Hello I am trying to figure out how to make an image appear after a correct or incorrect answer has been selected.
I have a multiple choice question asking about a sequence. I would like an image to appear after an answer has been submitted.
I don't seem to be able to add an image inside of the feedback button?
Any solutions?
No, the default objects popping up on success/failure are text captions that cannot have images.
It is possible to achieve your goal, with advanced actions. I tried to explain functionalities and tweaking possibilities of question slides in these blog posts:
Lilybiri
Lilybiri
Lilybiri,
I wonder what your thoughts would be about using the success/fail to send the learner to a slide that shows the feedback images? It's more work, I think, but might work? Remove the feedback captions on the quiz slide, I think you'd have to change the failure level to 'none,' and set the 'on exit' on the feedback slides to jump to the next question?
Andy,
That was the only possible way in versions before CP4. Have a couple of reasons why I now try to avoid such solutions:
Lieve
can you help me understand how quiz scope would be a problem?
in the ToC, could you exclude those slides from displaying there, or is that just one more workflow thing to manage increasing the effort level?
And we're all aware of your AA freak-ness
The slides to be navigated to have to be in the quiz scope to avoid breaking the current quiz attempt. That is easy if you are aware of it, but not all users are, so you have to explain again about that scope.
Yes, you can hide those slides, but that is the type of work I hate. It is not that complicated to tweak the question slides to show different things from the default captions, so...
Lieve
ah yes, quiz scope. I would've put the feedback slides immediately after the question, so I didn't consider it as a problem, but I can see how someone might place them elsewhere in an effort to keep their slide flow 'clean.'
Thanks for your thoughts.
Ok. Sounds like there is no easy solution for this situation.
I am thinking now to have the next image in the sequence appear and disappear at the start of the next slide before the next question appear.
It is a shame that we can't place images inside of the feedback boxes. It seems like it would open a whole new world of possibilities in terms of bringing our content to life.
I was just looking for a way to do this too. This seems like much needed functionality.
