PDF to FlashPaper
Feb 1, 2012 2:08 AM
   I want to convert a PDF document into FlashPaper swf.
   I printed the document from the Adobe Acrobat to FlashPaper.
   I could not even select the text in swf. i.e the acrobat printed as image.
   So, what should I do to make the swf from PDF. (the text in swf should be selectable & searchable)
Thanks in advance,
Vinod Kumar.K.V
    Feb 11, 2012 2:20 PM   in reply to vinod kumar k v
    Obvious question, in the FlashPaper SWF did you select the text selection tool, or keep it at the hand?
    If so, what you like have to do is find out the instructions for making an image text selectable in Adobe Acrobat, and then do the conversion.
    Maybe the text selector will then work in FlashPaper?
    Maybe you'll need to us an OCR first to convert image to text?
    Never done it, but I'm sure there is a way per the above to do what you're asking.  Common for images in pdf's to not have selectable text.
    Google search will likely give results.
    Feb 16, 2012 5:15 PM   in reply to vinod kumar k v
    Well, sadly it's probably some compatability bug between versions of Acrobat etc., who knows.
    Sadly FlashPaper is dead....
    Good luck.
    Jul 18, 2012 12:16 AM   in reply to vinod kumar k v
    Did you try the flipbook maker software, it can convert PDF to Flash flipping page or SWF files, you just can Google it and download to have a try.
    Dec 19, 2013 3:39 AM   in reply to vinod kumar k v
    Hope this is helpful: How to Convert PDF to Word Document
