Order of Exposure sliders
Jan 17, 2012 5:36 AM
Lr4 seems good so far. Impressed but there are some thing that don't seem to make sense for me like the order of the exposure sliders. Why is it that they are:
Highlights
Shadows
Whites
Blacks?
It should be:
Whites
Highlights
Shadows
Blacks
Doesn't it make more sense?
Also, Noise in the adjustment brush should be labelled as Noise Reduction. Leaving it as only 'Noise', when you increase the slider to a + value you expect it to increase noise, not reduce it.
    Jan 17, 2012 5:54 AM   in reply to Firillu
    The order of the sliders in PV2012 is very deliberate. PV2012 is a new way of looking at processing your images. There are numerous other posts here and elsewhere that discuss the hows and they whys. Julianne Kost has a nice video about the process. Summarized, you work from the top down and in pairs (Exposure/Contrast, then Highlights/Shadows, and lastly Whites/Blacks). Once you get used to it, you will find this much more powerful. Read a little more and watch a video or two about it and you will see why they are the way they are.
    As to your Noise slider naming question. Real Estate, pure and simple, is the answer. The interface is limited by the space available. While Noise Reduction might squeeze in, it won't in other languages necessarily.  This is why White Balance is called WB.
    Jan 17, 2012 3:34 PM   in reply to Firillu
    Firillu wrote:
    Yes I saw the video, but I still cannot see any sense in the sliders go from H to S then to W and B.
    You'll often need to adjust Highlights and Shadows, and much more rarely need to adjust Whites and Blacks.  That's why.
    Jan 17, 2012 3:55 PM   in reply to Firillu
    You are free to use them in what ever order you like. As you gain experience with the new control set you may find a completely different order suits your workflow.
    Jan 17, 2012 8:25 PM   in reply to Firillu
    I get the logic behind the current order, but I too think that it feels wrong and should match the histogram.
    Jan 17, 2012 9:27 PM   in reply to Firillu
    I know we can get used to this order but it is not a goo idea! It's like trying to learn to drive a stick shift with the gears out of order! IT IS HORRIBLE! I know I can get used to it but don't want to. I've gotten used to bad interface before, but that does not mean it is a good idea. PLEASE GIVE US AN OPTION IN PREFERENCES TO CHANGE THIS!!!
    Jan 17, 2012 10:06 PM   in reply to HEAD Productions
    HEAD Productions wrote:
    I know we can get used to this order but it is not a good idea!
    And yet, the odds of the order changing is nil (as close to ZERO as you can get). So, can you learn to adapt? You aren't being forced to use PV 2012...you can keep using PV 2010 but then you won't get the obvious PV 2012 improvements...your choice...
    Jan 17, 2012 10:14 PM   in reply to Jeff Schewe
    Jeff, you said you've got used to it, but do you think this new order is really better?
    Jan 17, 2012 10:17 PM   in reply to Firillu
    They make more sense to me the way they are - quite elegant I think.  But it's not a big deal.  Adapt.
    Jan 17, 2012 10:24 PM   in reply to HEAD Productions
    Well, yes...it leads you to the best order of adjustment. I really don't care what order the controls are in...what matters most is the ability to arrive at an optimal result in the least amount of effort...
    Jan 17, 2012 10:25 PM   in reply to Firillu
    To me the new order is far more logic than the alternative proposed here. My feeling is that the order is in accordance of how much the impact is on an image's appearance. So first exposure, then contrast, then fine tuning the highlights and shadows and in the end the last subtle effects with blacks and whites. To me very intuitive.
    It would be totally illogical to treat an image in a sequence according to the brightness level a slider represents. So, Adobe, definitely leave the sliders as they are, and don't clutter the option interface with a UI to configure the sequence of the sliders. It isn't necessary.
    Jan 17, 2012 10:42 PM   in reply to Firillu
    Firillu wrote:
    The order they are in do not aid worflow whatsoever, they are just put in an illogical order and not in the histigram's conventionional order. Why design a bad interface and we have to get used to it?
    There's one thing I don't think has been said yet and I think it's the key to the whole thing. The slider order is logical, in fact it is extremely logical and intuitive...once you get around to its perspective.
    In PV2010, we taught ourselves to work from the outside in. Set the end clipping points, then work within it. I say "we taught ourselves" because I don't think it was naturally intuitive. We all know lot of people weren't clear on Fill Light vs Blacks, or Exposure vs Brightness.
    In PV2012, the Develop controls work the opposite way: Not from the endpoints in, but from the midtone out.
    Exposure first: Overall range and midtone, in other words, setting the center. This is why Brightness disappeared.
    Contrast: Your basic S curve rotating, again, around the center.
    Highlights: The upper end.
    Shadows: The lower end. Think of Highlights and Shadows as a pair, rotating, once again, around the center. A refinement of Contrast.
    Because of the new highlight control, in many images the clipping may already be well controlled at this point. But if they still are not, then...
    Whites: Extreme highlight clipping, or white point.
    Blacks: Extreme shadow clipping, or black point. Again, think of these last two as a pair, pivoting...wait for it...around the center. A refinement of Highlights and Shadows.
    I'm not sure if that's the official explanation but that's how I see it, anyway. A series of concentric corrections starting from the midtone out. If you accept that concept, the new controls become very intuitive.
    That is also why having them in "histogram order" doesn't make a lot of sense, nor does setting a preference to rearrange the sliders. The current order of the sliders is what best represents the way the develop controls are designed to be used. It isn't just because it's top down, or because "you should." It's top down because the order resolves the contrast in each of the main tonal ranges moving progressively out from the midtone.
