vaughnc2
Watched Folders Not Updating Organizer version 10
Jan 14, 2012 5:18 PM
Tags: #photoshop #windows_7 #64-bit #7
I have version 10 and am using Windows 64-bit. I have new photos in my watched folder, but the organizer is not being updated with them. Any suggestions?
    Jan 14, 2012 11:31 PM   in reply to vaughnc2
    Use File...Watch Folders to check your settings -- the folders (and whether to watch subfolders), as well as "Automatically Add to Organizer".
    Ken
    Jan 16, 2012 10:34 PM   in reply to vaughnc2
    Plese see if the following steps fix the issue :
    1. Go to Start > Run
    2. Type in services.msc
    3. Navigate to Adobe Active File Monitor V 10.
    4. Double click to open it
    5. View the start up type and set it to Automatic if not already set to that.
    Thanks. Hope this helps.
    Feb 2, 2012 4:29 AM   in reply to vaughnc2
    I'd like to know the answer to this as well - I used to have PE5, no problems, but since getting 10 it doesn't watch the folders.  I went into services and changed Automatic Delayed to Automatic.  I also had version 5 of Active File Monitor set, so I tried pausing this (ie just leaving v10 on) but still didn't work.  I'm running PE 10 on a Windows 7 64 bit.
    Feb 2, 2012 7:38 AM   in reply to JustWantToLogIn
    Check all of your catalogs.
    I had the default Catalog "My Catalog" as well as a couple of others. When I set the Watch folder I was in a different catalog and the pictures didn't show up for me in the catalog.
    Looking in the other catalogs, I found my pictures were pulled into there instead.
    I'm not sure how to set which catalog for it to pull into, but if you've worked with multiple catalogs you may want to take a look there.
    Feb 2, 2012 10:17 AM   in reply to Dragonbite
    Thanks - tried that but I only have one catalogue, accessible to all users (there is only one user/adminstrator on the machine and it's not networked)
    Feb 9, 2012 5:22 AM   in reply to vaughnc2
    Still not working for me - I had v5 as well, so I stopped that in case there was some kind of conflict.  Still nothing pulling up automatically.
    May 7, 2013 5:06 AM   in reply to JustWantToLogIn
    try this
    Please see if the following steps fix the issue :
    2. Type in msconfig.exe
    3. Navigate to the "services" tab make sure Adobe Active File Monitor V 10 is checked.
    4. Hit Apply, Hit ok, Restart
