W3C error with select elements
Jan 27, 2012 4:23 PM
Tags: #select #html5 #w3c_validator
I am getting the following error message when using the W3C Validator on a HTML5 page in CS5.5:
Line 79 No space between attributes [HTML5]
Line 81 No space between attributes [HTML5]
Line 81 The select element cannot have ,ore than one selected option descendant unless the multiple attribute is specified [HTML5]
Line 82 No space between attributes [HTML5]
Line 82 The select element cannot have ,ore than one selected option descendant unless the multiple attribute is specified [HTML5]
The error appears when it checks a dynamic populated list created by Dreamweaver.
For every item in the list, I get the error shown in lines 81 and 82. The line 79 error always appears first..
The page works fine.
I did a search for this error on the web, and found that it was reported as a bug in the validator some time ago, but another report says that the bug has now been fixed.
When the validator stays on the page for longer than a few seconds with this error, Dreamweaver reports that it has ;lost contact with the  (local) Apache server. Dreamweaver has to be restarted to fix it.
Is this a bug in the validator or is it an error in the Dreamweaver list menu code.
It happens in any dynamically populated list with Dreamweaver generated with code like this:
<select name="pick" size="11" class="selectblue">
    <?php
do {
    <option value="<?php echo $row_Recordset1['club_index']?>"<?php if (!(strcmp($row_Recordset1['club_index'], $row_Recordset1['club_index']))) {echo "selected=\"selected\"";} ?>>
     <?php echo $row_Recordset1['club_name']?></option>
    <?php
     } while ($row_Recordset1 = mysql_fetch_assoc($Recordset1));
       $rows = mysql_num_rows($Recordset1);
       if($rows > 0) {
           mysql_data_seek($Recordset1, 0);
           $row_Recordset1 = mysql_fetch_assoc($Recordset1);
  </select>
