text in PS
Jan 25, 2012 8:11 AM
Is it true that we should avoid making text in Ps cause the letters appear pixelated?
What do you think about the about view? Is it true?
Meaning, AI or Fw should be used for this purpose.
    Jan 25, 2012 8:20 AM   in reply to JimVag1947
    It depends on the output, pdf or eps (with Vector Data) can hold vector elements and type.
    But for large amounts of copy I would recommend using a page layout application like Indesign.
  • PECourtejoie
    Jan 11, 2006
    Jan 26, 2012 1:05 AM   in reply to JimVag1947
    This was a suggestion from very long time ago, in the times of Photoshop 6 or 7, before the advent of vector shapes, or vector text. (we are in V12)
    If it is for a website, the text would be converted to an image, and you should use a web design application to insert text.
    Feb 12, 2012 2:16 AM   in reply to JimVag1947
    Faux styles can cause rasterization, so they are best avoided.
    Large quantities of text are better set in Indesign (or other page layout applications) for the simple reason that its type-features usually allow working more comfortably there.
    But otherwise, if the proper output format is used and separation considerations are taken (black text in an RGB-image will usually output as 4C-black on separation), setting text in Photoshop should be fine.
  • Noel Carboni
    Dec 23, 2006
    Feb 12, 2012 5:01 AM   in reply to JimVag1947
    No one here has mentioned the more advanced kinds of font smoothing avaialble to web browsers when rendering text on screen.  Jim has not said what his goals for use of his text are.
    Photoshop does do font smoothing - antialiasing - of several types and strengths, but it CANNOT do font smoothing that takes into account monitor characteristics - there's no way it can known what monitor the text you're rendering is going to be displayed upon.  ClearType font smoothing in Windows, for example as rendered in Internet Explorer, uses color to help achieve sharp text that's rendered at the sub-pixel level.
    So don't avoid using Photoshop to make text, especially for fancy fonts or drawn text that isn't going to be available to web browsers as a simple font, but if you're making a decision whether to render text that IS available as a web font to the browser, opt for having the browser render it instead of sending it as (part of) an image.  It will likely look better, be more scalable, and this will also result in a smaller amount of data sent to the user, meaning the site will display more quickly.
    -Noel
    Feb 12, 2012 5:13 AM   in reply to Noel Carboni
    Good point; I usually think of (some form of) print as the final output – which may not actually be the case in many cases.
  • Trevor.Dennis
    May 24, 2010
    Feb 12, 2012 12:46 PM   in reply to c.pfaffenbichler
    If you happen to have a Lynda.com account, then Nigel French's 'Photoshop for Designers - Type Essentials' is a worthwhile browse through.  In fact my absolute favourite Lynda.com title.
    Incidentally, Nigel French heavily frowns upon the use of Faux type effects, and insists that a properly designed font be used.
  • PECourtejoie
    Jan 11, 2006
    Feb 12, 2012 1:07 PM   in reply to Trevor.Dennis
    I rather see Faux Bold as a compatibility setting for old Photoshop files.
