I have MAC mini 10.6.8 Iphoto 09 and recently installed Adobe PS8 including CS4 bridge.
I accessed teh briedge and browsed to my master IPhoto library.
Now when I try and access the libraray through IPhoto I have at least the last year's photo missing.
I have no backup and these are irreplaceable.
Lee
Don't know how you did that, bridge can't view the content of the library by default, it only shows the icon for library??
If you have deleted files using Bridge they should still be in the trash, maybe you messed with the folders in the library and did move the year folder to an other location.
I'm sorry to hear that, don't think you should be in panic right now, there is still a lot to investigate, just don't empty the trash and try to investigate further.
For instance use the finder and select the iPhoto library, Then use right mouse click and from the menu choose show package content. Navigate through the files and find either the folder called Masters (or originals, believe they changed the name once)
Inhere should be different folders for each year containing a lot of subfolders. Copy (Copy, don't remove!) these folders to a new folder outside the iPhoto library and point bridge to this new main folder. Then in bridge go to the menu View and choose show items from subfolders and let Bridge cache. Then see what has been left of your files.
Also open the trash (click on on the icon in the Dock) and see if there is a folder with the year called or other files you recognize. Just drag them out of the trash to a new location.
In general, it is not a question of if your HD is going to die but when, they all die, some sooner then to be expected. Also the human factor is by far from trusted so always, (always!!!) make a back up of important files!!
And don't try to mix iPhoto and Elements/Bridge without learning more about this way of working, iPhoto uses a library with hidden files and creates a lot of spin off with different versions, thumbs sizes etc. they are by default not developed to work together ![]()
Hi Omke,
thank you for your time and thoughts.
I had expected apple utility would help me recover by iphoto rebuild, so need to do a backup.
I had previously, jan 2011, used getbackup to do a backup to multiple DVDs.
Getbackup buld spool files before burning, and I could see i needed disk space..
So I did some hopusekeeping and emtied trash.
The getbackup wa still going to use many DVDs so after 1st I abandoned and resolved to buy HDD.
I have now purchased a usb external drive and carried out first time machine backup.
I was then about to try and fix Iphoto library using apple utility, although with a mac mini amd windows keyboard I do struggle with special key conbinations.
Then I found iphoto library manager and made a rebuilt copy of my iphoto libraray on a partition on the new disk.
However I have still lost more than 12 months of photos.
I am aghast that adobe software for MAC could do such a thing to a standard MAC library.
If anyone has any other help I would really really appreciate.
I will in due course log this as a formal call to Adobe, I am very unhappy with what their application has done.
Lee
North America
Asia Pacific
