• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
2 dimensional vector how do i do it? plse help
Guest
Jan 15, 2012 Jan 15, 2012
Ls,
Im trying to create an x/y grid in  a 2 dimensional vector for reference of a boolean flag.
I thought it would be something like this below (doesnt work😞
var tabley:Vector.<Vector.<Boolean>>;
var tablex:Vector.<Boolean>;
var y:int = 0;
var x:int = 0;
tabley  = new Vector.<Vector.<Boolean>>(mapHeight,true);
for (y = 0; y< mapHeight;y++)
tablex = new Vector.<Boolean>(mapWidth,true);
for (x = 0; x< mapWidth;x++)
  traverstablex = true;
  trace("newt:", y, x, tablex );
tabley = Vector(tablex);
it all ends after the first x loop in a miserable:
newt: 0 29 true
newt: 0 30 true
newt: 0 31 true
TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Boolean>@2a380b51 to __AS3__.vec.Vector.
at FruitGamev6_fla::MainTimeline/frame2()
at flash.display::MovieClip/gotoAndPlay()
at FruitGamev6_fla::MainTimeline/testlevel()
Any help is greatly appreciated.
Regards,
Mac
TOPICS
ActionScript
Views
1.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
a vector in flash is a "typed" array.  it is not related to a mathematical vector.
Votes
Translate
Translate
Report
Report
Guest
Dude! im well Kglad to hear from you.
I dont understand your reply.
All i want is a vector (or an array; but since vector is so much faster.. )
That can contain:
Yrow(0) -> Xrows(10)  // xrow(0) = true,xrow(1) = true, xrow(2) = false...
Yrow(1) -> Xrows(10) // ...
Yrow(2) -> Xrows(10)
so i can reference the y,x coord and retrieve a boolena value or an int.
Some guy on a website suggested this (But cant seem to get it to work):
var v2:Vector.> ;
var v3:Vector.;
  v2 = new Vector.>();
  for (var ii:int = 0; ii < 10; ii++) {
   v3 = new Vector.();
   for (var iii:int = 0; iii < 10; iii++){
    v3[iii] = iii;
  v2[ii]=v3;
Votes
Translate
Translate
Report
Report
Community Expert ,
you have to datatype your vector array.  what datatype will your vector array contain?
Votes
Translate
Translate
Report
Report
Advocate ,
Jan 16, 2012 Jan 16, 2012
this worked for me
you didn't explain what traverstablex was so i assumed you meant tablex
tabley = new Vector.<Vector.<Boolean>>(mapHeight, true);
            for (var y:int = 0; y < mapHeight; y++)
                var tablex:Vector.<Boolean> = new Vector.<Boolean>(mapWidth, true);
                for (var x:int = 0; x < mapWidth; x++)
                    tablex = true;
                    trace("newt: ", y, x, tablex);
                tabley = tablex;
Votes
Translate
Translate
Report
Report
Guest
Jan 18, 2012 Jan 18, 2012
Hello _spoboyle,
Thank you for your reply.
I was so busy I missed it.
Your assumption is right, that was supposed to be tablex.
Actually, apart from the Vector cast at the end, i dont see the difference. Was that it?
I was gonna use it to remove a multiplication to calculate a tile coord from the updateframe event.
I dont know if a multidim. vector retains its speed benefit.
And, because it didnt get it to work, i'm now using a singledim vector for the ycoord alone.
The x coord only requires an add. so now its:  tabley[ycoord] + xcoord.
Wich saves me serveral multiplications.
Thank you for your help.
Ill try and see if i can get some more fps using the full vector routine you suggested.
Highest regards,
Mac
Votes
Translate
Translate
Report
Report
Advocate ,
Jan 19, 2012 Jan 19, 2012
LATEST
firstly becase the contents of tablex are typed to Vector.<Boolean> you don't need to cast (this would be different if you were using Arrays for example)
the reason the cast failed was becase tabley is typed to only contain Vector.<Boolean> and by casting tablex to a Vector it fails
Vector is not the same as Vector.<Boolean>
I have not tried it but I assume you could use
tabley = Vector.<Boolean>(tablex); //although this is totally unnecessary
Votes
Translate
Translate
Report
Report
