einsteinart
InDesign "Find Font" deletes text - help!
Feb 1, 2012 6:57 AM
Tags: #font #indesign #indesign_cs5.5
So I open a file, use 'find font' to find and replace a font. Sometimes when I hit "change all" it deletes entire paragraphs of text. I've tried it with different fonts and it's not consistent. Sometime it deletes, sometimes it doesn't.
Just now, I did a "change font" from Garamond to Univers and lost a paragraph on page one - no text in the box whatsoever. So I did and Undo. Then, I did the exact same "change font" again. Paragraph on first page is fine, one on page 2 goes missing. Any help would be appreciated.
Thanks.
    Feb 1, 2012 8:06 AM   in reply to einsteinart
    Is the text going into overset, leaving a "hole" in the middle of a frame with text before and after it showing, or is it being completely removed from the story (deleted). Waht do you see if you switch to story editor?
    Please, also, tell us your version of ID, and the patch level, along with your OS.
  • John Hawkinson
    Jun 25, 2009
    Feb 1, 2012 9:02 PM   in reply to einsteinart
    Creative Suite 5.5
    I have an attachment to show you, but I can't seem to get it to attach here. it's only 90k...
    Hold down Cmd and select About InDesign to get the full version. 7.5.0, 7.5.1, or 7.5.2?
    You can only attach images on the forum. So post a screenshot of the issue, please.
    Feb 2, 2012 4:36 AM   in reply to John Hawkinson
    You cannot "attach" anything. You can embed an image, but only on the web page. Use the camera icon, like this:
    If you want to share the files, you can load them on a server and put a link to them here. One way to do that is with DropBox. Another is to use YouSendIt.com to send the files to yourself, then post the link here.
    Feb 27, 2012 11:18 AM   in reply to einsteinart
    Help > Updates... and make sure you have the 7.5.2 patch installed.
    And see Remove minor corruption by exporting
    If it happens to more than one file, see Replace Your Preferences
    Mar 8, 2012 5:39 AM   in reply to einsteinart
    Maybe somebody else has some ideas. I never export jpeg from ID.
