Output of vectors in print
Jan 19, 2012 10:36 AM
  Latest reply: Eugene Tyson, Jan 21, 2012 12:13 PM
    Jan 20, 2012 11:15 AM   in reply to Gernot Hoffmann
    Gernot Hoffmann wrote:
    ...Please, quote a reference...
    I can't locate references but it is indeed possible to pack a vector clipping path in TIFF (or even JPG) and then have that vector path recognized in InDesign, Pagemaker, or QuarkXPress. Try it.
    Eugene Tyson wrote:
    ...Also can someone confirm that Smart Objcts, Photoshop PDF or not, will rasterise to the image resolution on output?
    Isn't that something that you can confirm for yourself by placing a SO in a Photoshop image with insanely low PPI?
    Jan 21, 2012 5:15 AM   in reply to Marian Driscoll
    Marian, you're right:
    It's possible in PhS to define a path as clipping path and to save the
    image together with the path as TIFF.
    The clipping is not immediately shown, but placing in InDesign makes
    it obvious.
    Other programs, here Paint and the Windows Image & Fax system,
    ignore the clipping effect.
    My guess: it's not a generic feature of the TIFF format, but an 'abuse'
    of metadata fields for arbitrary purposes, here by Adobe.
    I'm not really interested to digest the file format specs.
    Best regards --Gernot Hoffmann
  • PECourtejoie
    Jan 11, 2006
    Jan 21, 2012 5:50 AM   in reply to Gernot Hoffmann
    Gernot, (I don't know if other users were taunting you by using your Titles, I think remembering that you prefer to be adressed without them) with all due respect, this is not secret at all, I remember using it from Photoshop 4 with the infamous Quark 3.1: http://www.sketchpad.net/quarkpath.htm
    It is a very common practice in the print industry. (As long as it still exists.)
    As for Vectors in Photoshop, If you can send the same Letter size 4 ppi file with a vector circle to both a postscript laser and a non-postscript inkjet printers, you will see a big difference...
    I remember making the test long time ago.
    But the underlying question here seems to be what InDesign can do with Photoshop vectors, so the best place might indeed be the InDesign forum.
    Jan 21, 2012 8:17 AM   in reply to PECourtejoie
    Pierre, conversations are expected without titles, please.
    I think we can clarify everything, step by step.
    From my post #7 it should have been already clear, that vector paths can be reproduced
    only by PostScript devices.
    I know TIFF as a professional raster graphics format. I didn't know that it can reproduce
    clipping paths. Now let's investigate this issue further:
    (1)
    http://www.google.de/url?sa=t&rct=j&q=tiff%20%22file%20spec%22&source= web&cd=1&ved=0CCgQFjAA&url=http%3A%2F%2Fpartners.adobe.com%2Fpublic%2F developer%2Fen%2Ftiff%2FTIFF6.pdf&ei=Yt0aT4f1A4-g-wbyk42uCg&usg=AFQjCN Gp5Fw5VVGmAJLTd2PCmR-Y7Rr2cQ&cad=rja
    (2) quoted from (1):
    "Some image manipulation applications support notions of transparency masks and
    soft-edge masks. The associated alpha information described in this section is different
    from this unassociated alpha information in many ways, most importantly:
    Associated alpha describes opacity or coverage at each pixel, while clipping-related
    alpha information describes a boolean relationship. That is, associated alpha can
    specify fractional coverage at a pixel, while masks specify either 0 or 100 percent coverage."
    (1) refers to the file specs for TIFF, dated June 3 1992. This version appears on top
    of the Google search results. Therefore I'm assuming that it is the actual version as well.
    (2) tells us, the clipping path information seems to be converted into an alpha channel.
    This is very different to a true clipping path - the 'clipping related alpha information' doesn't
    concern scalable vector graphics, but simply on/off transparency.
    I think there is no doubt, that TIFF cannot reproduce/maintain arbitrary vector paths, and
    now it seems, that the 'vector clipping paths' are simulated by alpha transparency.
    Personally I had never any doubt that TIFF can contain alpha channels.
    Objections with references are welcome!
    By the way: the word path appears in (1) only once: as a part of sympathetic.
    Message was edited by: Gernot Hoffmann
  • PECourtejoie
    Jan 11, 2006
    Jan 21, 2012 8:47 AM   in reply to Eugene Tyson
    Gernot, I should have drawn a line after my first paragraph, as I was replying specifically about the "secret" mention, noting that the biggest competitor recognized clipping maths. Sorry for the confusion. I can't check the specs on this small screen. But I trust your analysis, and guess that we will have to fait for Chris Cox or another employee for à definitive answer.
    Jan 21, 2012 12:10 PM   in reply to Gernot Hoffmann
    Gernot,
    Some things I can speculate on and some things I consider fact - they can be demonstrated.
    Fact 1: Photoshop can save paths in jpegs  -  multiple paths and they need not be "clipping" paths
    Fact 2: Photoshop can save paths in tiffs     -  multiple paths and they need not be "clipping" paths
    Fact 3: These paths data can be read and used by Indesign (usually for clipping masks) and possibly other Adobe products  as well as any other app that  wants to do the binary detective work.
    Speculation 1: Adobe includes these data in similar ways in both formats.
    Speculation 2: The methodology used is not a standard extension of either format.  While I would not label this practice as format "abuse",  it is certainly not part of the standard and I suspect the data are also not part of the official metadata nor are they alpha channels. I believe they are stored in image resource blocks.
    Paulo
