I have a bunch of multiple selection items which are all the same, so I copied and pasted them where I wanted them. The pasted ones are taking up two to three lines per choice (one word per line) even though they are very short and the original that I copied from only takes one line each. Does this mean I have to do each one manually? Why are the copied ones different from the original? Thanks!
It sounds like a bug, since this shouldn't be happening. However I tried to reproduce the problem, but couldn't. It's probably a bug, that specific to your choices labels. Could you share your form to me (trein@adobe.com), so I can take a look at the specifics? Once I can see it, I can provide some guidance about the issue and how to work around it (if posisble) until we've fixed it. You can share a form by clicking the share button, and then clicking add collaborators.
Todd
I'm able to reproduce the problem, and we'll fix it. But fixes take a while to get through our engineering and release process (i.e. 1 to 2 months). For now the work around is to add a blank choice to the copied multi-select field, and then delete the newly added blank choice. That seems to cause some change that eliminates the issue. Let me know if that works for you.
North America
Asia Pacific
