brianpan
Reader 10.1.2 won't print
Jan 15, 2012 2:34 PM
Tags: #printing #failure #10.1.2
Operating System XP SP3.  Installed Reader 10.1.2 and now cannot print pdf's opened in IE8, nor pdf's opened directly in the reader.  Printer (HP Laserjet 1020) "prints" a blank sheet, then displays error signal and has to be switched off and on again before it will print anything else, from any other source.  Prints WORD 2003 documents perfectly - as always.  When previous reader version was in use, there were no problems. It looks as though an urgent error fix is needed - am I right?
Brian.
    Jan 19, 2012 2:32 AM   in reply to brianpan
    Please see if any of the workarounds listed below, work for you:
    http://kb2.adobe.com/cps/928/cpsid_92870.html
    Jan 19, 2012 6:23 AM   in reply to Ankit_Jain
    Thanks Ankit_Jain. It works fine
    Following latest security update from Adobe for Acrobat Reader, I was unable to print anything anywhere (Reader crashing). Even reinstalling from scratch didn't change anything.
    After I followed the workaround listed (Reader 10.1.2 does not print), I shared all the printers from my XP Virtual Machine, thus allowing me to print again.
    Jan 19, 2012 6:27 AM   in reply to alain355
    Glad it worked for you.!!
    Jan 20, 2012 10:03 AM   in reply to Ankit_Jain
    I am running Windows 7 (64-bit) and Adobe Reader 10.1.2, and have the same problem.  My printer is "shared" per the KB article refrenced above, but still will not print.  When I hit the "print icon" or do Cntrl-P, the Adobe application closes.
    Any Suggestions?
    Jan 22, 2012 10:29 PM   in reply to thrumsl
    Please post a screenshot of the printer sharing settings if possible.
    Jan 24, 2012 9:15 PM   in reply to brianpan
    We have provided the permanent fix for this issue. please refer http://kb2.adobe.com/cps/928/cpsid_92870.html.
    Atul Agarwal
    Adobe Systems
    Feb 1, 2012 1:19 PM   in reply to brianpan
    I am having the same problem. I tried the download and it didn't change anything. I uninstalled 10.1.2 and installed 9.5 and still have the same issue. I can print from all other programs but not Adobe. I have tried restarting the computer (Win XP SP3) and the printer (HP Officejet 6500). I have also tried to print as an image and that does not work either.
    Any other suggestions?
    Feb 1, 2012 8:16 PM   in reply to lisaemb
    Did you also run the patch?
    Feb 1, 2012 8:53 PM   in reply to Pat Willener
    Yes, I did. And restarted everything again afterwards.
    Lisa Smith
    703-401-2831
