I have been using Audition 3.0 for quite some time. I use ASIO4all v2 audio driver most of the time and on occasion when I need to have more than one stream of audio at the same time recording something playing from the web) I switch to the Audition 3.0 Windows sound driver for direct sound. For some reason it (Audition 3.0 Windows sound) dissapeared from the driver selection box under audio hardware setup. According to device manager the sound card drivers are all installed and working properly. If I uninstall the ASIO driver and try to restart Audition, it says that it cannot find an audio device. When Audition is closed my system is running the realtek sound card driver and not the ASIO4all v2. For some reason it appears that audition cannot see the stock driver. Everything else on my system seems to be running normally.
Any advice on what to do would be appreciated as I have a lot of custom presets, so I would not like to uninstall and reinstall unless absolutely necessary.
Thanks!
If you go to the uninstaller, you'll find that there's a 'repair' option that does pretty much what it says on the tin. If you are running the 3.0.1 patch, you may have to re-run it afterwards - probably best to do this anyway. If you haven't installed the patch, then you should!
Thanks for the reponse, I should have included the fact that i am running the patch, and yes, I have tried the repair option with no change. I am wondering if it's a windows XP issue. Is there a way to back up all my custom settings? Maybe I would be best to try a fresh install of Audition?
I don't know why that the repair wouldn't work before, but I rebooted and tried again and this time it has repaired itself and I know have the option to select the Audition 3.0 windows sound driver now! Thank heavens for the repair function, all of my presets are not lost and full functionality has been restored!
North America
Asia Pacific
