Rakesh3211
Blazeds dynamic destination
Jan 31, 2012 1:11 AM
Tags: #flex #dynamic #blazeds #destination
I'm trying to create dynamic destinations using BlazeDS. To start with I used the 'Feed' sample that comes with BlazeDS. It has a destination defined as 'feed' in messaging-config.xml. Now I commented the destination in messaging-config.xml and added the following code in Feed.java, to create dynamic destination
MessageService service = (MessageService) msgBroker.getService("message-service");
Destination destination = service.createDestination("feed");
if (service.isStarted()) {
   destination.start();
   System.out.println("Started destination....");
On the Java side it doesn't throw any error. But this doesn't work on the Flex side as it doesn't find the dynamically created destination.
    Jan 31, 2012 3:51 AM   in reply to Rakesh3211
    BlazeDS contains a sample that illustrates how the dynamic messaging destination is created and used from Flex. The sample is called runtimeconfig-messaging. You can use that as a template to get your particular destination working.
    Rohit
