Native event
Jan 27, 2012 1:12 AM
I have created AdvancedDataGrid in flex 4.5.1. under WindowedApplication.I want to handle nativeDragStart event but it gives error as--
TypeError: Error #1034: Type Coercion failed: cannot convert mx.events::DragEvent@13a8b511 to mx.events.DragEvent.
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.core::UIComponent/dispatchEvent()[E:\dev\4.5.1\frameworks\projects \framework\src\mx\core\UIComponent.as:13128]
          at mx.managers::NativeDragManagerImpl/_dispatchDragEvent()[C:\autobuild\ galaga\frameworks\projects\airframework\src\mx\managers\NativeDragMana gerImpl.as:625]
          at mx.managers::NativeDragManagerImpl/nativeDragEventHandler()[C:\autobu ild\galaga\frameworks\projects\airframework\src\mx\managers\NativeDrag ManagerImpl.as:598]
I have used following code--
<!-- http://blog.flexexamples.com/2007/09/19/dragging-rows-between-two-diff erent-flex-datagrid-controls/ -->
<mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml"
                                        layout="horizontal"
                                        verticalAlign="middle"
                                        backgroundColor="white">
          <mx:Script>
                    <![CDATA[
                                   import mx.controls.Alert;
                         protected function adg1_nativeDragStartHandler(event:NativeDragEvent):void
                                                      // TODO Auto-generated method stub
                                                       Alert.show("Native Event Handler");
          </mx:Script>
               <mx:ArrayCollection id="arr">
                         <mx:Object colA="Item A.0" colB="Item B.0" colC="Item C.0" />
                         <mx:Object colA="Item A.1" colB="Item B.1" colC="Item C.1" />
                         <mx:Object colA="Item A.2" colB="Item B.2" colC="Item C.2" />
                         <mx:Object colA="Item A.3" colB="Item B.3" colC="Item C.3" />
                         <mx:Object colA="Item A.4" colB="Item B.4" colC="Item C.4" />
                         <mx:Object colA="Item A.5" colB="Item B.5" colC="Item C.5" />
                         <mx:Object colA="Item A.6" colB="Item B.6" colC="Item C.6" />
                         <mx:Object colA="Item A.7" colB="Item B.7" colC="Item C.7" />
                         <mx:Object colA="Item A.8" colB="Item B.8" colC="Item C.8" />
                         <mx:Object colA="Item A.9" colB="Item B.9" colC="Item C.9" />
               </mx:ArrayCollection>
          <mx:AdvancedDataGrid id="adg1" designViewDataType="tree" dataProvider="{arr}" dragEnabled="true" dropEnabled="true" nativeDragStart="adg1_nativeDragStartHandler(event)">
                         <mx:columns>
                                        <mx:AdvancedDataGridColumn dataField="colA" headerText="Column 1"/>
                                        <mx:AdvancedDataGridColumn dataField="colA" headerText="Column 2"/>
                                       <mx:AdvancedDataGridColumn dataField="colA" headerText="Column 3"/>
                         </mx:columns>
          </mx:AdvancedDataGrid>
</mx:WindowedApplication>
someone please help me.
