15   79.499517   79.499517
       AdobePIP.dll   Adobe Product Improvement Program   7.0.0.1786
       AdobeXMP.dll   Adobe XMP Core 2013/03/13-12:09:15   79.151481   79.151481
       AdobeXMPFiles.dll   Adobe XMP Files 2013/03/13-12:09:15   79.151481   79.151481
       AdobeXMPScript.dll   Adobe XMP Script 2013/03/13-12:09:15   79.151481   79.151481
       adobe_caps.dll   Adobe CAPS   7,0,0,21
       AGM.dll   AGM 2013/07/14-12:09:50   79.543790   79.543790
       ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
       aif_core.dll   AIF   5.0   79.534508
       aif_ocl.dll   AIF   5.0   79.534508
       aif_ogl.dll   AIF   5.0   79.534508
       amtlib.dll   AMTLib (64 Bit)   7.0.0.169 BuildVersion: 7.0; BuildDate: Mon Apr 8 2013 2:31:50)   1.000000
       ARE.dll   ARE 2013/07/14-12:09:50   79.543790   79.543790
       AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
       AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
       Bib.dll   BIB 2013/07/14-12:09:50   79.543790   79.543790
       BIBUtils.dll   BIBUtils 2013/07/14-12:09:50   79.543790   79.543790
       boost_date_time.dll   DVA Product   7.0.0
       boost_signals.dll   DVA Product   7.0.0
       boost_system.dll   DVA Product   7.0.0
       boost_threads.dll   DVA Product   7.0.0
       cg.dll   NVIDIA Cg Runtime   3.0.00007
       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
       CIT.dll   Adobe CIT   2.1.6.30929   2.1.6.30929
       CITThreading.dll   Adobe CITThreading   2.1.6.30929   2.1.6.30929
       CoolType.dll   CoolType 2013/07/14-12:09:50   79.543790   79.543790
       dvaaudiodevice.dll   DVA Product   7.0.0
       dvacore.dll   DVA Product   7.0.0
       dvamarshal.dll   DVA Product   7.0.0
       dvamediatypes.dll   DVA Product   7.0.0
       dvaplayer.dll   DVA Product   7.0.0
       dvatransport.dll   DVA Product   7.0.0
       dvaunittesting.dll   DVA Product   7.0.0
       dynamiclink.dll   DVA Product   7.0.0
       ExtendScript.dll   ExtendScript 2013/03/21-12:10:31   79.535742   79.535742
       FileInfo.dll   Adobe XMP FileInfo 2013/03/19-12:09:02   79.151561   79.151561
       filter_graph.dll   AIF   5.0   79.534508
       icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       imslib.dll   IMSLib DLL   7.0.0.116
       JP2KLib.dll   JP2KLib 2013/02/19-12:28:44   79.248139   79.248139
       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
       libiomp5md.dll   Intel(R) OMP Runtime Library   5.0
       libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
       LogSession.dll   LogSession   2.1.2.1785
       mediacoreif.dll   DVA Product   7.0.0
       MPS.dll   MPS 2013/03/15-13:25:52   79.535029   79.535029
       msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       PatchMatch.dll   PatchMatch 2013/06/11-12:08:08   79.542390   79.542390
       pdfsettings.dll   Adobe PDFSettings   1.04
       Photoshop.dll   Adobe Photoshop CC   CC
       Plugin.dll   Adobe Photoshop CC   CC
       PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   4.0.1.34
       PSArt.dll   Adobe Photoshop CC   CC
       PSViews.dll   Adobe Photoshop CC   CC
       SCCore.dll   ScCore 2013/03/21-12:10:31   79.535742   79.535742
       ScriptUIFlex.dll   ScriptUIFlex 2013/03/21-12:10:31   79.535742   79.535742
       svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
       tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
       updaternotifications.dll   Adobe Updater Notifications Library   7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   7.0.1.102
       WRServices.dll   WRServices Mon Feb 25 2013 16:09:10   Build 0.19078   0.19078
    Required plug-ins:
       3D Studio 14.1.1 (14.1.1 x001)
       Accented Edges 14.1.1
       Adaptive Wide Angle 14.1.1
       Angled Strokes 14.1.1
       Average 14.1.1 (14.1.1 x001)
       Bas Relief 14.1.1
       BMP 14.1.1
       Camera Raw 8.2
       Camera Raw Filter 8.2
       Chalk & Charcoal 14.1.1
       Charcoal 14.1.1
       Chrome 14.1.1
       Cineon 14.1.1 (14.1.1 x001)
       Clouds 14.1.1 (14.1.1 x001)
       Collada 14.1.1 (14.1.1 x001)
       Color Halftone 14.1.1
       Colored Pencil 14.1.1
       CompuServe GIF 14.1.1
       Conté Crayon 14.1.1
       Craquelure 14.1.1
