i have a js function that works fine when attached to the onClick event of a button, but i want it to execute when user clicks the tab
is there a way to do that?
function clearURL() {
var testURL = document.URL;
var urlQry = testURL.split("?")[1];
if (urlQry != "")
var activeTab = ColdFusion.Layout.getTabLayout('myLayout').getActiveTab().title;
if (activeTab == 'myTabTitle')
var newURL = testURL.split("?")[0];
window.location = newURL;
thanks
ion wrote:
thanks BKBK, but is not really working. is not the whole layout that needs to be affected, only one layoutarea.
when i do this, it throws the layout out of wack, and when clicked, it does nothing (no error either)
I understand. You could place the DIV within the layoutarea, as in this example:
f = function () {
alert('Karamba!')
</script>
<cflayout type="tab" name="tabLayout">
<cflayoutarea name="tab1" title="Tab 1">
Tab 1 contents
</cflayoutarea>
<cflayoutarea name="tab2" title="Tab 2">
<div onclick="f()" >
Tab 2 contents
</div>
</cflayoutarea>
</cflayout>
I used this to submit a form using ajax whenever a new tab is selected. This is essentially the onclick portion:
ColdFusion.Layout.onTabActivate = function(tab)
ColdFusion.Layout.onTabActivate = function(tab){
ColdFusion.Ajax.submitForm('myform', 'my.cfm')
</script>
<cfform id="myform" name="myform" action="my.cfm" method="post">
Tab 1 contents (form input)
</cflayoutarea>
Tab 2 contents (form input)
</cflayoutarea>
</cflayout>
</form>
Maybe this will help: http://api.jquery.com/keypress/
North America
Asia Pacific
