Cut video - but audio starts at beginning
Jan 27, 2012 11:22 AM
Hello,
using Premiere CS 4.0 and I wanted to cut a video - the following happens when I want to cut with the razor tool or with in/out points in the timeline and then deleting the marked part with 'extract' (I think it's called that in english - have the german version).
So I cutted after 20s into the video and deleted the beginning and after rendering the video, the video starts correctly at 20s of the original file but the audio plays from the start of the original beginning - so it's completly out of sync.
The video itself is from my photo camera's video function and KMPlayer gives this for the video/codec information: http://pastebin.com/6Sw5JysF
Any ideas? I don't really want to re-encode the original file because of the time it would take and the possible quality loss.
    Jan 27, 2012 2:54 PM   in reply to nugush
    Hi, I am not sure if I understand your problem, but if you apply the razor tool it should cut both Video and Audio tracks at the same frame. Go back to the original tool (Arrow, Selection Tool in English, V on the keyboard). Then  mark on the timeline (left click) the clip you want to delete and use delete button on keyboard. If The Video And Audio clips are linked they both should disappear. If not linked delete Video and Sound clips separately. Be sure to delete all rendering files and rerender the project. If this is the first 20 sec's you could also move the timelinecontent left to start from the beginning of timeline before rerendering. Run it to see it is OK, then export.
    Good luck Anaestesia
    Jan 27, 2012 3:21 PM   in reply to nugush
    You might want to update to 4.2.1.
    Many bugs have been fixed.
    Jan 27, 2012 4:09 PM   in reply to nugush
    That is odd, and unexpected behavior. As we cannot see all of the Audio Tracks, down to the Master, is there anything on the Audio Tracks below your screen-cap?
    Also, if you Alt+click on the Audio Stream in your Clip # 2, to temporarily unlink it, and then Dbl-click on it, to load it into the Source Monitor Panel, which Audio do you get?
    As a test, you might want to go back to where you were, before you did the cutting. Repeat the cutting (Razor), and Delete the Audio & Video Streams from what will be your Clips # 1 and # 3, but do not yet Move Clip # 2. Play Clip # 2, and tell us what Auido you hear - Clip # 2's, or Clip # 1's.
    Jan 27, 2012 5:30 PM   in reply to nugush
    No Bugs, that I can recall. CS4 got at least 3 updates, and most users were very happy with CS 4.2.1.
    Glad that you got the Cuts and Move made. Only thing that I can think of, would be that PrPro got confused on which Render files to use, but that is only a guess.
    Good luck, and sorry that the Render times increased. Do not recall that, when CS 4 was being updated, but might have missed it.
    Jan 30, 2012 11:34 AM   in reply to nugush
    Hi, Seems you have found a workaround then. When you suffered the problems did you DELETE all rendered files and perform a rerendering? I adviced that and, Bill Hunt specultates if a mixup of renderfiles could be the problem... I am curious concerning this as I have sometimes suffered problems I think is due to renderfiles. When this problem happens it disappears when I delete all renderfiles in the project and rerender ... Looking forward to your reply.
    Anaestesia
    Jan 30, 2012 1:26 PM   in reply to nugush
    Pro does not handle the file correct.
    This file is an mpeg4 codec wrapped in an avi.
    So it might be best to convert the file.