       Crop and Straighten Photos 14.1.1 (14.1.1 x001)
       Crop and Straighten Photos Filter 14.1.1
       Crosshatch 14.1.1
       Crystallize 14.1.1
       Cutout 14.1.1
       Dark Strokes 14.1.1
       De-Interlace 14.1.1
       Dicom 14.1.1
       Difference Clouds 14.1.1 (14.1.1 x001)
       Diffuse Glow 14.1.1
       Displace 14.1.1
       Dry Brush 14.1.1
       Eazel Acquire 14.1.1 (14.1.1 x001)
       Embed Watermark 4.0
       Entropy 14.1.1 (14.1.1 x001)
       Extrude 14.1.1
       FastCore Routines 14.1.1 (14.1.1 x001)
       Fibers 14.1.1
       Film Grain 14.1.1
       Filter Gallery 14.1.1
       Flash 3D 14.1.1 (14.1.1 x001)
       Fresco 14.1.1
       Glass 14.1.1
       Glowing Edges 14.1.1
       Google Earth 4 14.1.1 (14.1.1 x001)
       Grain 14.1.1
       Graphic Pen 14.1.1
       Halftone Pattern 14.1.1
       HDRMergeUI 14.1.1
       IFF Format 14.1.1
       Ink Outlines 14.1.1
       JPEG 2000 14.1.1
       Kurtosis 14.1.1 (14.1.1 x001)
       Lens Blur 14.1.1
       Lens Correction 14.1.1
       Lens Flare 14.1.1
       Liquify 14.1.1
       Matlab Operation 14.1.1 (14.1.1 x001)
       Maximum 14.1.1 (14.1.1 x001)
       Mean 14.1.1 (14.1.1 x001)
       Measurement Core 14.1.1 (14.1.1 x001)
       Median 14.1.1 (14.1.1 x001)
       Mezzotint 14.1.1
       Minimum 14.1.1 (14.1.1 x001)
       MMXCore Routines 14.1.1 (14.1.1 x001)
       Mosaic Tiles 14.1.1
       Multiprocessor Support 14.1.1 (14.1.1 x001)
       Neon Glow 14.1.1
       Note Paper 14.1.1
       NTSC Colors 14.1.1 (14.1.1 x001)
       Ocean Ripple 14.1.1
       Oil Paint 14.1.1
       OpenEXR 14.1.1
       Paint Daubs 14.1.1
       Palette Knife 14.1.1
       Patchwork 14.1.1
       Paths to Illustrator 14.1.1
       PCX 14.1.1 (14.1.1 x001)
       Photocopy 14.1.1
       Photoshop 3D Engine 14.1.1 (14.1.1 x001)
       Photoshop Touch 14.0
       Picture Package Filter 14.1.1 (14.1.1 x001)
       Pinch 14.1.1
       Pixar 14.1.1 (14.1.1 x001)
       Plaster 14.1.1
       Plastic Wrap 14.1.1
       PNG 14.1.1
       Pointillize 14.1.1
       Polar Coordinates 14.1.1
       Portable Bit Map 14.1.1 (14.1.1 x001)
       Poster Edges 14.1.1
       Radial Blur 14.1.1
       Radiance 14.1.1 (14.1.1 x001)
       Range 14.1.1 (14.1.1 x001)
       Read Watermark 4.0
       Reticulation 14.1.1
       Ripple 14.1.1
       Rough Pastels 14.1.1
       Save for Web 14.1.1
       ScriptingSupport 14.1.1
       Shake Reduction 14.1.1
       Shear 14.1.1
       Skewness 14.1.1 (14.1.1 x001)
       Smart Blur 14.1.1
       Smudge Stick 14.1.1
       Solarize 14.1.1 (14.1.1 x001)
       Spatter 14.1.1
       Spherize 14.1.1
       Sponge 14.1.1
       Sprayed Strokes 14.1.1
       Stained Glass 14.1.1
       Stamp 14.1.1
       Standard Deviation 14.1.1 (14.1.1 x001)
       STL 14.1.1 (14.1.1 x001)
       Sumi-e 14.1.1
       Summation 14.1.1 (14.1.1 x001)
       Targa 14.1.1
       Texturizer 14.1.1
       Tiles 14.1.1
       Torn Edges 14.1.1
       Twirl 14.1.1
       Underpainting 14.1.1
       Vanishing Point 14.1.1
       Variance 14.1.1 (14.1.1 x001)
       Variations 14.1.1 (14.1.1 x001)
       Water Paper 14.1.1
       Watercolor 14.1.1
       Wave 14.1.1
       Wavefront|OBJ 14.1.1 (14.1.1 x001)
       WIA Support 14.1.1 (14.1.1 x001)
       Wind 14.1.1
       Wireless Bitmap 14.1.1 (14.1.1 x001)
       ZigZag 14.1.1
    Optional and third party plug-ins:
       Alias PIX 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
       ElectricImage 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
       HSB/HSL 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
       JPEG 2000 2.0
       SGI RGB 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
       SoftImage 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
       Texture Fill 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
       Wavefront RLA 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
    Plug-ins that failed to load: NONE
    Flash:
       Extensis
       Adobe Exchange
       Kuler
    Installed TWAIN devices: NONE
    Sep 19, 2013 1:24 PM   in reply to Amit5000
    You've copied a bunch of optional plugins from Photoshop CS4 (11).  You really should get the ones for CC (14).
