I setup Indexing Services in Windwos Server 2003, and I confirmed that it can index (out of the box) Static PDF (created LiveCycle Desinger), in addition to other file types.
However, the Dynamic PDF (also created with LiveCycle Desinger) are not indexed, or they do not show in the search result. Any one knows how to index also the dynamic PDF files under Microsoft
Indexing Services?
Tarek.
Thanks Niall,
What about this Adobe PDF IFilter V6:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=2611
Could you please help me to find out if it will work ?
Will it index Adobe Dynamic PDF Forms ?
Thanks.
Hi Tarek,
I am not sure that the Adobe IFilter v6 will work either. The blurb talks about the functionality being built in to Reader 8, which would put this back in 2006 approx. In addition I think that it is intended for indexing PDFs generally and not specifically targetting Dynamic XML Forms.
From an OS point of view, the preview of Dynamic XML Forms in Finder does not work in Apple OS X 10.6 either:
I don't know of ny other solution.
Niall
I installed "ifilter60.exe" on Windwos 7 (work laptop) and also installed "IFilterShop_XmlFilter_SE_1_0_Eval.exe" to index XML content. It is clear that Dynamic PDF is not indexed. Luckly, I am storing XML Data in a separate file for each PDF, which will be very helpful. I can search files using XML content instead, and since I am following a standard naming convension, I can easily relate the found results in XML to PDF files.
See snapshots below:
but, when I search against file name, I can get results, but still PDF content is not visible:
Hope my fidings will be of help to others.
Tarek.
North America
Asia Pacific
