Hi All,
What is the cause of this? Is there any way to overcome this issue or any work around? At the same time I need to retain the hyperlinks also. Because it is very very difficult to re-create the links (more than 100 or 200 number of links will be there in every chapter).
Note: I have tried something like trashing indesign preferences. It is also not working.
Green4ever
I restored all my indesign file in the same folder structure except the root folder. I already tried the way you suggested. It is not helping me.
"I thought that may be Indesign is searching for the missing links" So I try editing the preferences so that indesign will not search for the missing links(I think it is only aplicable for graphic links is it?). After that also I am facing the same problem.
Is there anyway to open the indesign file without checking for missing hyperlinks. So that it may open faster.
Green4ever
It sounds to me like the problem is the new server path, and hopefully once the files are corrected and resaved so everything points to the new path (and I don't do hyperlinks, so I'm not sure, but you may have to fix them all manually) and the files are saved you should be back to normal.
John may have some thoughts about a script that can do the path corrections for you, though.
Hi John,
I tried it yesterday but I cannot open the idml back in Indesign. It says file format doesn't support.
Then today again I tried it and got success. Yesterday I used 7zip to unzip and zip, it fails. Then today the same I tried using win xp's compress method. Really is there any problem in 7zip application?
Note: I used Epsilon to edit the xml. I hope it doesn't have any problem in dealing with the xml.
Green4ever
North America
Asia Pacific
