• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Cflloop, Tables and CSS
Explorer ,
Jan 19, 2012 Jan 19, 2012
I have a web application that has an iframe (believe me it is necessary) split 69/30.  On the 30 portion of the page I have several tables that are stacked upon each other.
All tables are designated with the following:
<table width="100%" border="3" borderColor="##c0504d">
Several of the tables are being hidden using the [id = #Varidable# style="display:none"] property.  The hidden tables are created by a <CFLOOP query=foo>.    Here is the problem the tables within the CFLOOP are not the same width as the tables outside of the CFLOOP.  The are just a tad wider.
Here is a snippet of the actual code:
<CFOUTPUT>
          <TR>
               <th width="20%" align="Right">Risk:</th>
               <td width="80%" align="left">
                    #ThisTitle#
               </td>
                                   </TR>
                                   <TR>
                                                  <th align="Right" valign="top">Risk Statement:</th>
                                                  <td align="left">
        #GetThisRiskInfo.RiskStatement#
                                                  </td>
                                   </TR>
                    </table>
                                   <TR>
                                                  <td colspan="#zcount#">
                                                            <CFLOOP query="GetMission">#GetMission.CurrentRow#<BR>
        <CFIF GetMission.CurrentRow EQ 1>
        <CFSET HideArray1 = "ShowMission#GetMission.MissionID#">
        <CFELSE>
        <CFSET HideArray1 = HideArray1 & ", ShowMission#GetMission.MissionID#">
        </CFIF>
                                                            </CFLOOP>
        <input type="radio" name="xMissionID" value="#GetMission.MissionID#" onClick="javascript:HideNShow('#HideArray1#', 'ShowMission#GetMission.MissionID#')">#GetMission.MissionName# <CFIF #CurrentRow# NEQ #GetMission.RecordCount#> | </CFIF>
                                                            </CFLOOP>
                                                  </td>
            </TR>
                    </table>
                         <table width="100%" border="3" borderColor="C0504D" id="ShowMission#GetMission.MissionID#" style="display:none">
                                             <tr>
                                                            <td colspan="#ZCOUNT#" align="center">
        <strong>#GetMission.MissionName#</strong>
                                                            </td>
          </tr>
          <tr>
               <td>
... etc blah etc
               </td>
          </tr>
     </table>
</CFLOOP>
</CFOUTPUT>
What can I do to alleviate the problem with the table borders not aligning?
Thanks!
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Jan 19, 2012 Jan 19, 2012
Sarcasm is not appreciated.
The issue ended up being that additional data within the <table> tag.    I wrapped the table tag within the <CFLOOP> with a <div> and placed the ID and style tags in the div and the formatting issue went away.  So
became:
<div id="ShowMission#GetMission.MissionID#" style="display:none">
                    <table width="100%" border="3" borderColor="C0504D">
Votes
Translate
Translate
Valorous Hero ,
Copy the HTML output to a static HTML file.
Modify the HTML to alleviate that problem you are having.  Likely culprits are cell content that is stretching the table and|or whitespace in places that whitespace can cause problems.  Whitespace shouldn't cause probelms in HTML, but sometimes it still does.
Once you have the HTML working properly, port it back into the CFML page so that ColdFusion produces the desire HTML.
THen pray and hope that you can someday make a better and easier to maintain layout.
Votes
Translate
Translate
Report
Report
Explorer ,
became:
Votes
Translate
Translate
Report
Report
Valorous Hero ,
I am glad you found an answer, though I find it to be a bit of a strange answer.
But that was not a sarcastic reply.  That is exactly how I would debug a complex display issue like this.  Remove the dynamic from the system until I solved the output issue.
It is usually not that dificult to export the generate HTML from a browser into a file where one can then play with the elements to figure out what is causing the issue and then determine how to mitigate it.  Then one just needs to migrate the discovered solution back to the dynamic system.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Indeed the resolution was not of the ordinary variety.
I apologize for taking offense if none was intended.
Votes
Translate
Translate
Report
Report
Guide ,
In ilssac's defence, I'm pretty sure there was no sarcasm intended there. If you want someone to fix your code, go pay a consultant. If you want people to look at your problem for free in their spare time, accept you might not always get answers back in word-for-word how you'd like.
Votes
Translate
Translate
Report
Report
Resources
Documentation