    If you see how the histogram gets highlighted as you move down the sliders, that's the order: from the center out. That's how it makes sense.
    Jan 17, 2012 10:40 PM   in reply to Conrad Chavez
    Conrad...correct.
    Unless there's an obvious need to the contrary, the order that the setting are ordered is useful to understand and embrace. Theres nothing written in stone that you MUST do anything in any particular order–that's the benefit of parametric editing.
    It doesn't matter what order you do the adjustments in, just the final resulst–which will be better with PV 2012 in almost any case (if you have any examples where PV 2012 is NOT better, post it–there's still time for certain changes).
  • LuxMirabilis
    Jun 8, 2010
    Jan 17, 2012 10:42 PM   in reply to Conrad Chavez
    Exposure first: Overall range and midtones, in other words, setting the center. This is why Brightness disappeared.
    Contrast: Your basic S curve rotating around, again, the center.
    Shadows: The lower end. Think of Highlights and Shadows as a pair, rotating around, once again, the center. A refinement of Contrast.
    Blacks: Extreme shadow clipping, or black point. Again, think of these last to as a pair, pivoting around...wait for it...the center. A refinement of Highlights and Shadows.
    Well put! That is the recipe, with some recursive looping added for good measure.
    Jan 17, 2012 10:50 PM   in reply to Jeff Schewe
    If it does not matter in which order you do the adjustments, than I still think it is better to have the tools in order. When I look at a photo I think of the tonal ranges in order, I'm not looking at the controls, and when I decide which tonal range I want to adjust and reach for the controls they are out of order, I have to stop and read the control names to find the one I want to use. I never have to do that in curves or most other tonal correction tools.
  • LuxMirabilis
    Jun 8, 2010
    Jan 17, 2012 11:00 PM   in reply to HEAD Productions
    It does not matter what order the sliders are changed from the program's mechanization. However, Adobe thinks that the order the controls are arranged is the most efficient way to edit most images. After trying it myself, I do agree.
    Jan 17, 2012 11:32 PM   in reply to Firillu
    Firillu wrote:
    The order one uses the sliders is subjective, and usually also depends on the photograph itself. Every guru has his magic way.
    What is not subjective however, is the standard way a histogram is layed out on all things photographic from cameras to software. It goes for white to highlights to shadows to black from one end to the other.
    Yes we can get used to it and adapt like other Lr quirks. But it is still bad and it is a shame that Adobe thinks that this uncenventional way is 'better' for us.
    Totally agree! Well said.
    Jan 18, 2012 6:50 AM   in reply to Firillu
    And how long have you been using LR4? How many images have you processed? Come back and report when you've spent a lot of time in the app and can make a valid judgement based on extensive experience...
    Jan 18, 2012 6:59 AM   in reply to Jeff Schewe
    I've processed three jobs, about a thousand images, and I hate the way it makes me jump from visulizing the histogram to find the control point I want, they don't correspond.
    Jan 18, 2012 7:09 AM   in reply to Firillu
    Well, I would suggest you can actually have it both ways.  If you interact directly with the histogram, pushing and pulling it back and forth, you can work more in the order you prefer (albeit right to left).  Adjusting the histogram directly is actually a very intuitive way to operate vs. using sliders - be one with the histogram!
    Jan 18, 2012 7:41 AM   in reply to Firillu
    Firillu wrote:
    Just in case you cannot read, I said it has nothing to do with experience. Has nothing to do with getting used to. They are in the wrong order irrelevant to whatever workflow you follow and whether you process one image or a trillion. Workflow is subjective, but the histogram is not. I do follow the order of develop panels, but the slider in this panel are illogical.
    I'll get used to it in 10 minutes, but they are still wrong.
    Please reconcile these two highlighted statements. Are you saying that Workflow is subjective unless it disagrees with you, in which case it is wrong?
    Realize that there are many workflows people follow. Some people love the new slider order. Some aren't emotionally attached and don't care. A few (two by my count in this thread) are opposed to it. To express that your workflow is right and that all others are wrong is not a good way to garner support for your, and here's the key word, opinion.
    You are part of the beta process through your voluntary participation. You have the opportunity to preview and comment on various changes and to offer suggestions things you feel need changed. If you want people to listen to you, express facts, present opinions and supporting arguments as such and not as fact, offer suggestions but respect other's workflows.
    Jan 18, 2012 8:01 AM   in reply to Firillu
    Firillu wrote:
    I don't want the sliders to follow my workflow or anyone elses for that matter - just folllow histogram conventions.
    I think that's the point. I don't need Adobe to inpose a workflow on me, thank you, I am capable of doing that myself.
    Jan 18, 2012 9:49 AM   in reply to HEAD Productions
    I think that the way in which each control works, and their order, has been designed to produce the most effective rendering of the raw file. You may of course use them in a different order, but you may not be rendering the file in the best way. You may find that turning the histogram off, and concentrating on the image itself, helps to appreciate the research and design behind the new setup. After all, a histogram is only one of many mathematical representations of an image; it is not the image which is what we are trying to render to the best effect.
    Bob Frost
    Jan 18, 2012 12:56 PM   in reply to Firillu
    Maybe there should be a divider line between Shadows and Whites so that the pairing is clear.
  • LuxMirabilis
    Jun 8, 2010
    Jan 18, 2012 4:14 PM   in reply to Mark Alan Thomas
    That makes sense.
