I am trying to duplicate a layer to another open document.
The problem is that it is not visible at all at the new document once the duplication procedure is complete.
Although the layers panel depicts the duplicated layer plus the usual backg. layer, in the document/canvas itself i do not see the layer which
by the way is an icon.
Thanks.
As you see in the image there is a purple layer and masks, which masks have the shape of icons.
I want to isolate a specific icon(via copy, duplication...whatever), but now i am thinking that maybe this is not possible, since we a talking here about masks.
I tried duplication and the thing is that in the new document, where the duplicated mask is going, i only see the mask in the layers panel(along with the purple background layer) and in the canvas itself i see nothing.
The only way this can be done, as i see it, is to ceate a new document, color the background/layer as i want it, and then copy there the mask/icon from the document where these are, and from which, the above screenshot is.
I tried the above with duplication and i have no succesfull results though-i see the mask in the layers panel but nothing on the canvas.
So, where do we go from here?
I'm having the same problem. I have a layer containing a photographic image, with a vector mask on it. This is all the file contains. It looks fine in its own file.
If I right-click on the layer and say Duplicate and pick another open file of the exact same size, the layer shows up at the top of the other document's layer list with mask intact, but its contents are invisible. Its opacity is 100%, blend mode normal. If I turn off the visibility of all other layers, the document is simply empty.
I also tried duplicating the layer to a new file. Same result: nothing visible in the new file.
I just noticed that if I toggle the duplicated layer's visibility while it's selected, a fine grey outline of the mask will appear overlaid on the image. The outline does not appear if I toggle the visibility of the duplicated layer when another layer is selected. It also doesn't appear if I simply select the duplicated layer while it's visible. I have to select it first, then toggle its visibility. Definitely a bug, and a pretty big one. I just spent considerable time making a vector mask, and it's useless.
This is Photoshop 13.0.1 x64 under Mac OS 10.8.3.
Update: If I tile the open files so I can drag and drop, the dragged layer does show up but its position varies based on where I release the mouse button when I drop it. Unbelievable. Again, this is between files of the exact same size. What you're dragging isn't even an image; it's an icon representing the layer. So it's not as if you can visually align anything during the drag! And you can't drag the layer to the title bar (tab) of the other image to drop it "centered" either; the tab isn't a valid drop zone. So how are we supposed to drop the layer in its "natural" position?
More info: Vector masks are unusable entirely because of massive rendering problems. Even if I add one to a layer in the file directly, eventually the masked image will be corrupted and blocks of it will disappear. The bizarre thing is that the parts that disappear can't be restored by zooming or other manipulation that forces redraws.
If your docs are tiled, dragging via a tab is unnecessary, but I guess you were only doing that to try to discover a "centred" drop method. Anyway, when you do go via a tab because docs are not tiled, drag onto a tab, wait there for about a half-second until that doc is activated... then continue the drag into the document window before releasing the mouse button.
Hold down Shift key while dropping in the destination.
North America
Asia Pacific
