Our single edition app was rejected by Apple:
Viewer Builder: v1.8.0
Viewer Version: v1.8(32911)
2.3: Apps that do not perform as advertised by the developer will be rejected
We found that your app did not achieve the core functionality described in your marketing materials or release notes, as required by the App Store Review Guidelines.
Your app has the UIFileSharingEnabled key set to true in the Info.plist, but this feature is not functional
When file sharing is enabled, the entire Documents folder is used for file sharing. Files that that are not intended for user access via the file sharing feature should be stored in another part of your application's bundle. If your application does not require the file sharing feature, the UIFileSharingEnabled key in the Info.plist should not be set to true.
For discrete code-level questions, you may wish to consult with Apple Developer Technical Support. Please be sure to prepare any symbolicated crash logs, screenshots, or steps to reproduce the issues for when the DTS engineer follows up. For information on how to symbolicate and read a crash log, please see Tech Note TN2151 Understanding and Analyzing iPhone OS Application Crash Reports.
North America
Asia Pacific
